Mxlrg01 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-07-2003, 05:42 PM - Thread Starter
dv13's Avatar
Hi, got my maxell dvd-r media today. they are green on top and purple on bottom.
I ran one of the progs i found here and the manufacturers id is MXLRG01
Can anyone confirm whether by this code if these are indeed genuine maxell brand disks or a counterfeit? thanks..t
dv13 is offline
post #2 of 3 Old 09-07-2003, 07:32 PM
JeffWld's Avatar
If they are branded they should be legit. To my knowledge, Maxell doesn't sell bulk/spindled media.
The code isn't a good indicator since the fake Maxells also had that code. Where did you buy them?
JeffWld is offline
post #3 of 3 Old 09-07-2003, 09:50 PM
xortam's Avatar
The code is right and the media color is right so chances are that they're legit. Mine have a horizontal label that says "maxell" on the upper left and DR47 on the bottom right.
"Plasma TV ... so called because in order to afford one, you're going to have to sell your blood." -- Ed Helms, The Daily Show.
xortam is offline
Closed Thread DVD Recorders (Standard Def)
