New RCA DRC8052N?? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 227 Old 09-21-2006, 06:02 PM
Stalker's Avatar
Upscaling comes from the connection!
The best conection is the HDMI which will upscale to 1080i but keep in mind the PQ will still be determined by the source i.e. quality of the recording of the DVD.
Stalker
Stalker is offline
post #92 of 227 Old 09-21-2006, 06:09 PM
bobkart's Avatar
An HDMI connection doesn't upscale, in this case the DVD Player/Recorder does that, then sends the result over HDMI, which is delivered to the display just as it gets it. An HDMI connection is just a cable, with no ability to change the video characteristics (such as resolution) as it goes through.
bobkart is offline
post #93 of 227 Old 09-23-2006, 09:44 AM
dpcolgan's Avatar
Anyone know where I can get/purchase a replacement remote for my new DRC-8052N?
dpcolgan is offline
post #94 of 227 Old 09-24-2006, 04:24 PM
spacelunatic's Avatar
Found this in the model 8060 User's guide at the back under Accessories:
Remote Control (RCR615DCM1)
part number 261387; $23.10
How to Order
To place an order by phone, have your Visa, MasterCard, or Discover Card ready and call the toll-free number listed below.
Use this number only to place an order for accessory items.
1-800-338-0376
The necktie is a symbolic leash, symbolizing the wearer's domesticity and subservience to the demands of society.
Cut a tree, plant a tree.
spacelunatic is offline
post #95 of 227 Old 09-25-2006, 03:57 PM
gwave's Avatar
I think I learned that if you connect the 8060n via HDMI the other outputs stop working. So you can't have it put out to more then one TV or a slingbox as I was planning to do until I found out its a no go. Unless I missed something.
gwave is offline
post #96 of 227 Old 09-30-2006, 06:42 AM
8IronBob's Avatar
Quoted: 61 Post(s)
Liked: 24
Yes, I have just received this DRC8052N as a birthday gift, and currently have it hooked up to a Westinghouse 32" LCD HD-Ready TV (the old LTV-32w1) using an HDMI-DVI cable (from Philips). Now, the problem that I have with this, is that even though it records from the cable box, and plays back those DVDs just fine. However, I have it that, if I were to play any commercial, Hollywood DVD, the sound will play, but the screen will flicker and sometimes lose the signal, even at the 720p and 1080i signals. I'm quite sure that the Westinghouse DVI is HDCP compliant whilst having that HDMI-DVI connection. Was there any way to set region codes, or other types of programming for the DVD playing feature regarding commercial DVDs at all? Don't tell me that RCA's trying to pull another Sony on me.
Living Room: Samsung UN46A750 46" ToC 1080p, Yamaha HTC-6160 AV Receiver, JBL Cinema 480 5.1 Speakers, Magnavox HDD/DVD Recorder, Scientific Atlanta Explorer 8300HD.
Master Bedroom: Sony KDL-55W950B 55" 1080p, Sony HT-XT1 Soundbar, Xbox One, Scientific Atlanta 8300HD
Basement: Toshiba 32TL515U 32" 1080p 3DTV, PlayStation 3, Xbox 360, Bose Companion II Series 2 2.1 Speakers, Panasonic DMR-EZ28 DVD Recorder
8IronBob is offline
post #97 of 227 Old 10-04-2006, 03:22 PM
cinlea2001's Avatar
I purchased an RCA DRC8052N DVD recorder appx 2 months ago. One annoying problem is that periodically, it locks up and won't respond to any commands, whether its from the remote or whether I push the buttons on the recorder itself. The only solution is to unplug it. Of course, then I have to reprogram everything again. The issue that is giving me the most grief, and which I am looking for help with, is that periodically it jumps off the channel and records snow. I have to stop recording, go to setup, arrow down to "tv channel", and it immediately goes back to the station I was supposed to be recording. This happens about once a week, at random times. I record all news programs (AM, noon, 5pm, 11pm) every day of the week. There's no pattern to which day or which time this happens. Does anyone have any idea what might be wrong?
cinlea2001 is offline
post #98 of 227 Old 11-01-2006, 06:41 AM
KAB
KAB's Avatar
$89.99 +$5 s/h on woot today (11/01)
No, not spamming the site - thinking of buying one and was looking for info on how good/bad it is and came across this thread. Thought I"d pass along the deal info
This would be my first/only recorder and I plan to use it only for keeping copies of things already recored on my DVR. Given that intended use, can anyone see a reason not to purchase it?
Thanks for all the info posted previously
K
KAB is offline
post #99 of 227 Old 11-01-2006, 09:26 AM
CieJe's Avatar
yea, I saw that woot deal and I almost bit... I'm not sure if I will or not. reviews etc around the net don't look too favorable... but honestly they don't look favorable for most dvd recorders that I've looked at. info from people that own one would be awesome
CieJe is offline
post #100 of 227 Old 11-01-2006, 10:41 AM
KAB
KAB's Avatar
When I posted earlier, I hadn't noticed that the Woot deal is for a reman'd unit. I think I'm gonna pass as I get a uneasy fealing about the reliability of those types of things
KAB is offline
post #101 of 227 Old 11-01-2006, 11:31 AM
Olevia37HD's Avatar
Never mind this unit is a piece of junk when new(IMHO)!!!
Olevia37HD is offline
post #102 of 227 Old 11-01-2006, 01:20 PM
Chris Ruhl's Avatar
I've had the exact opposite experience. I've had mine for over 5 months now. Not a single problem.....
Chris Ruhl is offline
post #103 of 227 Old 11-01-2006, 02:58 PM
Olevia37HD's Avatar
You ever try to play a DVD full of Divx files?
post #104 of 227 Old 11-01-2006, 10:17 PM
randym431's Avatar
http://www.rcaaudiovideo.com/rcaav06...RC8052N_SS.pdf
Says it comes with hdmi cable AND supports DTS audio. ?????
randym431 is offline
post #105 of 227 Old 11-02-2006, 07:32 AM
Chris Ruhl's Avatar
Mine did not come with an HDMI cable. I have mine hoooked up to a secondary system with an older Pioneer DD 5.1 receiver (doesn't support DTS). However I am 99% sure I recall seeing a "DTS" logo on the top of the unit.
And Olevia37HD, no I can't say I tried any Divx files on the mahcine. I take it, it didn't work for you?
post #106 of 227 Old 11-02-2006, 07:50 AM
Olevia37HD's Avatar
Originally Posted by Olevia37HD View Post
Let me say I recommend upconverting to get this best quality picture from any source. Which this unit gives you.
I find this DVD recorder gives you a lot for your money.
The only problem I'm having is the unit Freezing while setting up to playing a divx files.
But only with divx files.
I'll have several files on a DVD-RW and I go to the Title screen and its seems to happen if I pick a file and don't let it preview first. But then again it could happen from moving around on that screen to fast.
This is my 2nd unit having the same problem.
Anyone have any ideas?
Other than that the picture is amazing comming from this unit.
Junk and not worth the trouble.
post #107 of 227 Old 11-08-2006, 08:43 PM
randym431's Avatar
It DOES support DTS audio (if you have a DTS enabled receiver).
post #108 of 227 Old 11-09-2006, 08:59 PM
randym431's Avatar
Does this output digital optical audio out while selecting hdmi hookup? Some dvd hdmi players disable optical out when in hdmi mode.
post #109 of 227 Old 11-09-2006, 09:14 PM
Quoted: 38 Post(s)
Liked: 197
Have you tried the same Divx files on a CD?
7558037 is offline
post #110 of 227 Old 11-09-2006, 10:16 PM
Olevia37HD's Avatar
No. Does it say it only plays Divix files on CD?
But I did tried the same DVD Divix Disc on a SAMSUNG DVD-R135, which didn't have a problem with it.
Did I say how much of a piece of junk the DRC8052N is and you should avoid at all cost!!!!
If you looking for a player that does what its advertises try the SAMSUNG DVD-R135.
post #111 of 227 Old 11-09-2006, 10:41 PM
Quoted: 38 Post(s)
Liked: 197
The Pio 640 manual says it plays DivX files on CD-R/RW, but nothing mentioned re: it also playing on DVDs. Might be the same on your recorder?
Also or instead, you might try changing the filename to .AVI since, according to Wikipedia, DivX "format is simply the AVI file format by another name."
7558037 is offline
post #112 of 227 Old 11-09-2006, 11:18 PM
Olevia37HD's Avatar
And why would I want to do all of that?
Remember the SAMSUNG playes the original Divix DVD.
Infact out of all the players I tried from BB & Wallyworld the RCA was the only Divix player that had a problem.
I'm glad most stores have a 30 or 90 day lease. I'm working on one now, for the Philips DVDR3390. Which will go back. The remote sucks and no ff or rew with Divix files.
post #113 of 227 Old 11-09-2006, 11:31 PM
Quoted: 38 Post(s)
Liked: 197
And why would I want to do all of that? .
You're right...no reason whatsoever.
7558037 is offline
post #114 of 227 Old 12-31-2006, 06:07 PM
FishGuy72's Avatar
OK, I just picked up the DRC8052NC for $99 and it included a HDMI cable in the box. I was basically looking for something to archive my Moxi box recordings to DVD until an affordable Hi Def DVD Recorder is available. I'm thinking this will be the perfect unit to fill the gap.
I never record anything over 2 hours (so SP setting should be good), I really wanted HDMI upconvert (this upconverts the DVDs and the other AV input sources as well) Then of course, I needed DVD record. I didn't really need Divx, but I'll get around to testing that too at some point.
I'll let you know my results/impressions as I try all the different features.
FishGuy72 is offline
post #115 of 227 Old 12-31-2006, 10:26 PM
steinway's Avatar
My TV has a DV output that can control some DVR's to start to record things from the TV's control. Does anyone know if this unit has the ability to be a slave to the TV for recording?
steinway is offline
post #116 of 227 Old 01-01-2007, 03:34 PM
greenjt's Avatar
I purchased the RCA DRC8052NC a few weeks ago to act as a simple VCR replacement. The unit played fine and the cable pass-through worked. What it wouldn't do was record TV in anything but fuzzy black and white. Also... when scanning for cable channels, they all show up in the same fuzzy black and white. I tried different wiring configurations but could not solve the problem. I also can't seem to set this up to be able to change channels on the TV using the DVDR. Customer service could only suggest unplugging it for 30 mins and trying again.
I have it connected to a Zenith Z42PX2D plasma.
I returned it for a new one today but have the same problem - i am at a loss. A little help please. Thnx.
jg
greenjt is offline
post #117 of 227 Old 01-01-2007, 03:52 PM
nextoo's Avatar
jg
A B&W fuzzy image via s-video can happen if the cable is bad. I've had this happen to me.
nextoo is offline
post #118 of 227 Old 01-01-2007, 04:24 PM
greenjt's Avatar
I should have mentioned that the same cable set-up works fine with my other DVDR.
Current wiring:
Coax in from wall
Coax out to TV
Component video and RCA audio
I also tried the HDMI and experienced no change.
greenjt is offline
post #119 of 227 Old 01-06-2007, 10:26 AM
FishGuy72's Avatar
Update #1 on testing.
- I recorded a nice HD nature program to my Moxi.
- Then I told my Moxi to only play it back in 480i
- While this was playing I recorded it to the DVD via S-video cable
- Then I played it back on a std def DVD player which looked GREAT!
- Next I played it back again on the DVD recorder, upconverting to 1080i and it looked pretty darn good!
SO, I'm definitely keep this recorder...
post #120 of 227 Old 01-06-2007, 10:33 AM
FishGuy72's Avatar
Hey, greenjt... I just tried that with mine and have the same results that you are experiencing.
I wasn't really planning on using the built-in tuner, so that isn't a make or break feature for me.
I will try however to see if I can correct it and let you know. It seems like it is set to the wrong type of catv signal. Basically on most TVs, when you set them up to autoscan channels it asks you to choose 1 of a couple of different types of catv signals and if you select the wrong one you get the b&w symptoms. I noticed that when you set this unit to autoscan, it doesn't have any choices for catv type.
