SIMA CT-2 or the SIMA CT-200: Which is better? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 189 Old 09-01-2007, 02:08 PM
Rammitinski's Avatar
Originally Posted by westgate View Post
on my ct2s, there is a 'dark' position on the side, w/ the lighter, b/w, and just plain enhance, which doesn seem to do much. the 'dark' position only darkens the image, not make blacks blacker. i dont use it, just 'enhance'. ive never used a ct200. i hope to hear something about it.
I wasn't sure just what those adjustments were for. I just got a ct200, but I still have it sitting in the bag and haven't had a chance to try it yet. I better get to it soon to make sure it works.
I'm almost tempted to just return it and get the ATX500 instead, if it really has updated firmware. In fact, I just may do that.
Rammitinski is offline
post #182 of 189 Old 09-01-2007, 05:40 PM
crabboy's Avatar
Quoted: 73 Post(s)
Liked: 67
You'd be better off to keep the Sima and buy the ATX500. The ATX is an unknown quantity; the Sima could bring some bucks on ebay. I have the CT200. It is a very good unit for copying old VHS tapes. I've heard it does other things well also.
Indirectly Outta Compton
crabboy is offline
post #183 of 189 Old 09-01-2007, 11:36 PM
Originally Posted by crabboy View Post
..the Sima could bring some bucks on ebay.
Yeah, that's what I was thinking - maybe use it awhile and then see what it'll fetch.
Either that or I'll just give it to a good friend of mine who copies and collects old movies and serials, (like the two-reelers they showed in the theaters many moons ago). It could probably improve the looks of some of that old stuff, with the faded prints and the spotty lighting.
The stuff he has is all on VHS (it was copied with an old, Go-Video dual deck), and I bug him occasionally about getting a DVD recorder. Maybe if I give him the Sima he'll be more motivated to finally get one.
post #184 of 189 Old 02-28-2008, 08:41 AM
chrissy126's Avatar
Hello,
Does anyone know if you can use the sima 200 to copy from 2 separate dvd/vcr combos. I have one combo unit with just a dvd player and another combo unit with a dvd recorder combo. Does anyone know if I can use the sima 200 to copy from dvd combo unit 1 (player) to dvd combo unit 2(recorder) without the copyright problem popping up? Thanks!
chrissy126 is offline
post #185 of 189 Old 02-28-2008, 10:51 AM - Thread Starter
STEELERSRULE's Avatar
Quoted: 65 Post(s)
Liked: 26
Originally Posted by chrissy126 View Post
Hello,
ABSOLUTELY!
That is what it is meant for.
Just connect the S-video out of the player(this is for DVD's mainly, but some players support output of the VCR side of dual decks. Some do not, and you would be forced to use the composite[yellow cord] out from the player) to the S-Video in on the SIMA.
Then connect the S-Video out of the SIMA to one of the S-Video in's on the recorder.
The Red and white audio cords are connected directly from the player(Audio out) to the recorder(Audio in), then go ahead and dub.
STEELERSRULE is offline
post #186 of 189 Old 02-28-2008, 02:08 PM
chrissy126's Avatar
Thank you, I thought I could. I was reading some of the other posts on here and I thought I read somewhere that the sima always didnt work getting through the copy guard on combo units. Maybe they meant if you were using the same combo machine to copy and record on which I am well aware that you can't do that. I can't wait to get my sima in the mail to try out copying dvds on my 2 combo units now. Thanks for the help!
post #187 of 189 Old 02-28-2008, 02:14 PM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
Panny DVDR's w/vhs will allow you to play from one side, route the signal through the Sima, and then back into the other device. Not sure how many other DVDR combo's do that though. Plus if you want to go DVD to DVD you will need another DVD to do the playing on since I've never seen a double DVD unit like they used to have in the day of double VHS units.
jjeff is offline
post #188 of 189 Old 02-28-2008, 02:22 PM
Quoted: 38 Post(s)
Liked: 197
The Pio 53x/63x/640 can record from one drive to the other thru its external line input/outputs. Haven't heard of anyone placing a Sima or other device in that loop, but it'd be an interesting test.
7558037 is offline
post #189 of 189 Old 02-28-2008, 02:46 PM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
I'd guess it would work. Seems Panny and Pio seem to share similar features. I've done it a few times with my ES-30 but really don't use the VHS much in the loop anymore.
jjeff is offline
