HDMI to DV (camcorder) adapter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-28-2007, 03:29 PM - Thread Starter
newz54's Avatar
We all lament that normally the best input a dvd recorder has is "s" video but almost all of them have a camcorder dv input. It seems to me that if you could find an hdmi to dv adapter you could stay in digital and improve the quality. I would love to hook up my dish vip622 via hdmi into a recorder.
I briefly seached google for such an animal but found nothing. Thoughts?
newz54 is offline
post #2 of 3 Old 03-29-2007, 12:54 PM
vferrari's Avatar
Don't think this is possible or necessarily desirable for a couple of reasons. First you have a misconception about the perceived advantages of keeping the input signal entirely in the "digital" domain. While its true that a firewire/DV input is digital the fact is that all DVD recorders that have firewire inputs are expecting to see video in DV digital format (and most of those are expecting to see DV transmitted from a camcorder device vs. a PC or other digital source of DV), they then have to take that DV digital input and transcode it to an MPEG2 video stream and either PCM or Dolby Digital Audio on-the-fly. This mpeg2 transcoding process takes place whether the input is digital DV or via the analog inputs. As such, there is not a significant advantage whether you are starting with an analog signal or a digital signal since the losses associated with recompression/transcoding typically overshadow any artifacts resulting from the analog/digital conversion circuits of the analog inputs. Bottom line, since transcoding takes place, there may only be a slight, typically visually imperceptible advantage to keeping the input all digital.
Second, I have never heard of a DV/Firewire to HDMI adaptor - I think the data transmission interface requirements are signifciantly different for the two types. While DVI to HDMI adaptors do exist, but that's to allow HDMI output to be used with a monitor that only has DVI input (a separate audio cable typically has to be used to provide the audio input in this case). In any event, even if such a beast did exist, it would likely be very expensive because for it to really work what you want to do you would have to take the mpeg2 output from your dish receiver via hdmi, transcode it to DV for the dvd recoreder to recognize the signal on the DV input and then the recorder would have to transcode that back to mpeg2. So in this case the two lossy digitial stream conversions would likely be very visually detrimental to the original video signal. In your case you are best off using the analog (s-video/component) outputs of your dish receiver and analog (s-video/component) inputs on the DVD recorder. Note also, that dvd recorders with component inputs are rare. Good luck.
The Future ain't what it used to be...
vferrari is offline
post #3 of 3 Old 03-29-2007, 01:25 PM
Kelson's Avatar
Quoted: 1950 Post(s)
Liked: 1146
Even if you could do it adapter-wise, it wouldn't help you. HDMI is encrypted, so any recorder that could make use of it would have to have the equivalent of HDMI decryption circuitry. That will probably never happen. HDMI was designed for the express purpose of preventing you from copying the digital signal.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
