Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 878 - AVS | Home Theater Discussions And Reviews
post #26311 of 26314 Old Yesterday, 10:14 AM
gastrof's Avatar
Quoted: 35 Post(s)
I just had something weird happen, and would like to compare notes with you guys.
I had a DVD, home-created using the software AVStoDVD, coded as 16:9.
On the 515 it plays into my 4:3 TV as letterboxed (the 515 is set to "letterbox" under its video settings). (In the other room, it plays off my other 515 as normal widescreen into my HD television.)
I hit "dubbing" while playing the DVD, and naturally it restarted the DVD playback, and began recording the DVD's recording to the hard drive.
Once that was done, I knew what'd happen. Since the 515 can't stamp a recording as widescreen (16:9) I knew it'd play back filling the 4:3 TV screen, with everyone looking tall and thin.
Wrong.
The recording played off the hard drive LETTERBOXED. (Even the restart of the playback once "dubbing" had been pressed showed up as 4:3 fullscreen, with the expected distortion, but not the playback from the hard drive!)
I know if I were to re-burn this to another DVD, it'll likely end up as fullscreen 4:3 and will have the "stretched" distortion, but HOW IS IT STILL CODED AS 16:9 ON THE HARD DRIVE, ON A MACHINE THAT CAN'T CODE THAT WAY?
Anyone got any ideas? Anyone seen the same thing before yourselves?
The only time I've seen this happen is when the tuner is used to record an HD channel off air. Not even off a widescreen cable channel. And yet, here it is, preserving the widescreen coding from a DVD on the hard drive.
Again, anyone else seen anything like this?
gastrof is offline
post #26312 of 26314 Old Yesterday, 09:06 PM
jam-h's Avatar
Question Do Funai DVD/VCR use same remote codes/conflict with Magnavox MDR series?
Might be given a used Funai-manufactured DVD/VCR combo (either a Funai ZV427FX4 or (Funai) Toshiba-branded DVR620).
Want to use in same location as Magnavox MDR HDD/DVDs. Would anyone know if the remote control codes for these units (with many of the same functions) conflict or overlap with Magnavox 515s, 537s, etc.?
jam-h is online now
post #26313 of 26314 Old Today, 01:24 AM
gastrof's Avatar
Quoted: 35 Post(s)
If memory serves, the Philips remotes didn't interact with the Magnavox machines, even tho' Funai made both.
Maybe any they make under their own name also have a unique set of remote codes, different from the other two?
gastrof is offline
post #26314 of 26314 Unread Today, 05:27 PM
jam-h's Avatar
Thanks for the real-life experience gastrof. It would be great to not need yet another IR-receiver cover. (Would also be great if the Maggys had user selectable remote-code sets to choose from, like the Panasonic "Diga" DVDRs...)
Looks like I might be getting the Funai-branded unit in a few weeks. I'll post the cohabitation results for the Maggy+Funai DVD/VCR in the "remote" case anyone else is interested in that model .
jam-h is online now
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
