Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 555 - AVS Forum | Home Theater Discussions And Reviews
 567Likes
post #16621 of 27715 Old 11-01-2011, 05:48 PM
mrmazda's Avatar
Quoted: 162 Post(s)
Liked: 55
Originally Posted by videobruce View Post
This is probably a foolish question, but has anyone thought of the possibility of adding a SSD drive??
Not sure why, but only to see if it would/could work.
No reason it wouldn't, but the available additional speed would be entirely wasted, not to mention the price premium.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is offline
post #16622 of 27715 Old 11-01-2011, 07:38 PM
dare2be's Avatar
I knew I should have bought more than two WD Elements 2TB drives on Black Friday last year at Target. I haven't seen that $70 price since, and now it's a pipe dream.
dare2be is offline
post #16623 of 27715 Old 11-01-2011, 08:59 PM
DeKatt's Avatar
I had not read this forum in several weeks. Now I see that I no longer have to suffer from "515 envy". Thanks to the great people who post here, I am ready to apply the V upgrade to my 2160A tomorrow. Special thanks to Bizarro_Stormy for being the first to take that leap into the void, and prove that the upgrade works.
EDIT: done, without a hitch (if you don't count the momentary panic until I remembered the "unplug for 30 seconds" step).
DeKatt is offline
post #16624 of 27715 Old 11-01-2011, 09:50 PM
keithjfro7's Avatar
The Mag 515 appears to have one major flaw: It won't allow you to dub DVD-R media from other machines onto the 515 HDD.
If I'm wrong someone tell me.
keithjfro7 is offline
post #16625 of 27715 Old 11-02-2011, 03:02 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
You're wrong. Finalized discs, like those from another machine, require a different method of dubbing to the Mag's HDD, as described here.
7558037 is offline
post #16626 of 27715 Old 11-02-2011, 06:28 AM
keithjfro7's Avatar
When I have a Ritek DVD-R recorded with media from an RDRHX715 in the machine and press dubbing I get the red circle with the line through it on the lower right.
When I have a DVD-R in the machine with media from the same RDRHX715 and press rec mode, nothing happens.
I've tried it with both the MCR on and off. Nothing.
OK...correction, I THINK it's working! Thanks!!!!!
post #16627 of 27715 Old 11-02-2011, 06:33 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Do you start the first title on the Ritek DVD PLAYING, then press Dubbing button on the remote? Try with MRC on and off. You must select Rec Mode before starting playback. Just follow the steps in that link I gave.
Does the Ritek DVD have copy-protected titles on it? Sony plays such tricks often.
7558037 is offline
post #16628 of 27715 Old 11-02-2011, 06:48 AM
keithjfro7's Avatar
I can get Sony media to dub onto mag HDD now.
Now the issue is why does anything I record from this magnavox on a DVD-R show up as 10 titles listed when I put it in any other machine or computer I own?
Never seen that before, weird.
post #16629 of 27715 Old 11-02-2011, 06:55 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
See Ken.F's explanation in your other thread for a possible answer. It's the only thing I can think of that makes sense.
Edit: According to a diff. Sony 780 manual I have, you press TITLE LIST to see and play from the normal disc title menu, where you select a title and press ENTER or the > button. If you press TOP MENU or MENU instead, you see a more detailed menu like you're seeing.
7558037 is offline
post #16630 of 27715 Old 11-02-2011, 07:20 AM
keithjfro7's Avatar
I also need to remember that the HX715 is a 6+ year old machine.
Just put the same disc in a newer panasonic player and a newer lap top and the magnavox menu popped up no problem.
post #16631 of 27715 Old 11-02-2011, 07:27 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Sounds like the 715 might have been mfgd right around the time they were adding +R/RW to machine designs and hadn't worked out how best to display title menus yet.?
Edit: Yup, 2005.
7558037 is offline
post #16632 of 27715 Old 11-02-2011, 07:34 AM
Quoted: 920 Post(s)
Liked: 368
Update to latest firmware without a problem. With the more accurate time, I might switch with the 515H. But not today. I'm going to play with the clock first.
JoeKustra is offline
post #16633 of 27715 Old 11-02-2011, 07:50 AM
timtofly's Avatar
Originally Posted by Dartman View Post
Well my geek friend and I about the 386 days got all excited because we found used 1 meg 30 pin dims for 25 each we both got 4 meg and played Doom and Wing commander to our hearts content with all the extras enabled on our zippy 386 dx 25 machines.
I think I may have had a 52 and 120 meg hard drive by that point. I remember when hard drives first approached a dollar a meg and we both bought Western Digital 340 megs, oh so much space we'd never fill it.
That was back before graphics became 3D, and media was artful, not digitized.
timtofly is offline
post #16634 of 27715 Old 11-02-2011, 07:52 AM
TBoneit's Avatar
It probably would work however at over $1000 for a 600Gb SSD and given that it is writes that wear out a SSD.
In the Magnavox it could work but in a Satellite DVR where for example it is always buffering two data streams it would wear out fairly quickly.
TBoneit is offline
post #16635 of 27715 Old 11-02-2011, 07:54 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
... or in one of the later Mag HDD recorders (2160>515), which are also buffering 6-hours continuously, but ONLY WHEN ON.
7558037 is offline
post #16636 of 27715 Old 11-02-2011, 08:28 AM
keithjfro7's Avatar
Edit: Yup, 2005.
But I'm using DVD-R Never use + anything.
post #16637 of 27715 Old 11-02-2011, 08:30 AM
dare2be's Avatar
I'm waiting for ship-to-store of my 515 from Wally World to supplement my 3576 that has served me well over the last 2-3 years...1856 HDD hours and 90 hours of DVD-WR. Since I have a satellite DVR and won't be connecting an OTA antenna or using the built-in tuners in any way, I should have no problems with any freeze problems. I'll keep everyone posted.
dare2be is offline
post #16638 of 27715 Old 11-02-2011, 08:41 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Wireless Speaker(s)
I'm planning to set up a wireless speaker for my main LCD HDTV next to my recliner so I can hear the lousy audio produced by most TV speakers. My wife has super-sensitive hearing so we've been using our AV receiver to boost the stereo sound from the TV's L/R audio ouptuts. This still creates a problem for two people with very diff. hearing capability.
So, to test whether a separate speaker near me would help, I moved my Center speaker from the AV system to the table next to me, and it was EXCELLENT... I could understand every word with the TV volume down to a level my wife could easily hear! First time in a LONG time!
My wife/CFO said she also could hear better from that speaker even tho she sits about 6-ft away from it (but ~13-15 ft from the TV).
So... since running audio wires is not an option for me, my research has led me to this speaker., which has good Reviews, one of which is about a hard-of-hearing husband, like me!
In response to a question asked about that speaker by someone who's TV didn't have stereo L/R outputs but does have digital audio out, I found a digital audio coax/optical>stereo L/R converter for the sender unit, so you don't have to have stereo L/R outputs on your TV as long as it has one of the digital outputs.
I thought there might be others who'd be interested in this, or others who've done a similar thing and has some tips?
7558037 is offline
post #16639 of 27715 Old 11-02-2011, 09:29 AM
TBoneit's Avatar
... or in one of the later Mag HDD recorders (2160>515), which are also buffering 6-hours continuously.
I thought The Magnavox only buffered when on?
Mine for example is only on when I'm watching a recording or a timer is working.
The Older Philips that I re-purposed for my brother when the device he was using to watch Basic cable died does give him more channels since it does tune the Clear QAM channels. I still had the manual for it too.
These Units do seem to be pretty reliable from my experience. Knock Wood.
I'm hoping that the rising drive prices don't kill these off.
TBoneit is offline
post #16640 of 27715 Old 11-02-2011, 09:43 AM
Kelson's Avatar
Quoted: 2030 Post(s)
Liked: 1209
I've been watching drive prices. The price of the MDR515 is $285 in Amazon.com. Was it always that high at Amazon?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #16641 of 27715 Old 11-02-2011, 09:52 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Yes, only when on. I'll correct my post to avoid confusion.
7558037 is offline
post #16642 of 27715 Old 11-02-2011, 09:58 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
The +R/RW and +VR recording system involves more than just the discs. The menu system is *primarily* what I was referring to in *your* case.
7558037 is offline
post #16643 of 27715 Old 11-02-2011, 10:02 AM
Quoted: 920 Post(s)
Liked: 368
You should get a Sony DHG. The drive and fan are on whenever power is applied. One of mine has 5.2 years of runtime, one 4.1 years. Yet they are silent. We should count our blessings with the Funai. It still makes me wonder why it draws 5w when in standby.
post #16644 of 27715 Old 11-02-2011, 10:04 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
I would think that's due to the amplified passthru always "on" even when the machine is off, besides the other normal standby duties.
7558037 is offline
post #16645 of 27715 Old 11-02-2011, 10:07 AM
Quoted: 920 Post(s)
Liked: 368
I never thought of that. Thanks.
post #16646 of 27715 Old 11-02-2011, 01:15 PM
TV123's Avatar
I must be special... I posted last week that I upgraded my 3-year old 2160a (which had never had any problems with freezes or timekeeping), and the next day it froze while searching for a time signal (I pulled the plug after about 20 minutes). After that, on advice (or hunches) from some other posters, I changed my time-setting channel from an analog to a digital.
All seemed well for a few days. I recorded and replayed a couple of programs. I got my new 515 remote today (yay! little changes make it much better for me.) and went to watch a recording I made last night. After a bit, I noticed that the timer display was stopped at about 3 minutes in (even though the recording was still playing), and none of the remote buttons worked. First suspect was the new remote of course, but none of the buttons on the front panel worked either, and swapping batteries around convinced me that the remote wasn't the issue.
I didn't have the patience to wait till the recording ended to see what happened. I pulled the plug briefly, and when I replugged it, I saw military time (I remember other posters mentioning that, but I'd never seen it before) - but still no response to any buttons.
Okay, unplugged it for 5-10 minutes, but when I replugged it, I didn't hold down the power button. After that, it searched for and found a time, and the only thing missing were my timer settings.
I set up my timers yet again, and based on vague memories of various postings here, this time I set the auto-clock to OFF. We'll see if that makes any difference...
Am I the only one who's having NEW problems after applying the new firmware to an older machine? And has anyone experienced a freeze while a recording is playing? I don't remember ever hearing about that, but maybe I wasn't paying attention because MY unit didn't have the problem
Anyone have any other suggestions? I keep seeing posts about successful upgrades and I wonder what's different for me.
TV123 is offline
post #16647 of 27715 Old 11-02-2011, 01:38 PM
Quoted: 920 Post(s)
Liked: 368
I did the upgrade this morning. I have set my V2160A:
Auto clock - see if it still hates PBS
Daily record CBS NTSC at 11:30pm.
I know some SCTE-127 data makes it through. If it locks up I will be the first to make a post. Tomorrow I will set my clock to manual on my other PBS channel. Then I'll try Fox, ABC and whatever. I have 26 NTSC channels. Honestly, my only NTSC selection is when doing these tests.
You could add your location to your profile under the UserCP tab and mention cable/OTA and if cable: who. Others with your problem are probably keeping track of this issue.
post #16648 of 27715 Old 11-02-2011, 01:49 PM
profhat's Avatar
You are wrong.
Is there any safe way to donwgrade the firmware of a V2160A?
profhat is offline
post #16649 of 27715 Old 11-02-2011, 01:54 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
TV123 might not want to add any ident. yet just in case a return might be reqd ?
There's still an open question whether or not these DVDRs can be returned to a previous FW after a machine takes on the newer/different Model No. TV123 just *might* be the first here who has to answer that question if his problem continues?
IMO, IF the FW can be "reversed" it should take OK. If not, I believe it'll just spit the FW disc out?
I think answering that reversal question is an important element in deciding whether ot not to update, i.e., peace-of-mind if possible to reverse.
7558037 is offline
post #16650 of 27715 Old 11-02-2011, 02:39 PM
TV123's Avatar
I _think_ I still have the download from the firmware I applied a couple of years ago for the finalizing bug but I'm not quite there yet... I'll wait and see how things go with all the clock settings "off".
I wonder if I'm having these issues because I mistakenly applied the 2160/513 version of the firmware before I applied the 515 version... but I'd think there would have been other users who had done that (but maybe not on the same day).
As for location, I'm on the east coast, with a major cableco, which (for now) still provides the locals in digital unencripted, plus the "basic cable" package in analog (no stb needed). Sorry I'm not too technically adapt as far as ntsc/atsc and I can never remember which is composite and which is component so I hope you'll be patient - I know analog vs. digital and red/yellow/white vs red/blue/(I forgot what other color). I'm just a step above a vcr user but in my house I guess the proverbial one-eyed person is the king among the blind
TV123 is offline
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
