New Walmart HDD/DVDR-Magnavox H2080MW8 - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 943 Old 02-10-2008, 10:05 AM
wajo is offline
post #542 of 943 Old 02-10-2008, 10:17 AM
tomanystraydogs's Avatar
So far it beats my previous panny's by a mile.
Only 2 things I wish were better:
1) remote, but that can be addressed with a good uni remote.
2) editing titles. no onscreen keyboard, you have to use the remote's keys.
Samsung Plasma TV FAQ - read it, learn it, live it.
tomanystraydogs is offline
post #543 of 943 Old 02-10-2008, 10:54 AM
Another test.
Put a blank Sony dvd-rw disc in.
Scheduled 2 recordings to the harddrive with a short gap in between.
Worked fine.
Now testing with a 12 minute gap between recordings.
post #544 of 943 Old 02-10-2008, 11:14 AM
Blank dvd-rw in drive, 2 scheduled recordings to HDD, worked fine.
Now testing 2 scheduled recordings to dvd-rw.
post #545 of 943 Old 02-10-2008, 11:42 AM
2 scheduled recordings to blank dvd-rw, worked fine.
So far I have not been able to cause a failure.
post #546 of 943 Old 02-10-2008, 12:32 PM
c987y's Avatar
Tommy, gotcha. Interesting that it seemed to fix it for him.
I am still puzzled as to why I can never get SP as a recording mode option on mine.
sloch, except for this one problem for me, I like the machine. The person who set it up chose not to use my cable box at all, so the tuner works for me.
c987y is offline
post #547 of 943 Old 02-10-2008, 12:42 PM
Another test:
Scheduled 2 recordings 10 minutes apart to the HDD while the drive had a dvd-rw in it with 2 titles on it.
Worked fine.
I am done testing.
As the Myth Busters like to say, this myth is officially busted
post #548 of 943 Old 02-10-2008, 12:44 PM
I will test that, brb
post #549 of 943 Old 02-10-2008, 12:48 PM
Scheduled recording modes, from best to worst, are:
HDD: HQ - SP - SPP - LP - EP - SLP
DVD (dvd-rw): HQ - SP - SPP - LP - EP - SLP - AUTO
post #550 of 943 Old 02-10-2008, 12:49 PM
Will look at dubbing now
post #551 of 943 Old 02-10-2008, 01:10 PM
When using setup - dubbing - HDD to DVD my rec modes are:
HIGH - HQ - SP - SPP - LP - EP - SLP - AUTO
This is using a dvd-rw, not sure if the disc type makes a difference and this is all I have to test with.
post #552 of 943 Old 02-10-2008, 01:15 PM
For clarification, I have no cable box, just basic cable.
post #553 of 943 Old 02-10-2008, 01:37 PM
Not enough space, bet that's the problem.
I just set dubbing to dub 3 programs that are over 4 hours total from HDD to DVD. My only rec modes available are SLP and AUTO.
post #554 of 943 Old 02-10-2008, 02:04 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
Originally Posted by tomanystraydogs View Post
Not enough space, bet that's the problem...
That's the only possible answer.
Chuck44 is offline
post #555 of 943 Old 02-10-2008, 02:10 PM
c987y's Avatar
Thanks, tomany and Chuck. The movie recorded to the HDD is under 2 hours, and that's all I'm trying to dub to a blank dvd. I've tried both rewrittable and non rewrittable.
c987y is offline
post #556 of 943 Old 02-10-2008, 02:14 PM
So you are saying SPP - LP - EP - SLP - AUTO are available but
HIGH - HQ - SP are not?
post #557 of 943 Old 02-10-2008, 02:23 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
What Mode did you record the movie to your HDD with?
Look at the title menu and it should show.
If you recorded in HQ it won't fit on a DVD without
recoding to a lower quality mode.
Chuck44 is offline
post #558 of 943 Old 02-10-2008, 02:27 PM
c987y's Avatar
Ah, thank you Chuck. Yes, I did record in HQ, thinking that would give me the highest quality. So is the picture quality better if I record HQ and dub in SP? Of if I record in the lower mode and dub in HQ?
c987y is offline
post #559 of 943 Old 02-10-2008, 02:37 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
With my Philips DVDR3575H/37 which is basically
the same machine I record everything to the HDD
in SP mode, which to my eyes looks just as good
as HQ. That also allows for high speed dubbing,
which keeps the same mode, as high speed dubbing
is actually just copying the files without having to
re-code.
Chuck44 is offline
post #560 of 943 Old 02-10-2008, 02:55 PM
c987y's Avatar
Chuck, a big thanks. That is going to be a much better workflow for me.
c987y is offline
post #561 of 943 Old 02-10-2008, 03:03 PM
as HQ.
I'm curious if you think recording HDTV in SP is just as good as HQ.
tia
post #562 of 943 Old 02-10-2008, 03:34 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
tia
Neither the Maggy or the Philips can record HDTV.
They can record a HD signal as SD, and with that
in mind I see so little improvement in quality between
HQ and SP that I don't use HQ, but use SP for everything.
Chuck44 is offline
post #563 of 943 Old 02-10-2008, 03:39 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I'm like Chuck44 and record everything in SP.
However, I did a test of mulitgenerational dubbing and found HQ to hold up extremely well... I don't think SP would do as good in the same test.
Can't think of a good reason for multi-generation dubbing, but if it ever comes up, I'd use HQ!?
wajo is offline
post #564 of 943 Old 02-10-2008, 03:54 PM
Thx.
I realize that, just did not know what your source was, say SD vs HD.
post #565 of 943 Old 02-10-2008, 04:22 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
...just did not know what your source was, say SD vs HD.
My source for recording is the Philips DVDR3575H/37's
tuner via OTA antenna.
My TV is a Toshiba 26DF56 SD Widescreen with digital
tuner.
Chuck44 is offline
post #566 of 943 Old 02-10-2008, 04:31 PM - Thread Starter
HoustonGuy's Avatar
I have done 25 or so high speed dubs on this Maggie(original was all HQ) from HDD to TY DVD-R's- not one hitch-perfect-takes about 30-35 minutes for 4 GB- How can my Pio 640 and Panny EH55 do this in 10 minutes? What a time difference
The Lab called: Your Brain is ready.
HoustonGuy is offline
post #567 of 943 Old 02-10-2008, 05:44 PM
My source for recording is the Philips DVDR3575H/37's tuner via OTA antenna.
I take it that's OTA HD, right?
That's good to know, thx.
post #568 of 943 Old 02-11-2008, 09:44 AM
I recorded the Grammys, 1080i over cable, using SP, looks good so far.
post #569 of 943 Old 02-11-2008, 09:49 PM
I took that Grammys recording (1080i over cable in SP mode) and chopped it down to 12 minutes, 13 seconds.
I did 2 burns to a Sony dvd-rw, one using HIGH and the other using SP.
HIGH took 3 minutes
SP took 13 minutes
Both look great and I really can't see a difference playing them back.
post #570 of 943 Old 02-11-2008, 11:42 PM
While watching Terminator:TSCC in 720p HD on my plasma I recorded to the Maggy in SP mode.
Playing it back it is amazing how good it looks.
