Panasonic DMR-EH50 "U99" error - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-09-2007, 03:27 PM - Thread Starter
t_rooking1's Avatar
I have a Panasonic DMR-EH50 DVD hard drive recorder.
I have a "U99" error.
I try to turn off and turn on, but the unit just keeps going through, "self check", "please wait", etc, over and over for about 5 minutes, then back to "U99".
I think the problem relates to a DVD-RAM I was recording on.
Every time I try to start the unit, it seems to try to go to the DVD drive (instead of the hard drive), try to read the DVD, fail, then go through the errors above.
I try to eject the DVD, but I can't.
Has anyone experienced this error, or have any suggestions?
I can't even get the unit started at the moment!
t_rooking1 is offline
post #2 of 2 Old 01-09-2007, 04:56 PM
ncaahoops's Avatar
I recently got a U99 with a DVD-only model (ES20). It took me 3-4 reboots (pressing the Power button for 10+ seconds) to get it to "behave properly". It was caused by what seemed to be a media issue (title not recorded properly). The back of the manual explains U99 "unit fails to operate properly". It sounds like a blanket-catchall Unknown error number...
I believe there is a button combination to force the tray to open using the buttons on the front panel, but I forgot the details. Someone with an EH50, or a HDD-Panasonic may know more...
Also did you try powering the unit on by pressing the Eject button instead of the Power button? This works with the DVD-only recorders, I do not know if it works with the HDD-based recorders...
Boldly trying a new DVR: http://moto3416review.blogspot.com/
ncaahoops is offline
