Is RG6 coaxial cable much better than RG59? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-10-2006, 06:10 AM - Thread Starter
actorBrad's Avatar
Quick question ... For connecting analog cable from the wall to the DVD Recorder (Panasonic ES20) - Would it make any noticeable difference to use an RG6 coaxial cable instead of the standard RG59?
actorBrad is offline
post #2 of 17 Old 02-10-2006, 06:14 AM
Joe_M's Avatar
Only if the cable was really long. Assuming the RG59 cable is of good quality, it's fine.
There is no "best", best is what's best for you...
Have you tried searching first?
Joe_M is offline
post #3 of 17 Old 02-10-2006, 09:20 AM
Oldemanphil's Avatar
Quick answer..yes. RG6 is usually required for digital cable and DSL.
Oldemanphil is offline
post #4 of 17 Old 02-10-2006, 10:04 AM
martin1's Avatar
She talking about analog cable not digital. From wall to ES20 RG59 is just find. The coax connector on the cable is the most important on short runs.
BJM
martin1 is offline
post #5 of 17 Old 02-10-2006, 12:53 PM
Kelson's Avatar
Quoted: 1951 Post(s)
Liked: 1146
Isn't the difference between RG6 and RG59 just thickness of the cable?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #6 of 17 Old 02-10-2006, 01:57 PM
hitechluddite's Avatar
RG-6 is lower loss and better sheilded but for a run of less than 10' the quality of the termination will have more effect in determining the total loss of the run.
hitechluddite is offline
post #7 of 17 Old 02-10-2006, 04:19 PM
Fuzzybear50's Avatar
The difference between RG6 and RG59 is the shielding.
I would use RG6 Quad Shielded cable.
Beer is the answer! What is the question?
Fuzzybear50 is offline
post #8 of 17 Old 02-10-2006, 04:36 PM
Targus's Avatar
and the diameter, attenuation, lower frequency limit, materials used, capacitance, loop resistance...
Targus is offline
post #9 of 17 Old 02-12-2006, 03:34 AM
nameless33's Avatar
I like to use the same stuff the cable company wired the rest of the house with.
nameless33 is offline
post #10 of 17 Old 02-13-2006, 10:53 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
For your specific application, NO there will be no difference at all. RG6 is required for the higher frequencies of satellite signals and digital cable, but for analog cable RG59 is fine. As has been said, RG6 is better overall, with less attenuation and higher frequency rating, but for analog cable, that won't be an issue.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #11 of 17 Old 02-14-2006, 07:19 AM
cssnms's Avatar
Newbi question: :
I bought my home 3 yrs ago. My house is 15 yrs old and at some point after it was built it was wired for cable. I recently signed up for digital cable as well as HD through Comcast, but I am unsure if at the time my house was wired they used RG6. I want to be sure that I am maximizing the digital signal. My HD pic on my Elite Plasma is great, but I am not sure if it is as good as it can get.
Is there anyway to tell if it is RG6?
cssnms is offline
post #12 of 17 Old 02-14-2006, 09:37 AM
Quoted: 111 Post(s)
Liked: 86
Well, the cable type is stamped on the wire itself every few feet, so you can take a wall plate off and pull out what slack is there and if you're lucky, it will be printed on the cable. Other than that, I guess a quick trip to the attic is all I can think of, unless, of course, you have access to an RF signal generator and a spectrum analyzer to see where the frequencies roll off on the high end.
Luke
post #13 of 17 Old 02-14-2006, 01:12 PM
bobkart's Avatar
Once you are getting the signal without errors (pixelation, freezing), that's as good as the picture will get. You can improve the reception and reduce the frequency of such errors, but those errors are the only way it can go wrong, it's not like analog cable where the picture can have all sorts of subtle inaccuracies, digital reception is either all there or it's not, and it's usually obvious when it's not. Once all the bits are succesfully being received, that's the best picture you'll see.
bobkart is offline
post #14 of 17 Old 02-14-2006, 03:45 PM
Quoted: 111 Post(s)
Liked: 86
bobkart is correct. If you are not seeing any digital artifacts like stuttering of the picture or excessive pixelation, then you are getting as good a digital signal as your receiver can use. Signal strength beyond the "successful read threshold" just doesn't matter to a digital receiver.
Luke
post #15 of 17 Old 02-14-2006, 08:22 PM
CruelInventions's Avatar
Quoted: 459 Post(s)
Liked: 593
I've actually got about 100 ft. of brand new, dual RG6 cable with attached grounding wire, which was thrown out by the satellite or dish install guys after finishing up a building job. Too lazy to carry the leftover cable, I suppose.. what a waste. I couldn't let perfectly cable go to waste, so I grabbed it. It's still sitting in my storage closet, as I have no use for it, so I'll end up selling it on Ebay or something. *hopes to, anyway*
CruelInventions is offline
post #16 of 17 Old 02-15-2006, 08:51 PM
cssnms's Avatar
Thanks for the info... I guess the question is answered. The pic looks great, no problems with freezing etc, so I will leave the cable alone.
Thanks again
cssnms is offline
post #17 of 17 Old 02-16-2006, 01:44 AM
plumeria's Avatar
and...
I thought you were about to say that you would be donating your 100ft of RG6 it to some needy AVS Forum members, instead of touting your future flea-bay sale ;(
peter
plumeria is offline
Closed Thread DVD Recorders (Standard Def)
