Panasonic E80 and mono signal from camcorder - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2003, 07:46 PM - Thread Starter
Gene H's Avatar
I'm transfering some 8mm video to DVD and it has only 1 channel of audio. How do I get the Panny E80 to record a mono signal? Or do I need to get a Y-splitter and connect the mono signal to the L and R jacks?
Gene H is offline
Old 09-03-2003, 08:25 PM
JeffWld's Avatar
Use the front-panel inputs (L2) and connect the mono audio to the left channel. The mono audio is automatically distributed to both left and right channel.
JeffWld is offline
