apex dvx-9000 trouble shooting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-16-2003, 07:42 PM - Thread Starter
PaulDeveau2003's Avatar
hi everyone, thanks for reading this.
Just bought the apex 9000 dvd r, works fine, but I can't seem to record from the timer, i set the time up and everything works fine untill its ready to record, then it tries to record and it gets a write error, but if i don't use the timer and just press the record button on the remote it works just fine.
part 2,
when I do record a show I get the record Icon on the upper left hand of the screen, it won't disappear, is the a way of making it disappear ?
thanks everyone, enjoy your weekend.
Paul
PaulDeveau2003 is offline
post #2 of 5 Old 08-17-2003, 03:20 PM - Thread Starter
bump
post #3 of 5 Old 08-19-2003, 06:35 PM
abbey641's Avatar
I got the same problem. Did you get anywhere with it? My email is abbey641@comcast.net. Let's try to help each other fix this bug.
abbey641 is offline
post #4 of 5 Old 08-20-2003, 11:25 AM
Gil T. Pleasure's Avatar
The record icon cannot be hidden while recording. Let's hope Apex fix this soon. As far as the timer problem is concerned, have you tried upgrading the firmware?
Download the latest firmware here:
http://www.apexdigitalinc.com/downlo...p?linenumber=3
Body by Nautilus. Brains by Mattel.
Gil T. Pleasure is offline
post #5 of 5 Old 08-20-2003, 04:35 PM
abbey641's Avatar
Yes, I updated the firmware. Doesn't fix it. I talked to Apex R&D today and they said I should try another brand of DVD+RW. Currently I use Memorex. I'm going to try Fuji. Apex is looking into it and they said they would let me know if they come up with something. They were very helpful (the R&D guy, not the technical toll free people).
abbey641 is offline
Closed Thread DVD Recorders (Standard Def)
