DRA-01601A: DVD Recorder with 160GB Hard Drive Info - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 729 Old 08-27-2010, 05:30 PM
Ravfour22's Avatar
ok i got my dvr working again i just replaced one of the caps a F 2200 10v or higher and 105C it is very fast had mine working in less tan 10 min
if you need help just contAct me and will try and walk you throught it
Ravfour22 is offline
post #722 of 729 Old 08-27-2010, 07:55 PM
Mitchman's Avatar
Good job Ravfour22. Which cap is it? Is there an identifier number on the board? And is that a 2200uF cap?
Mitchman is offline
post #723 of 729 Old 08-28-2010, 05:15 AM
Ravfour22's Avatar
The cap is Green in color, it has F 2200 on it, Then 10V but any voltage above 10 is fine I replaced with a 50V also must be at least a 105c(temp) or 221F(temp) cap, I also put in a second fan in the back. and drilled several holes in the lid over the power board,, from what i have been reading the chinese caps are not cured right they are done to fast so replace with a japanese cap, will last 20 years. i got one at a local tv repair shop, they charged me 3.00 per cap, anything else just ask.
post #724 of 729 Old 08-28-2010, 05:19 AM
Ravfour22's Avatar
any of the green caps could be bad, i got a reconditioned dvr for 99.99 when i took out the power board i had seen where a cap was replaced to that is what they did, they just swapped out a cap and re sold it. the best way to tell is that the top will be bowed out, if the cap is not perfectly flat then it is bad. might be hard to tell. i did not see it the first time, if you want i would just replace all the caps with jap versions and be done with it. will last 20 years well the caps will at least, lol. and no did not notice the pos on the board sorry
post #725 of 729 Old 09-08-2010, 10:24 PM
Ravfour22's Avatar
i would like to know if anyone has attempted to upgrade the dvd-rw
i want to replace it with a writer that will write double layer dvds
post #726 of 729 Old 09-09-2010, 11:09 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
You would be unsuccessful in this upgrade attempt. Even if you replaced the DVD writer with one that will support DL disks, the firmware running the DRA-01601A does not support DL disks, so you would have no way of requesting such an operation.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #727 of 729 Old 09-22-2010, 12:04 PM
Ravfour22's Avatar
i was wondering if anybody can tell me why when i burn a dvd and play in a different player when trying to fast forward or go back it will skip different times say i hit fast forward x4 it may jump 6 min. i am burning with memorex dvd-r also plus r
post #728 of 729 Old 09-25-2010, 10:14 PM
Mitchman's Avatar
It's Alive!!!!
I finally got around to replacing the 2-2200uf & 2-1000uf caps mentioned in this thread and the unit is once again in good working order.
Thanks guys!!!
Mitchman is offline
post #729 of 729 Old 02-20-2011, 08:33 AM
tahoejoe's Avatar
I remember reading somewhere in this thread that the DRA-01601A can play mpeg4 files. I have had no luck figuring out which mpeg4 format. I've tried files from my Neuros OSD with an .mp4 extension and the DRA-01601A can't see the files. I've changed the extension to .mpg and it sees them, but won't play them. Is it limited to divx/xvid files? If so, what extension should they be and are there any limits to the specifications of the files?
tahoejoe is offline
