Can't find any DVD-DL-R's? - AVS Forum
post #1 of 5 Old 05-17-2007, 04:11 PM - Thread Starter
Oiler1's Avatar
I have one older dvd player, one recorder and one new DVR which plays dvd dual layer +R's as well as -R( I think). I looked around and cannot find any DVD-DL-R's for sale? Only +R's. Would these still work on older DVD players and if not why are there not DVD-DL-R's?
Oiler1 is offline
post #2 of 5 Old 05-17-2007, 04:25 PM
suplex's Avatar
Try Here:
http://www.meritline.com/dl-dvd-r-do...r-dvdr-dl.html
Here:
http://www.supermediastore.com/ritek...dvd-media.html
And Here:
http://www.rima.com/Merchant2/mercha...gory_Code=DMDL
Never Underestimate The Power Of Forums.
suplex is offline
post #3 of 5 Old 05-17-2007, 05:01 PM - Thread Starter
Oiler1's Avatar
Thanks! I just can't find them in the brick and mortar stores locally. Nice to know they exist.
Oiler1 is offline
post #4 of 5 Old 05-17-2007, 06:07 PM
suplex's Avatar
Not a problem to help you locate them online, I always found the +R DL's to be cheaper for some reason myself, and you're right you practically can't find -R DL's in stores.
The way that a lot of people mostly use -R for Single Layer, that didn't seem to catch on with Dual Layer media as there is a wider selection with +R DL.
suplex is offline
post #5 of 5 Old 05-17-2007, 06:51 PM
wildfire99's Avatar
Because it took the -R camp a lot longer to get their DL discs together (and still seem to have layer break issues), thus +R DL took hold as the default.
wildfire99 is offline
User Tag List
