College FB Fans!-Record on E-80 XP!!!- HDD-HI-SPEED - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-03-2003, 11:51 PM - Thread Starter
HoustonGuy's Avatar
I recorded the Tennessee/Fresno State game this weekend on HDD at XP. It was on regular network -not digital. I burned to three discs from the HDD at 54,56,26 approx minutes after deleting commercials. I also did it two discs-1.25 each on FR. The 3 XP discs hi speed dub looked better- no question- there was a difference in PQ- I promise you. It was better. My point is - there is no substitute for XP HDD original and eventual 60 minute hi speed dubbing to a single disc for the best quality.
The Lab called: Your Brain is ready.
HoustonGuy is offline
post #2 of 6 Old 09-04-2003, 08:52 AM
gigaguy's Avatar
I still prefer not to have more than one disc for most programs I keep, (mostly movies,not any sports). 2 disks is workable for me, but 3 is not as convenient.
Were you satisfied with the quality of the 2 FR disks as an archive or would you still go to all XP for this kind of sports program?
gigaguy is offline
post #3 of 6 Old 09-04-2003, 10:21 AM
Scott M's Avatar
Quoted: 126 Post(s)
Liked: 89
A more fair comparison would be to record the same source on two machines -- one in XP and one in SP -- and then do a high-speed dub of both. That way, you are not introducing a re-encode variable into the mix on the FR dub of the original XP recording. Instead, you would be actually comparing XP vs. SP.
Scott M is offline
post #4 of 6 Old 09-04-2003, 03:45 PM
hmcewin's Avatar
Quoted: 24 Post(s)
Houston Guy.
Off topic, but I am eager to see how your comparison test between an SVHS machine and the Panny went.
hmcewin is offline
post #5 of 6 Old 09-04-2003, 05:36 PM - Thread Starter
HoustonGuy's Avatar
Yes the 2 disks on FR were very good and definitely keepers. I will have the s-vhs, E-80, Philips 985 comparison up this weekend.
post #6 of 6 Old 09-04-2003, 05:49 PM - Thread Starter
HoustonGuy's Avatar
Scott- I will try that.
Closed Thread DVD Recorders (Standard Def)
