Just picked up a new Panny DMR-ES15 at BB! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 280 Old 09-23-2007, 12:29 AM
ethuff@SBCGLOBAL's Avatar
I just bought a new one in a sealed box at my Kokomo, IN Best Buy for $19.99! It was sitting with the new 17's and I had an employee price check it. He said they must have forgot about it. My local Wal-Mart Supercenter also had them on clearance for $90.00.
ethuff@SBCGLOBAL is offline
post #272 of 280 Old 09-24-2007, 09:40 PM
westgate's Avatar
$19.99, WOW!!
westgate is offline
post #273 of 280 Old 09-25-2007, 02:14 PM
avdude168's Avatar
I bought a open box yesterday without the remote control. just wondering if the any hd receiver from cable will work with this
avdude168 is offline
post #274 of 280 Old 09-25-2007, 02:42 PM
Barjo4's Avatar
Hi AVdude,
The one I bought is patched into the HD dvr from Comcast and it works alright. ( I am not using a HD televison, however) I had to buy a remote and I found a Panasonic remote for $24.95.
Barjo4 is offline
post #275 of 280 Old 09-25-2007, 03:54 PM
Rammitinski's Avatar
A year or so back, I tried the most recent model 8-device (with DVR control) Philips remote with my Panny EH85 HDD/DVD recorder, and it contained a Panny code which controlled all the basic buttons.
I know it usually runs about $25,00, but if you could find it cheaper, you could try it. Whether it would control your cable box, I wouldn't know, since I have Dish. But it did control my Dish tuner. The main reason I didn't keep it was because it was extremely difficult to program the learning buttons from some of my other remotes.
But at the same price, I'd go with the Panasonic remote, naturally.
I was considering trying the remote again when I saw that my local Sears had an ES-15 remote-less display model for only $31.00. But it looked a bit beat up, so I decided against it. I should probably go over to Best Buy and check them out for the heck of it. Walmart here still wanted $125.00 for an unopened one.
Rammitinski is offline
post #276 of 280 Old 10-04-2007, 05:30 AM
AndreLaplume's Avatar
FYI...bought mine 6 months ago and used it primarily to make numerous copies of old VHS tapes. It does a great job.
I just started using it as a replacement for my VCR to record a half dozen shows a week. Set up is simple but the tuner sucks! I split the cable from my wall, half into the cable box and on to the tv. Half into the dvd recorder and on to the TV's Video Input. The picture is snowy and not crisp at all. A booster did not help. This is very disapointing.....my fault...should have tried it out months ago and returned it I guess.
AndreLaplume is offline
post #277 of 280 Old 10-05-2007, 11:59 AM
computerman3's Avatar
Wondering for best picture quality, should i use Componet? Svideo or compositie connection, RF is used for satellite reception only, due to dual tuner satellite receiver..which outputs on that cable for TV 2
computerman3 is offline
post #278 of 280 Old 10-05-2007, 12:14 PM
Well, I tried both RCA and Component...snowy each way. Let me know how yours turns out.
post #279 of 280 Old 10-05-2007, 12:35 PM
Component would normally be best.
post #280 of 280 Old 10-07-2007, 09:41 PM
Looks wonderful on mine, did 4 recordings since switching from Svideo, perfect picture. So leaving it as it, and nice and happy
