questions on ff12r 985 (A03) new modes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-07-2003, 04:05 PM - Thread Starter
tedm's Avatar
I've got a 985 with ff12r firmware, and have read some good reviews of the new SP+ mode (2.5hrs).
I'm curious if the new modes or any non SP modes (I've been using 2 hr. SP mode almost exclusively, and am happy with it), have any decreased compatibility in other dvd players?
Any comments on EP mode (4hrs) in general, or the new EP+ (6 hrs!) ??
thanks.
tedm is offline
post #2 of 4 Old 08-09-2003, 10:33 AM
drjohnc's Avatar
As to compatibility with other players, the DVD+R/+RW format is the most compatible there is. I also record to DVD-R/-RW, and have a total of six DVD players, only the Pioneer which creates the DVD-R/-RW can play back those recorded in excess of 2 hours, although all players can play back DVD+R/+RW discs recorded at any speed.
In my own experience (I've recorded well over 400 discs using both formats), recording in excess of 3-1/2 hours yields poor video results. Six hour recordings are worse than standard VHS tapes, and 4 hours recordings are not much better. I run the progressive output of the DVD players through a scaler for 1080i going into an HDTV. Even going straight SVHS to SVHS looks really poor at "extended" play speeds.
drjohnc is offline
post #3 of 4 Old 08-09-2003, 12:46 PM - Thread Starter
tedm's Avatar
thanks dr john for the good info. i'll keep that compatibility info in mind, and will let you know if i end up trying an EP 4 hr test disc on the 985.
on your other topic, I've had HDTV and progressive scan players for a few years, and although this will sound odd, a very good non-progressive scan, component output dvd player (e.g. panasaonic a-7), can look qualitatively better than the component outs of an early first gen progressive scan dvd player (e.g. toshiba 5109), IF the tv has a good line doubler.
Of course the 5109 had some now known issues, but you may want to try both outputs if your set's line doubling is exceptionally good.
tedm is offline
post #4 of 4 Old 08-09-2003, 07:28 PM
BeefStu's Avatar
Apparently not.
The thing I love most about deadlines is the wonderful WHOOSHing sound they make as they go past.
BeefStu is offline
Closed Thread DVD Recorders (Standard Def)
