DMR-E80 recording in 16:9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-08-2003, 08:49 PM - Thread Starter
king_lemmiwinks's Avatar
The DMR-E80 manual indicates that if you record a 16:9 broadcast to DVD-R it will be truncated to the 4:3 ratio. Can one record to the hard drive in the 16:9 ratio then dub it to a DVD-R mantaining the 16:9 ratio?
king_lemmiwinks is offline
post #2 of 4 Old 09-09-2003, 07:10 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
That bit in the manual had me going "huh?!" too.
As far as I can tell, if you record a 16:9 source, the E80 will flag it as 4:3 like it does every recording. When you play it back though, it'll look fine on a 16:9 display.
I record 16:9 programs from my Zenith 520 HD STB all the time & my DVD-Rs all retain their 16:9 enhancement (even if the E80 flagged them as 4:3 when I recorded them).
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #3 of 4 Old 09-09-2003, 07:22 AM
Scott M's Avatar
However, if you play the same disc back on a 4x3 display, wouldn't everyone look tall and skinny? There would be no 16x9 flag to invoke the player's anamorphic downconversion.
Scott M is offline
post #4 of 4 Old 09-09-2003, 09:40 AM
grizbear's Avatar
1. 16x9 recordings to DVD-Ram will display correctly on both 4x3 & 16x9 sets.
2. 16x9 dubs to DVD-R are recorded as 4x3 but will display correctly on 16x9 displays--you will probably have to force it.
3. 16x9 dubs to DVD-R will not display correctly on a Std 4x3 display. You can however, take a 16x9 DVD-RAM disc to your computer, modify the flag settings and then dub this to a DVD-R on the on computer drive. Players will read this as a true anamorphic disc. There are several schemes to do this, try a search on this forum.
grizbear is offline
Closed Thread DVD Recorders (Standard Def)
