Dubbing from Pan E30 to E80 - AVS Forum | Home Theater Discussions And Reviews
Old 08-08-2003, 08:40 AM - Thread Starter
gigaguy's Avatar
Is it better picture quality to output a DVD-R from the E30 to record to DVD-R in the E80, OR, do it all in the E80, from DVD-R to the hard drive back to DVD-R. SInce I have both machines now, I have this option. Much of a difference in picture quality? I need to do more testing with DVD-Rams to see. I haven't even hooked up the E80 yet.
gigaguy is offline
Old 08-08-2003, 10:44 AM
potus's Avatar
I haven't tried it myself, but the E80 manual seems to indicate that dubbing from DVD-R to HDD is NOT allowed....
Claims you can only dub DVD-RAM to HDD. Of course you can dun HDD to either DVVD-RAM OR DVD.R...
There are other strange "one-time" limits that seem to apply in some cases. Probably due to copyright issues...
potus is offline
Old 08-08-2003, 10:54 AM - Thread Starter
gigaguy's Avatar
Oh, thanks. I did read that someone cabled the DVD-R playback out the output jacks back into the input jacks and then recorded it to the hard drive. I may try that. Should work, I guess.
I still have a lot of testing to do, but trying to cut some corners by seeing what others have tried already. Great toy tho!
gigaguy is offline
Old 08-08-2003, 12:11 PM
potus's Avatar
Yeah, that should work, but it's not a true lossless digital dub...
You may also end up with some menus and other UI graphics on the recording.
Best way to dub a DVD-R is probably on a computer with a DVD burner.
potus is offline
Old 08-09-2003, 03:43 PM
ernie6's Avatar
You can dub a DVD-R to the hard drive if you use another player or recorder. You can only dub from the E80 to its drive if you are dubbing from a RAM.
The only benefit to dubbing to the drive is if you were making multiple copies and wanted to use "high speed" to save time. I recently re-recorded several letterbox DVD-R's to DVD-R using the E80 to re-format them to 16x9. I used an S35 to play and re-format with excellent results. I was recording movies to 16x9 from DirecTV, such as Where Eagles Dare, Once Upon a time in the West and many others.
ernie6 is offline
Old 08-09-2003, 06:36 PM
VideoGrabber's Avatar
Quoted: 175 Post(s)
Liked: 109
ernie6:
> I recently re-recorded several letterbox DVD-R's to DVD-R using the E80 to re-format them to 16x9. <
Could you explain this is more detail? I don't think I understand exactly what you're doing. Thanks.
- Tim
VideoGrabber is offline
