Restore A Vro-file From A Hdd To Dvd-ram. But How ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-24-2003, 10:58 AM - Thread Starter
donkovski's Avatar
The following question:
At first i make a copy of a DVD-RAM. I put it in the DVD-ROM-Drive and copy the dvd_rtav-folder to the harddisk. After doing that, it's not possible to copy this folder back to the DVD-RAM, so that the HS2 could read.
HS2 only says, uncompatible data format or similar. Then it's necessary to format the DVD-RAM with the HS2 :-(
If i format the DVD-RAM in the HS2, no programm is able to import this session, so that i could copy only the vro-file to the DVD-RAM.
Any ideas how to solve that problem ?
Thx in advance
donkovski is offline
post #2 of 4 Old 08-25-2003, 07:47 AM
Ollie W. Holmes's Avatar
I believe you need to use Panasonic's supplied software (the stuff that comes with the LF-D321 or SW-9571 drives) to copy from the dvd-ram to your PC's hard disk drive. Explorer is not recommended (nor does it work in earlier incarnations). Then you need to format a new dvd-ram blank to udf 2.0. The same Panasonic software that did the original dvd-ram to hdd copying is used to copy back the files on your PC hdd to the (new) dvd-ram blank.
Ollie W. Holmes is offline
post #3 of 4 Old 08-26-2003, 12:48 PM
videojanitor's Avatar
Hmmm, I've done this many times without any problems. Here's how I do it:
1. Open "My Computer," Open DVD-RAM drive, select DVD_RTAV folder.
2. Copy that folder to my hard drive.
3. To restore it to DVD-RAM, I first open the DVD-RAM in question and DELETE the DVD_RTAV folder. Why? I don't know -- just seems like a good thing to do. Then I copy the DVD_RTAV folder to the DVD-RAM from the hard drive.
That method has worked 100% reliably for me. I'm using Windows XP -- maybe if you're using a different OS, that might have something to do with it (but I wouldn't think so) ...
--Bill R.
videojanitor is offline
post #4 of 4 Old 08-27-2003, 09:20 AM
hroeder's Avatar
I've done the same thing Bill. A bit slow, but it works.
"Wouldn't you gladly resign from the human race if there was another one to belong to?"
Arthur Miller
hroeder is offline
Closed Thread DVD Recorders (Standard Def)
