Pioneer 640-H - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 53 Old 08-20-2007, 05:13 PM
nextoo's Avatar
Search "hkan". hkan has the "unofficial" pioneer web site that will walk you through it.
nextoo is offline
post #32 of 53 Old 08-20-2007, 07:36 PM
Sean Nelson's Avatar
Quoted: 25 Post(s)
Liked: 24
Originally Posted by tac7 View Post
Do you know if replacing the HDD in the Pioneer 640 is as tricky as in the 520?
Have a look at the Pioneer FAQ web site run by HKan, it has all the information you need to know.
Sean Nelson is offline
post #33 of 53 Old 08-20-2007, 07:40 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Sean, that link's the wrong site.
Here's Hkan's site (pioneerfaq.info).
wajo is offline
post #34 of 53 Old 08-21-2007, 10:29 AM
tac7's Avatar
I have looked at the pioneerfaq.info site, but I'm not clear on the requirements for that "Data Disc" mentioned in various forums. Is the "GGV1273 Type 2" disc the same as the "newpio.iso" [pioneer4(1.30).zip] mentioned on the pioneerfaq.info site?
If not, what is the difference, and where is that "GGV1273 Type 2" disc available? --thanks.
tac7 is offline
post #35 of 53 Old 08-21-2007, 10:39 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I think you can ask questions that Hkan will answer thru his site (in case you don't get an answer here).
wajo is offline
post #36 of 53 Old 08-21-2007, 03:47 PM
Quoted: 25 Post(s)
Liked: 24
I second this. HKan has been very helpful, you can e-mail him at: support@pioneerfaq.info
post #37 of 53 Old 08-28-2007, 11:00 AM - Thread Starter
BASHERS33's Avatar
Thanks ACpewty for all of the information.
Now I can't even find my instruiction manual and forgot the max speed diosc that can be sued on this and the max record speed. Ahhhhhhhh. I always lose manuals when I ened them and am all organized when I don't need them. I couldn't quickly find the limitations online either. lol
Yes I try not to fill the HDD, but I am way too lazy and now it is almost full to the very verye nd too. One time on my 510 or 520 (w/e it was) when I let it fill it madfe it where I couldnt delete things. And somehow I got around it.
And eys the clock is set to manual. Auto NEVER has worked for me on any unit, vcr or dvd recorder.
Got Talk (general discussion forum - someone add product reviews)
Got Zelda
BASHERS33 is offline
post #38 of 53 Old 08-28-2007, 11:13 AM - Thread Starter
BASHERS33's Avatar
Also that download says it is only for Europe. Is the only way to get it done in the U.S. still to ship it? I don't want to bother with that.
Got Zelda
post #39 of 53 Old 09-02-2007, 10:20 PM - Thread Starter
BASHERS33's Avatar
Hello.
Got Zelda
post #40 of 53 Old 09-02-2007, 10:48 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Originally Posted by BASHERS33 View Post
Hello.
Hello.
Go to the pioneerfaq.info website here, and scroll down till you see the following:
"Canada/US
DVR-540/543H/640H
Firmware 6.20* ONLY Region 1 US/Canadian version ONLY
Instructions in the file! Install it on your own risk! The *.MEM file must be the only one on the CD-RW."
That's the U.S. Region 1 Pio 640 FW update. Download and follow the instructions for unzipping and creating a data disc. Takes ~2 minutes to install.
wajo is offline
post #41 of 53 Old 09-04-2007, 03:31 PM - Thread Starter
BASHERS33's Avatar
Well even though it says install at your own risk, I assume others here have done it and everything went well?
Also I wonder if there are any updates that can be done for the 510 or 520? I'll try to find it on the site. I am assuming older models wouldn't have anything currently downloadable which can add anything to it though.
Got Zelda
post #42 of 53 Old 09-04-2007, 03:40 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
The 640 US update is very easy and fast. Many people have installed it and no one has had a problem...except me...I didn't unzip the files before burning my data disc and tried to install those unzipped files. The 640 just kept grinding away until I stopped the disc, with no harm done.
The unzipped file name and size should be:
SR06A620.MEM 12,482 KB
wajo is offline
post #43 of 53 Old 09-07-2007, 07:02 PM - Thread Starter
BASHERS33's Avatar
ok I GUESS this worked. I put the disk in, followed the instructions, and when it ejected the disk it said "download 2" on the front of the recorder then after a while it powered off.
To clarify, was this only to fix the titles carrying over? I assume nothing else was fixed and all I could do for the other things bothering me is order the other remote and then it would have the chapter mark button and commercial skip working on discs?
Got Zelda
post #44 of 53 Old 09-07-2007, 08:36 PM
Quoted: 25 Post(s)
Liked: 24
...order the other remote and then it would have the chapter mark button and commercial skip working on discs?
If you're talking about the 633 remote, it doesn't have a commercial skip button. What it has that the 640 remote lacks is an "eject" button and a better (IMHO) layout without some of the buttons hid behind a sliding door.
post #45 of 53 Old 09-07-2007, 09:53 PM
ACPewty's Avatar
I suspect you meant the 633 remote doesn't have the chapter mark button right Sean? It does have the commercial skip button, and it works better than the 640 remote because commercial skip also works for finalized DVDs.
ACPewty is offline
post #46 of 53 Old 09-08-2007, 07:24 AM
Urlee's Avatar
Say what you will about the eject button, but I find it very handy. It means I don't have to wait for the tray to open when I get up to remove a disc, and after I burn a new disc I can remotely open and close the tray to ensure that it's completely readable,
Sean,
I COMPLETELY AGREE with you on this.
I haven't had the pleasure of having the remote with that "Reject" ah, er, Eject button, but experienced having to WAIT and felt how NICE it would have been to have the tray already out by the time I got up to take the disk out. And close from the remote!
Sincerely,
Urlee
Urlee is offline
post #47 of 53 Old 09-08-2007, 08:54 AM
Quoted: 25 Post(s)
Liked: 24
Whoops, there goes another neural fuse! Yes, the 633 remote has eject and commercial skip buttons but no "chapter mark" button.
post #48 of 53 Old 09-08-2007, 11:49 PM - Thread Starter
BASHERS33's Avatar
I thought someone specifically said it had the chapter mark button or that my old controller for the 510 or 520 would work properly with the chapter mark button. Maybe I should go all the way back to the 510 and find someone with that remote becuae it had the chapter mark button, eject button, the better layout of buttons, and a properly working commercial skip button. So assuming its chapter mark button works on this recorder, it would have everything I assume.
Got Zelda
post #49 of 53 Old 09-09-2007, 08:26 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Sean, I knew that 30th bday pic you use as your Avatar would come back to haunt you someday!
You need to update it with last year's 50th bday pic so we'll have more sympathy for you.
wajo is offline
post #50 of 53 Old 09-09-2007, 10:23 AM
Quoted: 25 Post(s)
Liked: 24
Sean, I knew that 30th bday pic you use as your Avatar would come back to haunt you someday! You need to update it with last year's 50th bday pic so we'll have more sympathy for you.
You're thinking of the old picture, the one you're seeing now was taken within the last year after my 52nd. If anything, blame Urlee for "doctoring" it up.
It's amazing what you can hide in an image that's only 53 pixels wide...
post #51 of 53 Old 09-09-2007, 10:30 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I asked my wife to look at your pic and she guessed "late 20s"... man, you really CAN hide about 25 years in a pic only 53 pixels wide...
Shrink your pic to 26 pixels wide and you'd be in 1st grade!
wajo is offline
post #52 of 53 Old 09-09-2007, 10:37 PM
Quoted: 25 Post(s)
Liked: 24
I seem to recall that someone tested a 510 remote with the 633 and found that it would not respond to the chapter mark button. If that's true then the 640 isn't likely to either.
post #53 of 53 Old 09-13-2007, 10:50 PM
kjbawc's Avatar
I definitely recall that someone tested the chapter mark button on a 640, and it did not respond. If it had, I would have such a remote by now!
kjbawc is offline
