Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 569 - AVS Forum | Home Theater Discussions And Reviews
 153Likes
Old 11-28-2011, 11:59 AM
dare2be's Avatar
Originally Posted by Ken.F View Post
Might be a bad cable between the recorder and the TV, or the TV input has something wrong with it. Have you tried using a different type output on the recorder and different input on the TV?
Considering the problem is on all inputs, I considered the output cable. I get the same pattern (though not as pronounced) on component out as I do on S-video out. I haven't tried HDMI out yet.
Right now I'm leaning toward RFI either from the power outlet or nearby components, which I will test this evening.
dare2be is offline
Old 11-28-2011, 12:01 PM
Ken.F's Avatar
Quoted: 1472 Post(s)
Liked: 1256
Got a cordless phone in the house?
Ken.F is offline
Old 11-28-2011, 12:16 PM
dare2be's Avatar
Nope, no cordless phone, nor any landline phone. Just our cellphones.
dare2be is offline
Old 11-28-2011, 01:12 PM
stapler1234's Avatar
..........Right now I'm leaning toward RFI either from the power outlet or nearby components, which I will test this evening.
"Herringbone" RF Interference is most often due to bad grounding of the cables shield(s), allowing the shield to act as an AM-FM antenna, especially if the cable is positioned vertically. Additionally, if one or more of your components are powered from different outlets than others, a poor ground at one of those outlets could also cause the problem your seeing.
To simplify your search task, suggest you start with only satellite box and TV connected. If picture is "clean", add additional component boxes one-at-a-time until "herringbone" reappears. At that point, replace the coax and/or audio-video cables to see if problem remains or clears.
Don't despair. Tracing RF Interference problems can take a lot of time and effort, but they are solveable. In most cases, the cause is easly and cheaply repairable, once you find the "culprit".
stapler1234 is offline
Old 11-28-2011, 02:15 PM
dare2be's Avatar
I'm not sure I follow you. "start with only the satellite box and the TV connected", meaning, take the Mag out of the equation initially?, or have only the sat box and TV connected to the Mag? I only see the herringbone when viewing through the Mag, and the sat and TV are all that is connected to it. I have no herringbone viewing any other components connected, either before or after I introduced the Mag to the cluster.
dare2be is offline
Old 11-28-2011, 02:33 PM
dare2be's Avatar
Just thinking out loud, but if I hook up HDMI from the Mag to the TV, and still see the herringbone, I can rule out the connection from the Mag to the TV, as the HDMI connection is digital and wouldn't be affected by RF, correct?
I'm going to start my investigation down the path of least resistance, meaning the easiest initial reconfiguring/moving of components/cables/cords, the better.
dare2be is offline
Old 11-28-2011, 02:35 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I don't think that's correct... interference is a bitch, maybe even a Medusa!
wajo is offline
Old 11-28-2011, 04:13 PM
bodhi78's Avatar
The quickest test you can do right away without disconnecting anything: turn on the system, see the herringbone there, reach to the coax and raise it away from all other connecting cables, especially away from the power cords. Hold it there in the air and see if the picture has improved at all. Do the same for HDMI cable. If the herringbone is gone or lessen, then the cable shielding is the problem.
bodhi78 is offline
Old 11-28-2011, 06:55 PM
dare2be's Avatar
Do you mean the satellite coax feeding the sat DVR? I have no coax connected to the Mag. Only S-Video/L/R in and out.
My daughter has had the TV tied up this evening, so I probably won't get to try anything until after her bedtime.
dare2be is offline
Old 11-28-2011, 07:32 PM
bodhi78's Avatar
Sorry, yes I meant the video cable.
bodhi78 is offline
Old 11-29-2011, 07:42 AM
KR7L's Avatar
Originally Posted by JoeKustra View Post
You can get more data on the VIP722K from eBay:
http://www.ebay.com/itm/DISH-Network...item27c08aed4d
Doesn't look like S-Video works on the second output. That's not a bad thing, since RWY output on a digital signal can be quite good. My sister went dish last year and she likes the portability. Hope this works for you.
The current 722K supplied by Dish does not include a s-video output. At least mine does not.
KR7L is offline
Old 11-29-2011, 07:58 AM
DonB2's Avatar
With my older DVD Mag with no hard Drive I could save a frame of the recording to use as the title ICON for a DVD I do not see this option on the 515, Am I missing something?
DonB2 is offline
Old 11-29-2011, 08:06 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Yes, it's in the Edit menu for each title (one of the Edit options).
Here's a help file on it with some tips.
wajo is offline
Old 11-29-2011, 11:19 AM
DonB2's Avatar
Wajo, And that will allow me to index the pic on the Harddrive similar to the pic on a DVD?
Question 2: If one is using the Mag as a DVR where you pause a live show to get some coffee than come back to continue watching a show - what do you do if the next show you want to watch is on a different channel and starts on the hour but you have not finished the show on the other channel because you paused it a few times? DO you set up the Mag to record the other channel?
DonB2 is offline
Old 11-29-2011, 11:36 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Unfortunately, you can't do the same on the HDD. Only way to "pick a frame" for the index pic on the HDD is to do a Front-Cut so that frame is 1st.
No, you can't have the machine switch to another channel or that would stop the buffer on the live show you paused and, assuming that live show hasn't ended yet, you'd miss the portion left after switching channels.
Only if you know that live show you paused has ended could you then quickly SAVE the buffer to the HDD, then switch to the other channel to watch, manually record, or set a timer to record it.
wajo is offline
Old 11-29-2011, 12:34 PM
computerman3's Avatar
Hi There
Having problems with my Phillips 3576 Disc Reading, it records fine, i got about 9,631 hours of use time with it, some reason the darn thing lately has trouble reading certain discs, i plan on getting better quality discs from Supermedia store when i get a CHristmas gift card
Right now im using TDK Discs
(I know crappy kind) but all i could afford right now
computerman3 is offline
Old 11-29-2011, 12:36 PM
dare2be's Avatar
RE: Herringbone problem
Well, I never figured out exactly what the cause was, but I did find a workaround and it does appear to be the connection from the Mag to the TV. I swapped the HDMI and Component connections so that the Mag is connected via HDMI and the DVR is connected via component. No more herringbone on any sources.
dare2be is offline
Old 11-29-2011, 12:38 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Originally Posted by computerman3 View Post
Hi There
Burner might be getting a little old, esp. if you've been using 16X discs, or those land-fill discs burned just good enough originally that they played until land-fill time.
Prob. needs 8X discs, Taiyo Yuden Premium. There's a sale on now, $22.99/100, lowest price I've seen, thru 11/30.
Not my favorite white-top, but a great deal!
wajo is offline
Old 11-29-2011, 12:50 PM
dare2be's Avatar
Thanks for the link, I'm running low on my Verbatim +R's...refresh my memory, what are the benefits/differences between +R and -R again? I've been solely a +R user to this point, and probably won't change unless given a compelling reason.
dare2be is offline
Old 11-29-2011, 01:10 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I'd stick with +R for the reasons stated in this help file.
wajo is offline
Old 11-29-2011, 01:18 PM
DonB2's Avatar
"Unfortunately, you can't do the same on the HDD. Only way to "pick a frame" for the index pic on the HDD is to do a Front-Cut so that frame is 1st."
A work around but a lot of early tv shows start seconds to minutes before the Title of the show or name of that episode comes up on the screen.
I will ask for Index Pic on Hard Drive in the 518 version
Oh and thanks for the scenario on DVR usage.
DonB2 is offline
Old 11-29-2011, 01:43 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
While I'm using Magnavox, Philips and Panasonic recorders, beginning in 2008 I've standardized upon 8x TY Premium Line DVD-R media for all my recorders. My Panasonic recorders perform better with DVD-R media than DVD+R media. Magnavox and Philips recorders work equally well with DVD+R or DVD-R media.
I try to keep at least 2,500 blank 8x TY Premium Line DVD-Rs on hand at all times. Yesterday's SMS order included 300 more TY DVDs, around a two month supply.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
Old 11-29-2011, 01:53 PM
dare2be's Avatar
An advantage I have on creating index pics on the HDD is that all my content is either on demand or being transferred from another DVR, so what I do is pause the source material on the title frame, record that for a split second, press pause on the Mag, and then go back to the beginning of the source material and then resume recording on the Mag. I thus have an automatic built-in indexing pic process for all my HDD recordings, and it saves me the step of having to do the index pic editing on the DVD titles.
dare2be is offline
Old 11-29-2011, 01:57 PM
dare2be's Avatar
Thanks wajo, for the link comparing the +R -R formats...I knew it was there, but couldn't find it on a cursory search.
Yikes, and I thought I was a DVD junkie. I have over 800 full discs burned already, and I go thru about a 200-disc supply each year.
dare2be is offline
Old 11-29-2011, 02:22 PM
BIGA$$TV's Avatar
Quoted: 63 Post(s)
Liked: 53
Okay, I have to ask. Why do you need so many blanks? How many have you already burned?
The wife is on my case about all the DVD's I have burned and stored, perhaps 300 with two movie titles per. Maybe I can tell her she is lucky because there is a guy on AVS that makes my collection look like a spit in the ocean!
BIGA$$TV is offline
Old 11-29-2011, 02:35 PM
dare2be's Avatar
For backup and saving physical storage space purposes, get a 2TB external hard drive and use your computer to rip images of all your burned discs. Then you can store away the physical discs hidden in a closet somewhere.
dare2be is offline
Old 11-29-2011, 02:48 PM
dare2be's Avatar
I sometimes trip over my wife's shoes that she doesn't have room anymore in her closet to store them. Not once has she tripped over my DVDs.
dare2be is offline
Old 11-29-2011, 03:00 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
My home-recorded archive currently has more than 9,000 DVDs.
Here's a September 2010 photo showing the then-current storage arrangement for around 7,000 of the archived DVDs.
DigaDo is offline
Old 11-29-2011, 03:09 PM
dare2be's Avatar
Already showing as sold out.
dare2be is offline
Old 11-29-2011, 03:30 PM
mrmazda's Avatar
Quoted: 113 Post(s)
Liked: 41
And I thought I had it tough finding what I want when I want with only1/3 that many.
BTW, I've been buying only TYG02s from SMS for quite some time. They may be better than average, but they're far from perfect. One of my Pioneers is really picky about blanks, liking to fail to complete HS copy nearly half the time using them, apparently because it always tries to burn at 16X regardless of the media's capability. I put the "failed" ones in a PC burner and they show speed in K3B in sections as low as 2X, which nevertheless can write to whatever blank space is left on them, same as my other Pioneer. I had just as good if not better luck with locally obtained JVC brand DVD-Rs while they were available until nearly a year or so ago.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is offline
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
