Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 890 - AVS Forum | Home Theater Discussions And Reviews
post #26671 of 26688 Old 07-27-2015, 01:46 PM
Liked: 0
Ok. When I get to the rec mode select portion of dubbing the option for high is blanked out. All I can do on the dub is LP, EP, SLP, or AUTO. Th original recording is done in SP. I don't understand why HIGH, HQ, and SP are blanked out and not available for the dub. What am I missing?
num1cboysfn is offline
post #26672 of 26688 Old 07-27-2015, 02:19 PM
jjeff's Avatar
Quoted: 342 Post(s)
Liked: 139
Possibly your title is to large to fit on your DVD?
jjeff is offline
post #26673 of 26688 Old 07-27-2015, 02:49 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 150
It's all explained, in several ways, in the links I gave a few posts back.
PHILIPS HD DVRs | *MAG/PHILIPS SD DVDRs* | DVDR/DVR COMPARISONS | POST-DVDR OPTIONS
*If you're logged in, links will only work if your User CP > Edit Options > Number of Posts to Show per Page is set to 30, the default.
wajo is offline
post #26674 of 26688 Old 07-27-2015, 03:56 PM
Liked: 0
I'll read them again. I've gone thru them over and over step by step so I don't know what I could be missing. Perhaps jjeff is correct and the title is too long. I guess I've just been using the Panasonics too long too change my thought process.
post #26675 of 26688 Old 07-27-2015, 03:57 PM
Liked: 0
Thanks. Maybe in my haste and frustration I overlooked that. Hard to teach an old dog new tricks.
post #26676 of 26688 Old 07-28-2015, 10:01 AM
orrin1933's Avatar
Hello All,
I have a '513' which works very well for OTA recording. Recently, however, I changed the TV from a 37" Vizio 'E' series to a 39" 'D' series. Both are 720P.
Now the HDMI setting on the '513' does not stay at 720P! Many times when it is turned on it reverts to 480P with an anamorphic picture. It's no problem for me to touch the HDMI button, but my wife has trouble finding the right button!
The '513' is set to 16:9 with the Progressive Scan off. The CEC is disabled on both the TV and the '513'.
Is there anything I missed? Actually the settings are the same as with the older TV and the HDMI stayed at 720P with that unit.
Orrin - Engineer/Photographer/Webmaster
orrin1933 is offline
post #26677 of 26688 Old 07-28-2015, 10:26 AM
Ken.F's Avatar
Quoted: 698 Post(s)
Liked: 652
Originally Posted by orrin1933 View Post
Hello All,
Maybe the new TV doesn't keep the HDMI port active when the set is turned off. If the Magnavox gets turned on before the TV is on, the Maggie won't be able to tell what HDMI modes the TV can display so it sets the HDMI mode to 480. Try turning the TV on before turning the Magnavox on, and turn the Magnavox off before turning the TV off. If doing that makes the HDMI mode stick, check the TV settings menu for power saving options and see what happens if you disable them.
Ken.F is offline
post #26678 of 26688 Old 07-28-2015, 10:59 AM
Kelson's Avatar
Quoted: 1139 Post(s)
Liked: 699
It doesn't matter. The TV will upscale anything it is sent to match its screen resolution. The scaler in the TV is probably better than the scaler in the DVD recorder so let the recorder send out the native 480 signal to the TV and let the TV do the upconversion to 720p to fit its screen.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #26679 of 26688 Old 07-28-2015, 06:36 PM
orrin1933's Avatar
Originally Posted by Kelson View Post
It doesn't matter. The TV will upscale anything it is sent to match its screen resolution. The scaler in the TV is probably better than the scaler in the DVD recorder so let the recorder send out the native 420 signal to the TV and let the TV do the upconversion to 720p to fit its screen.
The TV does not upconvert to fill the screen! The 480P is a 4:3 presentation with the image compressed horizontally (anamorthic).
post #26680 of 26688 Old 07-28-2015, 06:40 PM
orrin1933's Avatar
Good idea, but not too practical since the maggy goes on and off by itself while making timer recordings.
post #26681 of 26688 Old 07-29-2015, 03:15 AM
Ken.F's Avatar
Quoted: 698 Post(s)
Liked: 652
I think you didn't read my entire reply.
Ken.F is offline
post #26682 of 26688 Old 07-29-2015, 06:24 AM
JimLely's Avatar
Liked: 26
But the TV will indeed upscale the Maggie's input to the TV's native resolution
JimLely is offline
post #26683 of 26688 Old 07-29-2015, 07:19 AM
Kelson's Avatar
Liked: 699
Cycle the TV's picture format with the zoom button on the remote until you get to the proper setting to display 16:9 as 16:9.
- kelson h
Kelson is offline
post #26684 of 26688 Old 07-29-2015, 10:28 AM
jjeff's Avatar
Quoted: 342 Post(s)
Liked: 139
Not all TVs can format every resolution. Some require SD to zoom while others can zoom or stretch HD, my Sony HDTV can zoom and stretch all resolutions but many of my other TVs can't
jjeff is offline
post #26685 of 26688 Old 07-29-2015, 03:53 PM
Liked: 0
Thanks for all your help. I think I got it.
post #26686 of 26688 Old 07-29-2015, 03:53 PM
Liked: 0
Thanks for your help. I think I got it now.
post #26687 of 26688 Unread Today, 01:33 AM
Liked: 0
Purchased the 557 a few months ago, then over the last several weeks, began noticing that for timer recordings, the WRONG channel would SOMETIMES be recorded. I've had the 513 and 515 for several years, and never encountered this problem, albeit I've had a different problem with the 513 remote. I can deal with the 513 remote issue, but recording the WRONG program is not acceptable. Thank you for any help.
izulu is online now
post #26688 of 26688 Unread Today, 02:14 AM
mrmazda's Avatar
Quoted: 69 Post(s)
Liked: 34
Originally Posted by izulu View Post
Purchased the 557 a few months ago, then over the last several weeks, began noticing that for timer recordings, the WRONG channel would SOMETIMES be recorded. I've had the 513 and 515 for several years...
When it happened, were you trying to record a QAM channel that does not end in .1?
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is online now
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
