Help with Memorex DVDR2102 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-28-2006, 06:56 AM - Thread Starter
jdelayknee's Avatar
Hi folks, newbie here. Just bought a Memorex MVDR2102. I am creating movies on my computer using Pinnacle studio 9+. User manual is woefully inadequate. Looking for forum member that has experience with this recorder that I can consult. My first question relates to creating chapters. The manual directs you to a set of preset time intervals that the machine will create a chapter OR you can turn chapters off. Is there a custom feature here where I can put a chapter for each segement I record?
jdelayknee is offline
post #2 of 2 Old 02-12-2007, 08:11 AM
TMeeks's Avatar
Sorry to respond so late. I hope you are still around or that this might help someone else with similar questions.
I would interested in finding out if you can record the portions of your video having titles onto the Memorex MVDR2102.
I cannot. And, the answer I get from Memorex support isn't encouraging. Anybody else have one of these things?
TMeeks is offline
