Summary of ATSC recorders - Page 35 - AVS Forum | Home Theater Discussions And Reviews
post #1021 of 1027 Old 01-28-2008, 02:31 PM
leithalinda's Avatar
Extremely odd is right, rgazzara. Even our older Samsung VCR passes through when off. But call Crutchfield sales and ask about the technical notes on this unit, and that's what you'll find. The other thing is, it seems this unit does not pass through any HD at all (all HD is downconverted to SD). So I would definitely not want to watch TV through this box anyway, since we do see a few HD broadcasts via the five local digital channels we receive at no extra charge over coax. It would appear that Sony assumed anyone without a cable box or satellite receiver box, who therefore needed this recorder with its tuners, would not be seeing any HD shows anyway. Wrong.
leithalinda is offline
post #1022 of 1027 Old 01-29-2008, 06:33 AM
rgazzara's Avatar
Not to argue the point, but are you sure that you and Cruchfield are discussing the same issue? For example, if Crutchfield (and Sony) thought you were asking about HD signal passing through the AV output connectors (composite, S-video, or Component), then I would agree with them because no current DVD recorder does this. Plus in order to get a signal out of these connectors, the recorder must be on.
These AV outputs do not pass an HD signal because the recorder has to down convert the HD to SD in order to record on a DVD, and so the AV outputs see this down converted signal.
Perhaps this is what the Crutchfield and Sony reps are talking about. That would make sense.
RG
rgazzara is offline
post #1023 of 1027 Old 02-24-2008, 01:25 PM
DrBri99's Avatar
anyone heard when the next generation of DVD recorders are going to be released?
I'm encouraged by the better digital tuner chip in the recent coupon boxes, specifically the LG chip (in the Insignia, and Zenith).
DrBri99 is offline
post #1024 of 1027 Old 02-24-2008, 01:37 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Read it and weep, nothing much different announced, only worse in some cases.
http://www.avsforum.com/avs-vb/showthread.php?t=970168
jjeff is online now
post #1025 of 1027 Old 02-24-2008, 02:07 PM
DrBri99's Avatar
thanks for the link, I feel "up to speed" now.
DrBri99 is offline
post #1026 of 1027 Old 02-24-2008, 04:03 PM
kjbawc's Avatar
Someone posted a link around here about a new Philips, a 3576.
kjbawc is offline
post #1027 of 1027 Old 04-19-2008, 08:33 AM
Bill R (# 2)'s Avatar
There is a duscussion about the new Philips model here: http://www.avsforum.com/avs-vb/showthread.php?t=1018989
Bill R
Bill R (# 2) is offline
