Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 642 - AVS Forum | Home Theater Discussions And Reviews
 169Likes
post #19231 of 27667 Old 02-28-2012, 11:06 AM
NickTheGreat's Avatar
Quoted: 408 Post(s)
Liked: 284
I'm glad I got my ordered a few weeks ago
Got 'er hooked up over the weekend and did my first real recordings last night. My 3575 is still sitting there, a little sad however
NickTheGreat is offline
post #19232 of 27667 Old 02-28-2012, 11:34 AM
maineiac13's Avatar
Quoted: 13 Post(s)
Originally Posted by wajo View Post
Thanks for the info. You got a low-mileage, like-new unit!
If only I was a low-mileage, like new USER!
maineiac13 is offline
post #19233 of 27667 Old 02-28-2012, 12:38 PM
Quoted: 908 Post(s)
Liked: 365
What is this? Amazon now wants $550 for a new 515H. This is worse than gasoline.
JoeKustra is online now
post #19234 of 27667 Old 02-28-2012, 12:49 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
Don't blame Amazon. Considering those high prices for 515's are by others that offer their goods through Amazon, that is not exactly Amazon that is the actual seller.
Johnla is offline
post #19235 of 27667 Old 02-28-2012, 12:50 PM
joekoler's Avatar
I know this has probably been asked before but what is the main differences between the 515 and 513 other than the size of the HDD? Are the remotes much different?
joekoler is offline
post #19236 of 27667 Old 02-28-2012, 12:54 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
http://www.avsforum.com/avs-vb/showp...#515Comparison
Johnla is offline
post #19237 of 27667 Old 02-28-2012, 01:01 PM
dare2be's Avatar
Quoted: 13 Post(s)
Hardware wise, 515 has a longer battery backup time, bigger hard drive, and that is about it. Latest software firmware from the 515 can be applied to the 513 to make it function exactly like a 515. Remotes are different but very similar:
MDR513 remote.....................................MDR515 remote:
dare2be is online now
post #19238 of 27667 Old 02-28-2012, 01:12 PM
joekoler's Avatar
Thanks for the info on the 513/515. The only thing I can't make out on the picture is does the 513 have the rapid play with sound like the 515 and does it work the same?
joekoler is offline
post #19239 of 27667 Old 02-28-2012, 01:14 PM
dare2be's Avatar
Quoted: 13 Post(s)
Yes. Look at Johnla's link of the comparisons and remote diagrams. Rapid play works the same.
post #19240 of 27667 Old 02-28-2012, 01:25 PM
Quoted: 408 Post(s)
Liked: 284
I went with the 513 since I couldn't find any 515's. I'm planning the FW update and use a Harmony remote. The only difference would be the HDD size. And my OCD won't let me accumulate too much on it at once anyway
post #19241 of 27667 Old 02-28-2012, 01:27 PM
dare2be's Avatar
Quoted: 13 Post(s)
I just got my main workhorse (3576, in heavy use since 2008) down to just 7 titles on the HDD. Boy was that liberating.
post #19242 of 27667 Old 02-28-2012, 01:56 PM
artwire's Avatar
Quoted: 36 Post(s)
Forum giving me fits today, very slow. Not sure if others are having trouble too -- just wanted to offer a heads up that there's a refurbished 515 on ebay. Price is reasonable now, in the $150 range, but there still are 6 days to go. No idea who is offering it, but the seller has a good reputation /rating.
http://www.ebay.com/itm/Magnavox-MDR...item4ab4a1019f
artwire is offline
post #19243 of 27667 Old 02-28-2012, 02:35 PM
84GNLT1's Avatar
Got my 515 today that i orderd last friday from J&R, very fast shipping. My question, does this machine have a program guide that displays different channels and the programs, current and future? I thought it would be set up like a direct tv dvr, you bring up the guide and highlight the program you want recorded. I only have OTA from an antenna on the roof going to a toshiba 51h84 rpct. Have the signal coming from the 515 to a Samsung DTB H260F to my tv because the tv doesn't have an atsc tuner. So, an i missing something, or do you have to program the 515 like an old vcr?
84GNLT1 is offline
post #19244 of 27667 Old 02-28-2012, 02:49 PM
ChrisC47's Avatar
Just a quick post to thank wajo and everyone for this outstanding thread!
I have been heavily using a Pioneer DVR-533H for years. I was very active here at AVS Forum in the "Pioneer disappearing EPG" thread starting in 2005 when I bought the thing and encountered some EPG problems. Over a couple months we documented lots of quirks there, and the machine has more or less survived until now. A couple times over the years it corrupted itself and I had to reset it, and a couple years ago I had to beat on the cable company (and various local broadcasters) to continue the EPG service. But the EPG continued to rot, and there was a start time bug in the Pioneer, and so lately I've been recording everything with manual timers anyway.
A couple months ago the timer control screens got corrupted and no amount of reset would fix it. I literally can't see the schedule, much less edit them or create new timers. So since then I've been running on just recording via the existing timers, which is fine since I mostly just record big blocks of time and then edit down to the segments I want (long story). Well, today I found that one of the shows had moved out of the timer blocks, and now I'm really stuck. Looks like the end of the road for the Pioneer after 7 good years.
I came here, learned about the HDD/DVDR situation, and now have a 513 on order! Refurbed from eComElectronics via Amazon. I'll give the firmware update a shot when I get it. I've looked at the manual and it seems to be fine for my needs.
Thanks for helping me solve this problem within hours of it popping up for me!
Atlanta over-the-air digital TV reference table, now with Atlanta OTA FAQ:
http://www.avsforum.com/avs-vb/showt...7#post16732147
ChrisC47 is offline
post #19245 of 27667 Old 02-28-2012, 02:49 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 197
No EPG. Timer recording is described here. Note also further down the Pre-Titling you can do so your recorded shows all have a title.
7558037 is offline
post #19246 of 27667 Old 02-28-2012, 04:28 PM
Quoted: 908 Post(s)
Liked: 365
It's nice that the 515H has the quality you received from the HD tuner. I have several H260F tuners in a box that I used to feed my analog recorders before getting digital tuner devices like the 2160A & 515H.
post #19247 of 27667 Old 02-28-2012, 04:41 PM
mrmazda's Avatar
Quoted: 144 Post(s)
Liked: 52
Originally Posted by maineiac13 View Post
my 513 Refurb from J&R (via Amazon) that arrived today. (Very quick shipping by the way as I ordered it on Friday and it was delivered on Tuesday.)
Amazon accepted my $170 513 order 28 hours ago and still I haven't received a shipped notification.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is online now
post #19248 of 27667 Old 02-28-2012, 04:49 PM
maineiac13's Avatar
Quoted: 13 Post(s)
Hmm...I ordered mine at 7am Friday morning, received a shipping notice from Amazon at 3pm and another shipping notice direct from J&R at 4pm...all on the same day.
post #19249 of 27667 Old 02-28-2012, 04:50 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 197
Only 6 ea. 513 refurbs left from latest batch at J&R.
7558037 is offline
post #19250 of 27667 Old 02-28-2012, 05:08 PM
Walmart has raised the price of the 513 to $249.88 and no longer allows you to see their inventory status. They did this for a long time at the beginning of sales... only let you enter "1" as qty of 513's but allowed big number for 515's. We'll see if that sticks till they run out.
Last known qty of 513's was 683 Mon morning, 2/27/12, and they were selling an avg of 70-80/day.
We may have been our own worst enemy on this price jump. All the inventory checks made it look like a super duper hot item, so the inventory managers jacked the price on us.
Oh well, I'll be happy with my 2 I guess.
Z
CO-Zman is offline
post #19251 of 27667 Old 02-28-2012, 07:01 PM
jomc's Avatar
Walmart is selling this new for $250. I have a $50 gift card and was thinking that the 3 year warranty for $30 was a good idea. In your opinion do you think $230 ($250 minus $50 gift card plus $30 3/yr warranty) is a better deal than the factory refurbished $170 90/day warranty from J&R?
Just kind of looking for knowledgeable opinions. Have a 2 yr old refurb Magnavox vcr/dvd recorder from J&R and it's on the fritz. . am wondering if I should spend the extra $60 and buy new w/the longer warranty? Thx for any advice.
jomc is offline
post #19252 of 27667 Old 02-28-2012, 07:02 PM
dare2be's Avatar
Quoted: 13 Post(s)
Z
Nah, I see the price increases as a sign that there won't be any more new inventory replenishment. See the sun? It's about to drop below the horizon.
post #19253 of 27667 Old 02-28-2012, 08:05 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 197
Moot point now, J&R sold out.
7558037 is offline
post #19254 of 27667 Old 02-28-2012, 08:55 PM
gastrof's Avatar
Quoted: 118 Post(s)
*sigh*
Come the first of the month, I was actually going to get another 513 to stow away, "just to make sure".
Oh well...
You'd think this alone would be reason enough for Funai to reconsider not making any more.
As for JonC, he could still get one from Wal-Mart, which I believe was his intention.
Hmmm....
I went with the 513 since I couldn't find any 515's. I'm planning the FW update and use a Harmony remote...
Why the different remote?
If you prefer the remote from the 515, you can get one of those to use with the 513.
...Just kind of looking for knowledgeable opinions. Have a 2 yr old refurb Magnavox vcr/dvd recorder from J&R and it's on the fritz. . am wondering if I should spend the extra $60 and buy new w/the longer warranty? Thx for any advice.
Could you describe the fritzy problem(s)?
gastrof is offline
post #19255 of 27667 Old 02-28-2012, 09:09 PM
profhat's Avatar
At least 10 or 15 (maybe more) of them will be offer on ebay in the next weeks/months, for something like $350 - 450. Funai must be very proud.
profhat is offline
post #19256 of 27667 Old 02-29-2012, 03:35 AM
MACINTN's Avatar
Both units back in stock at J&R as of this morning at 6:30am EST.The site would not let me update to check stock numbers though.I ordered another 515 (my third one) for my folks.
MACINTN is offline
post #19257 of 27667 Old 02-29-2012, 04:16 AM
mickinct's Avatar
Quoted: 206 Post(s)
Liked: 902
i just ordered 1 more.
MickinCT
mickinct is offline
post #19258 of 27667 Old 02-29-2012, 05:16 AM
mickinct's Avatar
Quoted: 206 Post(s)
Liked: 902
8:16 am sold out again.
MickinCT
mickinct is offline
post #19259 of 27667 Old 02-29-2012, 05:43 AM
dare2be's Avatar
Quoted: 13 Post(s)
gastrof missed out again
post #19260 of 27667 Old 02-29-2012, 07:10 AM
Kelson's Avatar
Quoted: 1984 Post(s)
Liked: 1173
If funai was smart, they would be the ones selling them on ebay for $350-450.
On a different note, ever wonder why there are so many of the previous model 513's sitting around in inventory waiting to be sold? They probably had a huge production run that they didn't clear out before they released the 515.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
