Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 875 - AVS | Home Theater Discussions And Reviews
post #26221 of 26222 Unread Today, 07:39 AM
chazdole's Avatar
Quoted: 45 Post(s)
Originally Posted by hopsing44 View Post
Hello AVS members:
Most likely, one of these regulators is for the 5 volt buss, the other for the 12 volt buss. Which is which I don't know yet.
If anyone does, look in there and see if it gives any clues to the identity for:Q2101 & Q2203.
There should be printing on the voltage reg. I say should because I once had a (overpriced) video processor that the manufacturer had sanded all the ICs to remove the numbers. I guess they didn't want anyone copying their proprietary design.
But, in your case, the reg might not be dead. In repairing a number of LCD TVs, I have found that part of the power supply is always hot, to power the IR remote circuitry, while another part is not hot until you switch the unit on. Do you hear a click or any indication that the unit is powering on?
I haven't followed all of what you have checked, but sometimes capacitors fail and change values, causing power supply issues. Any of them bulging?
Any fuses bad? Should be marked F1, F2, etc. on board. But Voltage regs do go bad, so that very well may be the problem. I would start by trying to get voltage readings. And I understand your hesitation about short circuiting with the probe. I've done that before, and it sucks.
chazdole is online now
post #26222 of 26222 Unread Today, 07:51 AM - Thread Starter
AVS Club Gold
wajo's Avatar
Quoted: 38 Post(s)
Liked: 144
[QUOTE=hopsing44;31342250
Anyway, I guess the final question for the Forum members comes down to------ does anyone have a service/shop manual for any of these units? The 2160a, 513, 515, 537, 557--- they no doubt all have the very same power supply configuration so a manual for one would be just as good as for any of the other units in this series.
Q2101 &
Q2203.[/QUOTE]
Have you seen this section of my help file on Hardware Replacement & Upgrade?.
PHILIPS HD DVRs | *MAG/PHILIPS SD DVDRs* | DVDR/DVR COMPARISONS | POST-DVDR OPTIONS
*If you're logged in, links will only work if your User CP > Edit Options > Number of Posts to Show per Page is set to 30, the default.
wajo is offline
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
Gear in this thread - Mdr515h by PriceGrabber.com
