Difference Broadcast System ..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-19-2003, 01:43 PM - Thread Starter
Norman Chan's Avatar
What can done if my country is PAL system and my TV is Multi-system , if I buy an DMR-E80 on-line from the US , can the DMR-E80 internal tuner receive the PAL signal and do the job of recording ?
Is there any other solutions to overcome this problem ?
Norman Chan is offline
post #2 of 2 Old 08-20-2003, 12:33 PM
Gil T. Pleasure's Avatar
No, the E80's NTSC tuner will not be able to receive PAL signal without some kind of an external NTSC to PAL converter box.
Do a search on Google for one.
Body by Nautilus. Brains by Mattel.
Gil T. Pleasure is offline
Closed Thread DVD Recorders (Standard Def)
