Does This Happen To Your Player - AVS Forum | Home Theater Discussions And Reviews
Old 08-15-2003, 02:07 PM - Thread Starter
trader's Avatar
Wen you put in a disc a DVD and press play does your machine ever turn off. Mine has been doing this lately. If I clean the disc then it works. It seems like my player is more sensitive then it ever was. Is this normal?
trader is offline
Old 08-15-2003, 05:18 PM
vferrari's Avatar
First of all this is a DVD recorder forum. So if you are talking about a playback only deck you might have better luck posting in the DVD Hardware section.
Second, it would be helpful if described what model player or player/recorder you are having the problem with.
The Future ain't what it used to be...
vferrari is offline
