Concerns over what media speed to use - AVS Forum
post #1 of 7 Old 01-14-2005, 09:43 PM - Thread Starter
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
I need some good advice as to whether or not it is OK to use 8X speed discs with my Panasonic DMR-E100. Specifically Sony or TDK brand. I have read various threads on this subject and I am confused. Is there a reliability issue with 8X vs. 4X speed media and if so, what should I expect?
Any comments from users of this recorder and 8X media with it (or the Pana DMR-E80, since it is basically the same generation unit) would be much appreciated!
THANKS ALOT!!:)
slprp1 is offline
post #2 of 7 Old 01-14-2005, 10:24 PM
DaveC E100's Avatar
I have the E100 and I just bought a 50-pack of Fuji 1X-8X and two 50-packs of Sony 1X-8X DVD-R's. Unfortunately I can't give you any first hand experiences because I haven't opened the packages yet. Obviously I am not expecting any problems or I wouldn't have bought them. I know they won't burn faster than the 4X my E100 is capable of, but I see no reason that they should work any different than the 4X DVD-R's that I have been using? Maybe I am in for a rude awakening but I don't think so?
Dave
DaveC E100 is offline
post #3 of 7 Old 01-15-2005, 12:06 AM
Doug O's Avatar
Maxell 8X "Made In Japan" work fine in my E80H. Since the E100 uses a different burner, I can't tell you for sure.
Doug O is offline
post #4 of 7 Old 01-15-2005, 06:55 AM
JMas's Avatar
I am stocking up on 4X while it is still available. I have had playback problems with both TDK and Maxell (Japan) 8X, occasionally on my E80 and more often on my older HS2. 4X has played fine in both.
John
JMas is offline
post #5 of 7 Old 01-17-2005, 06:02 AM
dons459's Avatar
My Pioneer dvr 310 will only use 2x on -rw and havent tried any faster then 4x on -r
i bought 25 4x -rw and it keeps spitting them out.
dons459 is offline
post #6 of 7 Old 01-17-2005, 03:39 PM
John Alan's Avatar
I have burned several Maxell 8X in my E80 with zero problems. I can't tell you about my E100 because it is still in the shop <sigh>. However, Maxell 4X was one of the most reliable discs in that machine. So, I have to think the 8X shouldn't be a problem.
Let us know of your experience.
John Alan is offline
post #7 of 7 Old 01-17-2005, 06:46 PM
SteveK2's Avatar
THANKS ALOT!!:)
In my E100, I've used Fuji 8x media (Made in Japan with scalloped cake box) with 100% success. No problems with burning, high-speed dubbing or playback. These are TY02 disks -- I have purposely stayed away from the made in Taiwan variant of the Fuji 8x media.
BTW...these are on-sale in BB this week for $19.99/50.
SteveK2 is offline
Closed Thread DVD Recorders (Standard Def)
User Tag List
