Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 883 - AVS | Home Theater Discussions And Reviews
post #26461 of 26463 Unread Today, 01:44 PM
Liked: 0
New 557 or used 535/537?
I have had an mdr535 for a couple years. I use the hdd almost every day mostly for time-shifting, from which I occasionally burn dvds. I haven't had any problems with it and I am looking to buy a second unit. I note from previous posts here that there are apparently significant differences between my 535 and the latest 557 model. Do those differences (some of which I do not fully understand) reduce the basic functionality of the unit? Is the new model "cheaped down" in any sense? Should I buy a new 557, or would I have better luck with a used or refurbed 535/537 on Ebay?
Also, is there a way to transfer contents of the hdd to an external hdd? (I don't mean removing and replacing the internal drive, I mean plugging in a cable and pressing buttons, as you would with a PC.)
newbie2015 is online now
post #26462 of 26463 Unread Today, 02:24 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 147
The major differences are pretty significant to a user of the previous gens of the Mag units, esp. if that user often uses and interchanges DVDs made in another Mag unit. The recording systems are different so it would be like using a Panasonic DVDR is an established Mag system. The 557 does have some new features that could be useful to any user, like ability to work with "virtual" titles rather than the real title, thus preserving the original intact, and Combining titles using that "virtual" system.
For transferring titles between Mag units, here's a help file with some suggestions.
PHILIPS HD DVRs | *MAG/PHILIPS SD DVDRs* | DVDR/DVR COMPARISONS | POST-DVDR OPTIONS
*If you're logged in, links will only work if your User CP > Edit Options > Number of Posts to Show per Page is set to 30, the default.
wajo is offline
post #26463 of 26463 Unread Today, 03:11 PM
mrmazda's Avatar
Quoted: 57 Post(s)
Liked: 33
Originally Posted by Ken.F View Post
Hopefully you can get the cable connected again before auto channel preset passes DTV 20...
One could inject an RF A/B switch to use as an on/off switch, facilitating quick "reconnecting" of the cable at the appropriate time.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is online now
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
