Modifying dvd recorders? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-06-2007, 02:38 PM - Thread Starter
TheDynaMike's Avatar
I am aware of plug in devices such as sima ct2 to make back ups of dvds however I was wondering if there is 'copy software " for my
dvd recorder that i can load onto a disk or DVD-R to modify my recorder to where I can make backups. It is a Magnavox MWR10D6. Has anyone heard of such a thing?
TheDynaMike is offline
post #2 of 6 Old 08-06-2007, 03:54 PM
DaveC E100's Avatar
Not likely if your machine is a stand alone DVD recorder. You can't load new software into those machines. You might have a shot if you are talking about a computer based DVD recorder but I have never heard of a Magnavox computer DVD burner.
Dave
DaveC E100 is offline
post #3 of 6 Old 11-07-2007, 11:06 AM
DonB2's Avatar
I think the DVD recorder would be capable of doing this if it had a built in Hard Drive and if the manufacturer did not have some internal copy protect flag set.
New owner of a MWR10D6
Donb2
DonB2 is offline
post #4 of 6 Old 11-07-2007, 12:00 PM
Whidbey's Avatar
It's possible with some DVD recorders, provided the manufacturer provides firmware updates and that someone has figured out to hack them. I was able to installed a hacked firmware onto my now deceased Lite-On 5007 which disabled the macrovision.
Enjoying crystal clear TV for free.
http://www.fcc.gov/mb/facts/otard.html
Whidbey is offline
post #5 of 6 Old 11-08-2007, 11:40 AM
Doug O's Avatar
What quit on the 5007? If it was just the drive, those are easy to fix. I had heard that some of those units had power supply problems but I think fixes for them may have been posted. Time to get out the soldering iron....
Doug O is offline
post #6 of 6 Old 11-09-2007, 12:13 PM
Whidbey's Avatar
The 5007 takes forever to prep discs, if at all. Then, if it successfully records something, it won't "finish up" so I can play the disc back or take it to another player. I've been using my old DVD+RW discs which are admittedly in bad shape, but I've also tried brand new DVD+R's with no success either.
I have not tried brand new DVD+RWs yet to see if that helps, and have no desire to go out and buy new discs just to experiment with.
I view and record almost 100% digital OTA now, so this recorder is somewhat obsolete for me now. If I could figure out how to make it timer record from a line input, then maybe I would have some use for it, providing I could get it to work.
I enjoyed the "DVR-like" features of this machine while it worked, but for now, until I get a better DVDr with a digital tuner, my trusty VCR is more reliable.
Whidbey is offline
