Picture overscan on Panny DMR-E55? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-01-2005, 07:47 AM - Thread Starter
herrfish1's Avatar
Need help guys! I just got a Panasonic DMR-E55 DVD recorder. It is running out of a Hughes HTL-HD Directv receiver and into a Sony KP-WT500 RPTV. I love everything except for the fact that when I record something on the DVD recorder and play it back on the tv, the picture appears to overscan (i.e. cut-off at the top and bottom--the picture is bigger than the screen). It's not a great problem, but it is noticeable. The DVD recorder picture settings are: 16 x 9, 480p, which should be right for my tv. Has anybody else noticed anything similar or does anybody have any idea what is causing this problem? Thanks for any help!
herrfish1 is offline
post #2 of 2 Old 01-14-2005, 06:36 AM - Thread Starter
herrfish1's Avatar
Just in case anyone else has this problem with the Panny E55, a Sony RPTV, and a Hughes HTL-HD D* receiver...you must set the wide mode in the tv to "FULL"--not normal or wide zoom or zoom..then everything works fine!!!
Closed Thread DVD Recorders (Standard Def)
