Help with Sat and Pan E50 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-18-2003, 01:41 PM - Thread Starter
rsingleton's Avatar
I have an RCA DirecTV box with two outputs (both are composite but 1 of them has S-Video). Previously, one output fed my TV directly while one fed my VCR. This worked fine.
I recently bought a Pana. E50 DVD recorder and replaced the VCR with it. So, the DSS is feeding the TV and the DVD. Big problem - the PQ via DSS to the DVD is crappy. Wavy lines, a color band, etc. Switching between the feed direct to the TV and the feed through the DVD is night and day.
The DVD to TV feed is S-Video and I was using composite from DSS to DVD, so I thought that might be the problem. I tried using the S-Video to the DVD (so the signal went S-Vid all the way), but the problem didn't get better. In fact, if I unplug the video feed and turn the input switch on the DVD to that input, I get junk on my TV (looks like interference - mostly a black screen with a band of color going through it).
If I remove the other out from the DSS and only feed the DVD, it works fine. Clear picture, nothing shows on screen with no signal, etc. But now I only have one output from the sat receiver.
As best I can tell, I'm getting some interference somewhere ... both outputs used to function fine before introducing the DVD player to the mix. Any idea what the problem is or how to fix it?
rsingleton is offline
post #2 of 2 Old 08-18-2003, 03:27 PM
JasonBrown's Avatar
I was getting crappy S-Video feeds to my E80 as well when I introduced an S-Video distribution box. The problem was fixed when I connected the "regular" video outs/inputs as well between the DTivo (satellite receiver box) and the inputs on the back of the E80. So I went from 2 audio and 1 s-video connect to 2-audio, 1 s-video and 1 regular (yellow cable) video connection. The picture comes thru in S-video, but there's no color band and the like associated with it.
My suggestion would be to connect BOTH the s-video and the normal video between the two boxes and see if that solves things. Despite the presence of the normal video connection, S-Video is being used. I can verify that.
JasonBrown is offline
Closed Thread DVD Recorders (Standard Def)
