Panasonic E80 owners please reply - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-08-2003, 05:46 AM - Thread Starter
HammerJoe's Avatar
Quoted: 98 Post(s)
For those that have this unit, can the HD be replaced with a bigger hard drive?
Can it be used on the computer as well???
HammerJoe is online now
post #2 of 7 Old 08-08-2003, 06:30 AM
Londo's Avatar
no and no
You know, I used to think it was awful that life was so unfair. Then I thought, wouldn't it be much worse if life were fair, and all the terrible things that happen to us come because we actually deserve them? So now I take great comfort in the general hostility and unfairness of the universe.
Londo is offline
post #3 of 7 Old 08-19-2003, 01:52 PM
Norman Chan's Avatar
Can we do 1 to 1 switch of the internal 80g harddisk ?
Norman Chan is offline
post #4 of 7 Old 08-19-2003, 02:26 PM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Yes. When you put in a virgin hard-drive, it'll ask you to format it. Anyway, that's what I recall from HS2 hard drive discussions some time back.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #5 of 7 Old 08-26-2003, 08:59 AM
PVerdieck's Avatar
Allright, lets get speculative.
How about if you have a friend with an E100. Remove his hard drive, put a new one in to get it formatted, then put it in your E80?
PVerdieck is offline
post #6 of 7 Old 08-26-2003, 09:49 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Your E80 will reformat it -- it'll then show & record only 80GB worth, not 120GB worth.
What we need is a new firmware that tells the E80 that a larger HDD is installed. But, we need a real techie who can extract the E80's firmware & modify it.
Brajesh is offline
post #7 of 7 Old 08-26-2003, 09:51 AM
PVerdieck's Avatar
Really? I would think it would recognize the file structure and think it didn't need to.
Closed Thread DVD Recorders (Standard Def)
