Sony DRU-510a Slow Read Time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2003, 01:48 PM - Thread Starter
goolie's Avatar
Just bought the DRU-510a. It came with firmware 1.0a; first thing i did was to upgrade to firmware 1.0c.
DVD read speed is still very slow; took 45 minutes to read a Simpsons DVD with DVD Decrypter (which reported 2x speed). DVD X Copy was faster, about 33 minutes. The advertisted read time is 16x though. Any ideas on why it's so slow?
I've heard rumor that manufacturers "lock" the read speed to discourage ripping, is this true? If so, any way to unlock them?
"Time flies like the wind; fruit flies like bananas."
goolie is offline
post #2 of 4 Old 08-17-2003, 09:47 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Read time for movies are not going to be the same as the read time for a data DVD. You will not read a hour+ movie in just a matter of minutes, like it would a data DVD.
Not to mention the software time needed to do what those programs are doing, that you mentioned you are using.
The 16X read time spec, is for data DVD's not movies.
Johnla is offline
post #3 of 4 Old 08-17-2003, 11:24 PM - Thread Starter
goolie's Avatar
Thanks for the clarification, John.
goolie is offline
post #4 of 4 Old 08-20-2003, 01:58 PM
Gil T. Pleasure's Avatar
Originally posted at DVDplusRW.org forum
Sony released software called Drive Speed Selector (DSS). It allows you to choose from three settings for your DRU-510A (or DRX-510UL): Silent, Automatic, and Overdrive. Currently, DRU-510A owners are limited to 2x DVD ripping, but according to the PDF that comes with the software, overdrive mode allows for up to 8x ripping for dual-layered discs and 12x ripping for single-layered discs.
See this thread:
http://www.dvdplusrw.org/cgi/forum/i...=ST;f=6;t=8107
Body by Nautilus. Brains by Mattel.
Gil T. Pleasure is offline
Closed Thread DVD Recorders (Standard Def)
