Do DVD Burners play DVD movies as good as standalone players? - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2003, 12:59 AM - Thread Starter
Solidoos's Avatar
I'm new, and want to get a nice burner, I just need to know the basics thanks.:)
Solidoos is offline
Old 08-19-2003, 11:11 AM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
In my instance I do not think the burner plays back as well as a regular player. I have the DMR E80 panasonic which overall is great. But playing back DVD's whether commercial or recorded by me, always look better on my CP-72 - cousin to the RP-82. I have tried all the possible choices for playback but the E80 to my eyes does not quite match the playback of the CP-72. But, you would not by any means call it a bad picture - it is quite good actually. Just not quite the CP-72.
tampa8 is offline
Old 08-19-2003, 12:19 PM
Diode1's Avatar
Playback with a Philips DVDR-985 is one of the best I'v seen with its built in fl2200 Faroujdia chip set, has very stable output, Maybe implemented better then other comparable units containing the same chip set.
-Jerry
Diode1 is offline
Old 08-24-2003, 03:38 PM
Tenchi211's Avatar
If you're looking for best picture quality in the playback of DVDs, I think a stand alone player would be your best bet. But the convenience of having a recorder/player in one box is hard to ignore. My Sony RDR-GX7 recorder is a fine playback machine, but picture quality is a bit on the soft side when compared to my Sony NS999ES Player. Also ease of use is better with the player. But again, for what you get, you can't go wrong with a good DVD recorder.
Mike.
Tenchi211 is offline
Old 08-24-2003, 07:30 PM - Thread Starter
Solidoos's Avatar
Thanks man.
Solidoos is offline
