Best/Worst Blank DVD-R's for Panasonic E100 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 37 Old 01-09-2004, 09:02 AM - Thread Starter
reades's Avatar
Two Questions:
1.) What blank DVD-R discs work best/worst with the Panasonic E100?
2.) I guess to take advantage of the 4X dubbing, I need to buy 4X DVD's, right? What ones seem to be best?
Thanks for the help!
reades is offline
post #2 of 37 Old 01-09-2004, 12:27 PM
videonut's Avatar
You can find all the answers at meritline.com, and they have a great return policy.
The Ritek or BeAll 4X media will probably work for you.
Good Luck!
Peter M
videonut is offline
post #3 of 37 Old 01-09-2004, 12:38 PM - Thread Starter
reades's Avatar
Peter,
Thanks, but they don't specifically address the E100, and I've read on these forums that the E80 and E100 react differently to media. Also, they don't list any 4x Discs for the Panasonics (since they don't show the E100).
reades is offline
post #4 of 37 Old 01-09-2004, 01:06 PM
RichardT's Avatar
Location: Clarkston, Washington (State), Southeast corner
Give this thread a thorough scouring and you'll find all kinds of answers.
Hate to dump water on someone else's parade, but Ritek 4x doesn't do well on my E100 (had it almost a month). 2 successes, 3 failures.
Verbatim 4x has worked well- so far.
RichardT is offline
post #5 of 37 Old 01-09-2004, 01:11 PM - Thread Starter
reades's Avatar
which thread is that?
reades is offline
post #6 of 37 Old 01-09-2004, 01:41 PM
videonut's Avatar
It's true that you will find many varying opinions regarding DVD media on this Forum. For some reason compatibility varies by machine, not so much by the model. This is why I'd suggested Meritline. They offer a very liberal return policy and also have special assorted packages so you can see which media will work for you.
Personally, I have a 99% success rate with BeAll discs (burned over seven hundred to date).
Good Luck,
Peter M
videonut is offline
post #7 of 37 Old 01-09-2004, 03:52 PM
goony's Avatar
Burned in what device(s)?
goony is offline
post #8 of 37 Old 01-09-2004, 04:16 PM
Londo's Avatar
For me w/Beall 4x printable.... E20, E80, Pioneer A06, Panasonic LF-D521 and LF-D321 99.9% good (only screwups are mine....)
You know, I used to think it was awful that life was so unfair. Then I thought, wouldn't it be much worse if life were fair, and all the terrible things that happen to us come because we actually deserve them? So now I take great comfort in the general hostility and unfairness of the universe.
Londo is offline
post #9 of 37 Old 01-09-2004, 06:19 PM
rondi's Avatar
Quoted: 37 Post(s)
Liked: 36
i don't know how many times i have posted this--- but here is another $.02!! :)
I have an E100 bot in Nov. i have tied Memorex X4 from Staples and half of the those were coasters. i returned the spindle and got a full refund. I ordered from Meritline.com a spindle of Ritek X4 and have had NO coasters.
I have a feeling it depends which burner is in the unit. some with E100's swear by Memorex X4 and others make coasters with Ritek's. go figure. it probably has to do with "when" the E100 is made.
do a search for rondi, and you'll see the pennies i threw into the discussion pot.
rondi is offline
post #10 of 37 Old 01-10-2004, 03:53 PM
lenfl's Avatar
I received my E100 in late Nov. and bought a spindle of 50 Memorex 4x. 48 dubbed at high speed (15 min for 2 hr) were fine, one would dub only at 1 x and 1 would not play in my mitsu player. FINE, GREAT, so I bought another spindle of the same thing at the same place two weeks later and THE FIRST FIVE WERE FAILURES. Go figure, same machine, same brand etc. Anyone have any ideas?
lenfl is offline
post #11 of 37 Old 01-10-2004, 04:04 PM
randall's Avatar
Fuji 1x DVD-Rs (yes, from Taiwan) burned on my E100 since September without a single failure (knock on wood). I've had no reason to try another product.
randall is offline
post #12 of 37 Old 01-10-2004, 09:28 PM
spiderman2k1's Avatar
I do not own the Panasonic DMR-E100HS but I have the E80H I got it last week and I have burned Kypermedia cheep media there the same as Memorex they come from the same place. I burner it fine. Other People are having problem. If I was going to buy a Panasonic recorder get one from www.6ave.com they have the lowest price's and they move them fast. So they must have the newest one's that Japan just made.
spiderman2k1 is offline
post #13 of 37 Old 01-10-2004, 10:38 PM
John Alan's Avatar
UPDATED: 02-06-04: Went to BB and bought 100 TDK 2X DVD-R for $99. Only after burning a couple did I realize that my E100 will burn at 1X or 4X but not 2X!!! So, it takes nearly an hour to do a "high-speed" dub of a movie. The good news is success and compatibility are 100%. Next month I want to get a spindle of Ritek 4X and burn a bunch. If this thread is still around I'll update it...or maybe just start another.
Here's my experience so far on my E100: (the number is parenthesis are the aprox number of discs burned)
For 4X DVD-Rs on my E100 the success rankings would be something like:
1. Ritek (silver top) 100%
2. BeAll (white top - printable) 90%+***
3. Sony (silver top) 85% (many burned)
4. Memorex (silver, embossed top) 90% (only burned a few)
4. Leda (white top) 15%
1X and 2X discs all burn at 1X only! But all the following are 100%:
TDK
Verbatim
Panasonic
Maxell
Specific results:
DVD-R:
TDK 2X - 100% success (10)
Verbatim 1X, 2X - 100% success (5) - haven't tried 4X
Panasonic 2X - 100% success (3)
Sony 4X - 85%+ success (45)
Leda 4X - 15% success (20)
BeAll 4X - 90% success (30)***
Ritek / Ridata 4X - 100% success (5)
Maxell 2X - 100% success (5)
Memorex 4X - 100% success (2)***
***=Here's the deal on the BeAlls and now Memorex. Only one BeAll failed to finalize properly. However, I have a very picky (cheap) Apex machine that will play MOST discs I burn. However, I've had a majority BeAlls and Memores that only produce "disc error" in that machine and will not play. But, those same discs play fine in the E100 and a couple of Panny S35's I have. So, only a 'conditional' failure on a fair percentage of BeAlls. Maybe they don't have quite the compatility of say the Riteks. I think my next purchase will be a spindle of Riteks. That's the latest!
RAM:
Panasonic - 100% success (5)
Maxell - 100% success (15)
I have never had a failure on 1X or 2X media. 4X seems to be a bit more problematic. But, it is a drag dubbing to a 1X disc. Takes way too long, even doing high-speed dubs...gotta move on! All 2X discs burn at 1X speed on an E100.
I, too, would like to hear from other E100 owners and hear their experiences with DVD-R disc. Please be sure to specify the SPEED of the disc with your info.
As I burn more I will continue to update this post.
Right now, at least for me, BeAll 4X - White top and Sony 4X are acceptable and Ritek 4X Silver top may be the best of the "inexpensive discs".quite
John Alan is offline
post #14 of 37 Old 01-11-2004, 03:43 PM
lenfl's Avatar
Question? does your e100 burn 2x disks at 1x or 2x or 4x speed
lenfl is offline
post #15 of 37 Old 01-11-2004, 04:24 PM
John Alan's Avatar
My E100 has always burns a disc - or attempts to - at the discs rated speed. It has never tried to burn a 4X at 2X or 1X. It tries 4X and it either works or fails. 2X is burned at 2X, 1X at 1X.
I updated my post above after burning some Riteks (perfect so far!!!) and a couple more Ledas (both failed finalization, sigh). I will continue to update that post as long as this thread is active.
Would like to hear detailed results from other E100 owners as well.
post #16 of 37 Old 01-11-2004, 08:54 PM - Thread Starter
reades's Avatar
Well, I need to go smoke a cigarette. I just lost my virginity on the E100 by doing a high-speed (4x) dub using a Maxell DVD-R. Everything finalized perfectly. I'll let you know how the rest of the dubs go.
Thanks for all the info so far. It has really helped.
reades is offline
post #17 of 37 Old 01-12-2004, 06:19 AM
luck's Avatar
Just ordered a sample kit of 11 different brands:
BeAll, Ritek, Maxell, Memorex, TDK, Verbatim, Sansung, Sony, Panasonic, Accu, Fuji.
I'll post results as soon as I receive and burn them.
Luck
luck is offline
post #18 of 37 Old 01-12-2004, 02:43 PM
rondi's Avatar
Quoted: 37 Post(s)
Liked: 36
i burned 4 more Ritek G04's yesterday and all burned + Finalization fine.
I think this has been discussed before---but some batches of DVD's are made by different companies. maybe that's why some brands work fine for a spindle and then the next spindle is bad.
I have an E100, and i don't know how to adjust the recording (burn) speed. i think it does it automatically--depending what speed of DVD you have.
I also think today--maybe not tomorrow--X4 is state of the art. Maybe when X6 or X8 DVD's come out, the reliability of burning them at X4 will improve. I think every poster here at one time or another has mentioned he has made coasters.
rondi is offline
post #19 of 37 Old 01-12-2004, 08:00 PM
John Alan's Avatar
luck, good luck. Unfortunately, only burning one disc of any brand doesn't tell the story.
I would say you have to attempt at least 5 to 10 burns of a brand before coming to any accurate conclusions. I've had about 85% success with Sony 4X but, if I only had one and it didn't burn right you might be inclined to cross them off the list!
On the other hand, with my E100, I've had rotten luck with Leda 4X. But, if I'd had a good burn from one, I might think they work fine. So, be careful with your conclusions. Try to get a few more of each burned before deciding what works well for you and what doesn't.
Having said that, please let us know your experiences with these discs!
post #20 of 37 Old 01-13-2004, 05:47 AM
luck's Avatar
Bingo!!! I bought 5 of each!!!!!:D
I think 5 burns of each would be a good start, right?
I'll post the results...
Luck
luck is offline
post #21 of 37 Old 01-13-2004, 07:34 PM
John Alan's Avatar
luck, EXCELLENT.
5 will give you a good idea of what you're dealing with.
I look forward to your report!
ja
post #22 of 37 Old 01-14-2004, 07:30 AM - Thread Starter
reades's Avatar
FYI - I've been burning to Panasonic 2X DVD-R's and Maxell 4X DVD-R's virtually non-stop for days without one glitch (knocks 3 times on his head) :-)
Anyone know of a place to get the Maxell 4X's for a good price?
reades is offline
post #23 of 37 Old 01-14-2004, 03:52 PM
stevorino's Avatar
Does anyone think that there is anything wrong with using cheapo 1x media. I'm using compUSA disks. 20 bucks for 25 dvd-r's. Maybe a total of 2 coasters after about 30 burns. I more concerned if there is any difference in the quality of the recording between media brands rather than potential for coaster making.
How about the life of cheapo 1x media? Anyone dare to comment :)
May your DVDs last your lifetime
stevorino is offline
post #24 of 37 Old 01-14-2004, 06:57 PM
John Alan's Avatar
1X is fine. But, I won't live to be 300 years old and once you've burned 4X for a while, 1X is torture, 2X is merely painful.
I'm looking forward to 64X!
post #25 of 37 Old 01-14-2004, 07:49 PM
stevorino's Avatar
I probably shouldn't worry about the life span, huh? Chances are I'll be on the next forum to discuss how to transfer my DVD-r's to the next peice of technology that comes along and renders our dvd recorders obsolete :p
post #26 of 37 Old 01-14-2004, 09:36 PM
John Alan's Avatar
Not to worry. Technology is racing forward...faster than a speeding budget!
hehehe
post #27 of 37 Old 01-21-2004, 10:19 PM
John Alan's Avatar
I have updated my success post above and brought this back to the top of the threads list hoping to hear from "luck" and some others as to their success with the E100. I've burned several BeAlls and Riteks now all without a single failure!
I had rotten luck with Ledas, but I sent a few to a friend and they have worked flawlessly on his machine...???
The quest continues. What are your experiences with 4X media on the E100?
post #28 of 37 Old 01-22-2004, 06:47 AM - Thread Starter
reades's Avatar
John, Thanks for the update.
I've had 100% success with Maxell 4X's (several 5-packs in jewel cases), and Panasonic 2X's.
reades is offline
post #29 of 37 Old 01-22-2004, 09:12 AM
luck's Avatar
John,
thanks for sharing your "experiences" with us.
I'm still finishing my HT room and its 12.375.982 cables and wires.:D
Let you know as soon as I start to burn the medias.
Luck
luck is offline
post #30 of 37 Old 01-22-2004, 09:36 AM
RAVEN56706's Avatar
got a question? does hig speed 4x only can handle 1 hour ot material?
2011 SUPERBOWL CHAMPIONS- New York Giants!!!
Gamertag: GENERAL CUPKAKE
RAVEN56706 is offline
Closed Thread DVD Recorders (Standard Def)
