Chk Remote Error on HS2??? Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-27-2003, 04:41 PM - Thread Starter
acidsex's Avatar
Tonight I was gonna copy some video to dvd-ram and when I tried to naviagte with the remote, the display on the HS2 says to Chk Remote. I changed the batteries and it didnt fix it.
Has anyone gotten this error before and if so, how do I fix it?
acidsex is offline
post #2 of 7 Old 08-27-2003, 06:24 PM
tampa8's Avatar
Quoted: 225 Post(s)
Liked: 153
That is the code you get when you are using a panasonic remote but the remote is programmed to a different code than the dvd player. Are you mistakenly using a remote from another panasonic unit? If not, it is possible some how the remote code got changed on the remote or the unit. just get them back on the same code. (I.E. code 1, or 2 etc..)
tampa8 is offline
post #3 of 7 Old 08-27-2003, 07:08 PM - Thread Starter
acidsex's Avatar
i dont recall ever changing the factory setting. how can i change the remote back to the shipped factory settigns for the remote?
acidsex is offline
post #4 of 7 Old 08-28-2003, 01:48 PM - Thread Starter
acidsex's Avatar
anyone else have an idea?
acidsex is offline
post #5 of 7 Old 08-28-2003, 03:28 PM
dgb
dgb's Avatar
It sounds like a remote code mismatch. If the display is "1 CHK REMOTE", then it's the remote which has changed rather than the recorder.
The remote code is set by holding either 1, 2, or 3 and pressing ENTER while holding down the number. It may be that this happened by accident.
To fix it, just see which number is displayed before the CHK REMOTE, hold down that number on the remote and press enter.
David
dgb is offline
post #6 of 7 Old 08-28-2003, 04:48 PM
vferrari's Avatar
Its all spelled out in the manual as well.
The Future ain't what it used to be...
vferrari is offline
post #7 of 7 Old 08-30-2003, 06:46 PM
Ollie W. Holmes's Avatar
Actually, you can test whether it is a remote code problem by seeing if the remote will turn on the unit. If the front display brightens and then dims, you have the wrong code. (My HS2 has auto dimming turned on).
Someone could also have programmed the HS2 to respond to code 2, i.e., your remote may still be putting out code 1 requests, but your HS2 filters on code 2. My RP-91 runs on code 1 and the HS2 runs on code 2. Thank goodness for this feature.
Ollie W. Holmes is offline
Closed Thread DVD Recorders (Standard Def)
