Looking for your opinion on purchase - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-29-2007, 02:19 PM - Thread Starter
billingw's Avatar
I have a Macbook and several VHS tapes of the family dating back to 1980. I wish to buy a one-step VCR/DVD burner to copy the tapes onto DVD and then import them into imovie for final editing and burning. Might you have an opinion on whether I should buy the SONY RDR-VX555 or the Panasonic DMR-ES45V? Perhaps you have a preferred third choice? Thanks.
billingw is offline
post #2 of 4 Old 10-30-2007, 05:37 PM
bron's Avatar
I am not that familiar with the two you mention, but a possible third choice would be a Toshiba D-VR5 if you can find one. They are on closeout at some stores and are also available on eBay and elsewhere.
bron is offline
post #3 of 4 Old 10-30-2007, 11:52 PM
Rammitinski's Avatar
Don't buy the Sony. If you ever want to use it to record from cable or satellite, you're going to run into some excessive copy protection problems.
Rammitinski is offline
post #4 of 4 Old 10-31-2007, 06:09 AM
jtbell's Avatar
You might want to consider that your image quality will take a double hit using the procedure you describe. When you dub VHS to DVD in the DVD recorder, you will compress the video data a lot in order to get it onto the DVD in MPEG-2 format. When you import it into iMovie, it will be converted into a different format for editing. Finally, when you burn a new DVD in iDVD, the video will be converted back to MPEG-2 and compressed heavily again.
I've extracted video from DVDs and then used iMovie and iDVD to make new DVDs, mainly to add chapter marks where I prefer to have them. The final product isn't really bad, but there is nevertheless a noticeable difference in image quality, especially when there's a lot of motion or video noise in the original.
If this material is important to you, I recommend getting an analog-to-digital video converter that takes analog output from a VCR, digitizes it, and sends it directly to iMovie in DV stream format via Firewire. I've had a Canopus ADVC-100 for over four years and have been happy with it. There's a more recent model, the ADVC-110, which seems to run about $220-250. There are surely other similar units. You can also use a digital camcorder for this, in "pass-through" mode.
jtbell is offline
