Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 893 - AVS Forum | Home Theater Discussions And Reviews
post #26761 of 26782 Old 09-01-2015, 05:24 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 150
Originally Posted by NCAP9 View Post
HI,
I am trying to upgrade the 160MB hard drive on my Magnavox H2160MW9 to 1TB Hard Drive.
I bought the drive (Western Digital 10EURX) and I installed it with ease.
Now my question is when I entered V-SKIP 079 and Press ENTER to START HDD Format
then the screen goes blank and the hard disk makes a few clicking sounds and then
the power seemed to go off and nothing shows up on the screen.
Am I doing something wrong such as this HD drive is too big for this model? But then
I also tried this 1TB drive on my other Magnavox 320MB MDR513H unit, but I got the same blank screen too.
Any ideas or suggestions why this is happening? I will appreciate any feedback.
The last step in upgrading HDDs is to select the HDD drive then press REC and record ~10 sec of anything. That sets up the HDD menus for use.
PHILIPS HD DVRs | *MAG/PHILIPS SD DVDRs* | DVDR/DVR COMPARISONS | POST-DVDR OPTIONS
*If you're logged in, links will only work if your User CP > Edit Options > Number of Posts to Show per Page is set to 30, the default.
wajo is offline
post #26762 of 26782 Old 09-01-2015, 05:40 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
Originally Posted by JoeKustra View Post
You had a link in one of your posts. That link will work only if you use the current default of thirty posts per page. That was the default since the current BBS software was installed several years ago. In a previous version the links were not dependent on that number, so that's why wajo has a note in his signature to use 30. That 30 was also done because this BBS gets very slow if you change the default to 40 or 50 posts per page. I use 40, so if I post a link, I modify the link to work without your default needing to be 30. There are a few options found in the User CP that can be changed.
Ohhhh, ok. All I did was right click that 'permlink' and get the shortcut then paste it in the post.
God Bless,
-Clint
Clint S. is offline
post #26763 of 26782 Old 09-01-2015, 07:11 AM
mkpl's Avatar
Quoted: 13 Post(s)
Originally Posted by Clint S. View Post
... or the left and right edges are slightly "missing" off of the edges? If it's the last one, (which is ok and what I think you're saying), that's sort of how 16:9 is now on 4:3 TV's; it's letterboxed but I can sometimes notice on something like news channels the first letter or two of text at the bottom of the screen (and sometimes the last letter) is chopped off.
Yes, that is what I am seeing, correct aspect ratio, but less cropping on the sides. One last note - those miniboxes run quite hot, don't stack anything on top of them.
Clint S. likes this.
mkpl is offline
post #26764 of 26782 Old 09-01-2015, 11:03 AM
JimLely's Avatar
Quoted: 22 Post(s)
HI,
Due to firmware limitations you are going to be limited to 500 MB on the 2160 and the 513.
ClearToLand likes this.
JimLely is online now
post #26765 of 26782 Old 09-02-2015, 01:47 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
Ok thanks......but I'm still not quite clear on "less cropping on the sides." I understand you're saying the AR is correct, but do you see the entire 16:9 content with some "black" on the left and right sides, or, are you saying a little bit of the left and right sides are missing, like I described? Thanks.
All, I found out some info from Cox:
They are encrypting everything, even the frickin' local channels!
The date of Sept. 7th I was given is just a "begin" date of when the change is going to start to "phase-in". She said there will be (if I remember the term correctly) "peel-back" areas, with certain channels vanishing (from straight-from-the-wall feeds) at a time. Then it will affect another area or zip code, etc., then another group of channels, etc., etc.
Further, you cannot go and get these mini-boxes until your area is affected!! WTF?? So as someone here described; it will indeed be a "mad dash" to the frickin' Cox offices!! So I was told I can't go get the two I need yet, I have to wait until the 7th!
(The purpose of them calling me was I "delightfully" filled out a "Survey" I was sent in an email regarding them allegedly phoning me, but they never once spoke to me! I only communicated with them via email). I was sure to put in my "lengthy diatribe" how I felt regarding what they are doing, and how they've "got everyone by the balls" regarding price increases, along with with my name, address, phone # and account #. I was told via email their *"Customer Loyalty Team" could try and keep my monthly bill (about $170) from getting much higher, which I also mentioned in the survey. (*Since we've been customers for over 40 years). I was shocked I got the call the next day (yesterday).
As it stands now, she said they'd give me one mini-box free for a year, and the 6-tuner Cisco (should be a 9865HDC) for about $18 more a month. (I'm confused on that since she said the DVR would only be $11.99, which I'll ask about when I call her back). Even at $18 more a month for the DVR, that's still a lot cheaper than the $28.50 I was originally quoted.
Buh-BYE 2160A.
So, somewhere around the 7th I'll be getting the mini-boxes and DVR. As I understand it (please correct me and clarify if I'm wrong), that 9865HDC is the same unit used for the Cox WHDVR, so I'm guessing it won't be much trouble to "convert" it to a WHDVR. I was told that no additional cable had to be run for a WHDVR setup, that the host WHDVR "communicates" with the other STB's ("clients") on the existing lines. I'm not sure how exactly that would be possible, but that's what I was told.
BTW, if anyone knows where I can find a 9865HDC manual, PLEASE let me know. I've been looking for over a week and all I can find is the QS Guide and datasheet. Thanks.
God Bless,
-Clint
Clint S. is offline
post #26766 of 26782 Old 09-02-2015, 06:07 AM
Kelson's Avatar
Quoted: 1224 Post(s)
Liked: 765
They will communicate via MOCA which is Ethernet over coax protocol. All your room to room coax runs carrying the cable TV signal are linked to form a coax network through your house.
Now here is the caveat. A whole-house DVR only communicates with whole-house, MOCA-enabled STB's. Those are typically NOT mini-boxes but their full-feature STB's -- which, as you can guess, cost a lot more to rent per month.
I mentioned the following to you before, when you were just starting to figure out what was going to happen with Cox and your options:
You can buy a TiVo Roamio and not pay any monthly fees to Cox. Right now you can buy a TiVo-renewed Roamio Basic/lifetime for $300. You get 4-tuners to eliminate conflicts and an incredible feature set that includes whole-house capability to eliminate more Cox STB's with Mini's. You can hook your magnavox to its composite outputs to capture those shows you want to archive to DVD or just pull them over to your PC. The money you save by returning the STB can be used to pay for the cable card. This will be your cheapest option in the long run. If you are a heavy user of Cox on-demand this will be a problem with a TiVo -- you will either have to compromise or opt for the Cox DVR. The TiVo deal is a steal and will not last long -- normal price for a Roamio Basic/lifetime = $550.
You don't need to use Cox equipment, just their cable card. Now that you know the direction Cox is taking you should put this back into your thinking and calculate your costs and pay-back period vs. paying Cox forever. Some cable companies actually give a credit for users with their own equipment -- you should check with Cox on that.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #26767 of 26782 Old 09-02-2015, 06:25 AM
JoeKustra's Avatar
Quoted: 457 Post(s)
Liked: 214
It seems Cox is rolling out VOD across the country now. It may take a while, but it's a start. http://www.tivocommunity.com/tivo-vb...d.php?t=531534
http://www.tivocommunity.com/tivo-vb...d.php?t=531556
Just saw this at the end of the Cox lineup:
* Digital or HD channel included with service level noted; requires rental of digital receiver or CableCARDTM, except TV sets with Clear-QAM digital tuner may receive local broadcast channels without equipment rental.
I wonder if that will change soon?
JoeKustra is offline
post #26768 of 26782 Old Yesterday, 01:55 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
Are you saying, or are they saying, that VOD is going to work now with rented CableCARD's?
Like I mentioned in that long post above, they told me all channels would be encrypted, even local!
God Bless,
-Clint
Clint S. is offline
post #26769 of 26782 Old Yesterday, 02:02 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
Ok.....fascinating.
Yeah I knew that, there's only one other area that would need to access the host, and it already has a full STB.
Right, I saw that and replied to it when I saw it. That WAS an option, but then I found out they disabled two-way on their rented CableCARD's so that On-Demand wouldn't work! So that's no longer an option and I'm forced to get their DVR, one from them.
God Bless,
-Clint
Clint S. is offline
post #26770 of 26782 Old Yesterday, 04:57 AM
JoeKustra's Avatar
Quoted: 457 Post(s)
Liked: 214
VOD from Cox will, when done, work with a TiVo. A cable card is used in a TiVo. A cable card is a one-way device. There is no cable card in your mini box, so it doesn't support VOD. Also, the way a TiVo will use VOD from Cox will be through streaming internet access, like Amazon and Netflix.
They are not always right. You may have everything encrypted, and eventually you probably will. When it happens it happens. I'm sure you will know when it happens and will let us know. Until then, patience and planning are your best course of action.
tomintn likes this.
post #26771 of 26782 Old Yesterday, 10:03 AM
DoctorM's Avatar
Quoted: 107 Post(s)
Liked: 51
So is this series now completely discontinued or dare we hope for a 2015 model?
I'm trying to get a parent off of VHS, and HD isn't the answer. From what I understand there's really no way to record off a cable box... even with component outputs present(?)
This would be a great stop gap, but I'm having difficulty finding one anymore.
Edit: Walmart still has these? Don't know why I didn't think to try there first. Although I can't believe the price is so high for something SD.
(this space for rent)
DoctorM is offline
post #26772 of 26782 Old Yesterday, 10:32 AM
JoeKustra's Avatar
Quoted: 457 Post(s)
Liked: 214
I can't speak to the future. As for a cable box, it depends on the cable feed and what they supply. I have a DTA with only HDMI and channel 3 for output. My previous actual cable box had composite and rf, but that was before the digital changeover. The best part of the Magnavox is its ability to make and edit a DVD. Not a lot out there for competition. For DVD, SD is good enough. Many on eBay also.
post #26773 of 26782 Old Yesterday, 11:25 AM
mreedelp's Avatar
Quoted: 48 Post(s)
Liked: 26
This thread is STILL about Magnavox/Philips recorders right? Or has it become a Cox bashing thread?
Just need to know so I can either come back or drop it from my lineup.
artisticimaging likes this.
mreedelp is online now
post #26774 of 26782 Old Yesterday, 11:56 AM
cc_in_oh's Avatar
Quoted: 361 Post(s)
Liked: 161
Just my $0.02 but if your parent hasn't progressed from VHS to even a dvd recorder by now, you would just be asking for trouble.
FWIW I record the composite out of my TWC box. S-video should also work if you can find a box that still has it. Some channels like BBCA work fine both live and on-demand, some are record-once, and some don't record at all. Some work live but not on-demand. Some on-demand work in SD but not HD. And anything can change at any time - you get the picture...
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is online now
post #26775 of 26782 Old Yesterday, 12:31 PM
DoctorM's Avatar
Quoted: 107 Post(s)
Liked: 51
eBay might be the best answer. I'm not convinced she's going to take to a DVR.
I recently got my CableCo to switch over a couple boxes. One DTA now only has an HDMI out and the full converter has HDMI and Component/Composite out (no RF). I've heard there might be some sort of 'do not copy' signal on the HD component out, but I'm not familiar enough to know for sure.
DoctorM is offline
post #26776 of 26782 Old Yesterday, 01:05 PM
cc_in_oh's Avatar
Quoted: 361 Post(s)
Liked: 161
Oh wait - I misspoke - I don't use the composite out of my Cisco STB. It goes to a Slingbox 350 on component, then the slingbox's composite goes to the recorder (a 515). I'm not sure but I'm assuming daisy-chaining to the 515 is better than splitting the Cisco's audio output. SO - if component vs. composite affects recordability as you suggest, my results may be sub-optimal. I doubt that's the case though...
CC
post #26777 of 26782 Old Yesterday, 01:32 PM
TV123's Avatar
Just want to say - I have a number of Mag/Philips dvdr's and have Cox (so far un- encrypted) and I'm definitely interested in following this - whether in this thread or another doesn't matter to me.
TV123 is online now
post #26778 of 26782 Old Yesterday, 02:00 PM
JoeKustra's Avatar
Quoted: 457 Post(s)
Liked: 214
Where are you located? You could add that to your data in the User CP. I hope it's not FL. Something in the water.
post #26779 of 26782 Old Today, 01:41 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
"Thanks for your input". If you would have read my first post, you would have seen it's about WTH I was going to do about my 2160A, whether or not I (we) could still use it, and trying to ascertain my (our) options. This is an issue that's of paramount concern for Cox subscribers which use these DVR's. You'd be "bashing" Cox too if you were in this predicament in which millions (and some on this thread) now find ourselves.
God Bless,
-Clint
Clint S. is offline
post #26780 of 26782 Old Today, 02:01 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
This was the same situation I was in a few years ago. What I did (and would still work if it were not for cable co's encrypting everything), was use my 2160A to record basic cable (using its internal tuner, direct from the channel #'s), and then use the STB to record premium channels. Since the 2160A (and all others on this thread, even other DVR's available AFAIK) have no HDMI nor component IN, we're forced to use S-Video, and I use (USED) that output from the STB connected to the L1 input (S-video) on the 2160A. One can still do this, but all recordings are going to have to be from an STB (if you have cable) and gone is the ability to watch one channel while recording another. If you're only OTA, then this is N/A.
And BTW, it looks like I'll be getting rid of my 2160A, so I may be looking for a buyer. It's flawless (still with the protective display clear plastic on it, and box, manual, etc.), but the remote is a bit worn, but also works perfectly.
God Bless,
-Clint
Clint S. is offline
post #26781 of 26782 Old Today, 02:18 AM
Clint S.'s Avatar
Quoted: 20 Post(s)
Liked: 0
Obviously I'm hoping that is soon and I won't have to "rent" one of their DVR's for very long. I asked Cox about this.
Right, I knew that, however (I believe I mentioned several days ago) it appears 2-way cards are available, but that may just be the "technology" using current cards. ?? http://arstechnica.com/uncategorized...ablecard-tech/
That doesn't help me since I don't do any streaming.
.....Until then, patience and planning are your best course of action.
Right.....I've tried to "plan", but I'm forced to remain in a "holding pattern" now since they will not allow anyone to get the mini-boxes until the 7th (as I was told, and I'll get the DVR then), but an article in the newspaper yesterday now says that's the 9th: (I don't know how to tag "TV123")
"The phase-out is happening for all Cox subscribers, from Virginia to California.
Locally, the mini boxes have been available for Cox customers in metro New Orleans since Monday. They will be available for Baton Rouge and Lafayette area subscribers beginning Sept. 9.
The plan is to start shifting some analog channels to digital at the end of October. By late January, all analog programming will be moved over and encrypted."
God Bless,
-Clint
Clint S. is offline
post #26782 of 26782 Old Today, 03:42 AM
JoeKustra's Avatar
Quoted: 457 Post(s)
Liked: 214
If you don't have the original shipping box, a 2160A fits into a large flat rate Priority USPS box. It's the thin box, not the 12x12x6 box.
Cable cards can be two way but nobody programs them that way. That's why the TA was born.
Streaming isn't my friend either, but it can work with good infrastructure.
I guess you'll need the Cox DVR for a while. That's too bad. On the other hand, new stuff comes out every day.
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
