Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 917 - AVS Forum | Home Theater Discussions And Reviews
 149Likes
post #27481 of 27494 Old 11-24-2016, 12:15 PM
joekoler's Avatar
I see Walmart has the Mag 557 back for the "bargain" price of $399. It used to sell for $200-$299. Tis the season for price gouging in America.
joekoler is offline
post #27482 of 27494 Old 11-24-2016, 12:35 PM
cc_in_oh's Avatar
Quoted: 881 Post(s)
Liked: 479
I didn't know they still made the 557? They have the 867 for $280 which seems fairly reasonable...
tomintn likes this.
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is offline
post #27483 of 27494 Old 11-29-2016, 12:45 PM
Ken.F's Avatar
Quoted: 1384 Post(s)
Liked: 1164
I had a weird power failure at my house today. The power went out and came back on about 6 times in 30 seconds, then it stayed out for about 5 minutes. After the 5 minute outage the power came back on for a few seconds and went out again, then a few seconds later it came back on and stayed on. A little while later I noticed my 513 and 515 were both dead. No display on their front panels and they wouldn't respond to the power button. Thanks to wajo and his help file I got both of them working again with a soft-reset.
Ken.F is offline
post #27484 of 27494 Old 11-29-2016, 02:20 PM
mrmazda's Avatar
Quoted: 105 Post(s)
Liked: 41
Originally Posted by Ken.F View Post
I had a weird power failure at my house today. The power went out and came back on about ... times ...
This is why some people use a UPS instead of a surge suppressor or no power protection at all. To us it is not worth the risk of losing equipment we couldn't replace with directly comparable equivalent, if at all.
...Thanks to wajo and his help file I got both of them working again with a soft-reset.
Consider yourself lucky.
rdgcss likes this.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is online now
post #27485 of 27494 Old 11-29-2016, 02:32 PM
Ken.F's Avatar
Liked: 1164
That's good advice. I have my computer, server, NAS, and all of my network gear on UPSs but I don't use the recorders enough to justify the cost of getting two more of them. I should just unplug them when not in use.
I do.
Ken.F is offline
post #27486 of 27494 Old 11-29-2016, 04:15 PM
mrmazda's Avatar
Quoted: 105 Post(s)
Liked: 41
Before the digital age took over satellite TV, it was routinely recommended to unplug everything when leaving home. Now I turn off 5 of my 7 SD recorders only when I expect a power outage to outlast the UPS batteries. IOW, 5 are always on, the other 2 infrequently on. Timer reprogramming after powerdown gets too complicated here to not have everything on backup power.
post #27487 of 27494 Old 11-30-2016, 10:21 AM
cc_in_oh's Avatar
Quoted: 881 Post(s)
Liked: 479
Originally Posted by wajo View Post
2195 for Philips and 1056 for Mags, as described here.
If you can't get 60 buttons learned, you may have to clear/reset button commands, as described on pg 14 of the User Manual (link in help file).
I couldn't get either device code to work in TV mode - maybe it's smart enough to only scan TV models?
Fortunately factory resets freed up enough memory to learn all commands, so I set one up for the 3576 and the other for the 2160A. 3 separate remotes is a bit cumbersome but otherwise working fine...
CC
cc_in_oh is offline
post #27488 of 27494 Old 11-30-2016, 10:27 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 185
It might be "easier" to use the OEM remotes for each unit... they don't interfere with each other?
wajo is offline
post #27489 of 27494 Old 11-30-2016, 11:06 AM
cc_in_oh's Avatar
Quoted: 881 Post(s)
Liked: 479
I only got the Philips after the OEM remotes got to be too hard to use (worn-out OK buttons). There's never been any interference between the 3576 and 2160A...
The first Philips lasted years, maybe 5 or 6, before developing this problem. The new one lasted less than a year, and with much lower usage. I wouldn't recommend it to anyone at this point...
CC
cc_in_oh is offline
post #27490 of 27494 Old Yesterday, 11:13 PM
Clint S.'s Avatar
Quoted: 45 Post(s)
Liked: 0
Guys, can anyone tell me please where I can get another NB300UD remote? (For a 2160A). I still can't find one in searches. This one did not get wet in the flood, but for some reason it hasn't worked the same since and now some buttons have stopped working. I've taken it apart and cleaned it, no help!
God Bless,
-Clint
Clint S. is online now
post #27491 of 27494 Old Today, 04:14 AM
cdjee's Avatar
Liked: 0
3575 hard drive size upgrade
I am checking to see if it is possible to upgrade the size of the hard drive on a 3575h without losing the recordings. I assume it isn't possible but wanted to check first.
cdjee is offline
post #27492 of 27494 Old Today, 08:04 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 185
The OEM remote NC003UD can be found at Amazon and prob. other places as well.
wajo is offline
post #27493 of 27494 Old Today, 08:09 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 185
Info on HW replacement is here.
Info on file transfer is here.
Bottom line is that HDD replacement is relatively straightforward but file transfer is not.
wajo is offline
post #27494 of 27494 Old Today, 10:22 PM
Clint S.'s Avatar
Quoted: 45 Post(s)
Liked: 0
Thanks for the reply. Yeah I saw that one yesterday but it's completely different from mine because mine is an NB300UD. FWIW, below that # is "1VM220543". I tried searching for it and only see a handful of results, nothing for sale except one that costs a fortune. http://mandisremotes.com/im/mandos/T...ba_SER0345.jpg . It's still not the exact same remote, it's closer than the one you linked but still some significant differences! This is odd, and most troubling.
God Bless,
-Clint
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
