Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 919 - AVS Forum | Home Theater Discussions And Reviews
 153Likes
post #27541 of 27563 Old 01-27-2017, 06:53 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Originally Posted by MediaFan63 View Post
Hi, I just picked up a Magnavox MDR535H/F7. Does anyone know of a reasonably priced place to get the original remote other than Amazon/ebay?. I'd like to dub DVD's into the Hard Drive but haven't found a way around the press the dubbing button which I obviously don't have. Thx for any and all replies.
Here's a search page with many options (Sears link won't load?).
(Sorry, forgot the link.)
Charlescollier likes this.
wajo is offline
post #27542 of 27563 Old 01-27-2017, 06:53 PM
MediaFan63's Avatar
Thanks wajo, that's the one.
I remember when products were built to last.
MediaFan63 is offline
post #27543 of 27563 Old 01-29-2017, 05:29 PM
NewABC's Avatar
Quoted: 21 Post(s)
Originally Posted by rmacdona View Post
Yesterday I picked up a Magnavox MDR515H.
Having previously read a post from a fellow Canadian who got his unit home only to find that the DVD tray did not function I considered testing my unit in the store but decided against it.
When I got the 515 home I decided to test the tray first thing so I plugged it in, gave it a few seconds to power up and then hit the open/close button - nothing happened. After a few choice expletives I decided to finish connecting and setting the unit up and tried again. This time the tray opened.
As best I can tell, the tray will not open when the unit is first powered up and the front panel display is displaying a series of dashes. Looks as if you either have to wait longer after powering it up or start the setup procedure before the tray can be opened. Once I had some info displaying on the front panel then everything was fine.
My concern is that anyone who tries to do a cursory check of the unit in the store may just plug it in and hit the open/close button and come to the conclusion that the unit is defective when it is not. Unless you can connect the unit to a television and run through the setup procedure don't jump to any conclusions about its functionality.
Hopefully Wajo can confirm this information and pass it along to the readers before they start abandoning perfectly good units.
The MAG 513 had been unplugged for at least a week. I plugged it in, set the clock and recorded on the HDD. But the DVD tray still won't open (the display obediently shows OPEN and afterwards CLOSE). I have tried using both the remote control and the manual open/close button on the unit. Is there anything else in the "setup" that I have to do to get the tray to open? Or is the tray now damaged?
Thank you
NewABC is offline
post #27544 of 27563 Old 01-29-2017, 05:57 PM
mrmazda's Avatar
Quoted: 113 Post(s)
Liked: 41
It could be broken. You can flip the door down with a flosspick or other plastic tool without damaging anything. Once flipped down you should be able to pull the tray out with subtle force. If you look carefully you might be able to find a manual eject button like can be found on most old CD and DVD drives on computers, in that same location down low about 30-35mm from the right side of the tray. A straightened large paper clip is usually the recommended tool for this button if it has one.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is online now
post #27545 of 27563 Old 01-30-2017, 10:02 AM
NewABC's Avatar
Quoted: 21 Post(s)
Thank you for replying.
Flipped down door with fingers. Tried prying out tray while display said "open" but it would not budge. No manual eject button.
NewABC is offline
post #27546 of 27563 Old 01-30-2017, 10:54 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Before tearing into the machine/DVD drive:
1. Try a Soft Reset, # 2 as described here.
2. If no joy, try a Hard Reset, # 3 as described here.
wajo is offline
post #27547 of 27563 Old 01-30-2017, 02:22 PM
NewABC's Avatar
Quoted: 21 Post(s)
thank you wajo for pointing me to that. I tried both and neither helped. The machine's software knows it's supposed to have opened the tray and keeps track of that because when I press the button a second time it displays "close". But something in the hardware is failing.
NewABC is offline
post #27548 of 27563 Old 01-31-2017, 06:50 AM
NewABC's Avatar
Quoted: 21 Post(s)
The seller sent me a note that he may have left a disk in the DVD drawer and that's why it's stuck and not opening. If that's true, is there anything that can be done to get it out? I am not familiar with, nor comfortable mucking around in, equipment internals
NewABC is offline
post #27549 of 27563 Old 01-31-2017, 07:20 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I'm not a skilled repair guy but I opened my recorder to publish some repair ops without any problems at all.
Here's some procedural stuff on how to remove the machine's cover, remove a DVD, etc. (scroll down to find what you need).
wajo is offline
post #27550 of 27563 Old 02-03-2017, 06:41 AM
NewABC's Avatar
Quoted: 21 Post(s)
I opened the unit and there wasn't a DVD in the tray. I manually opened and closed the tray a few times with the gear, closed the unit and now the tray is opening/closing perfectly, with both the remote control and the panel button. It seems the rough shipping got it off track. Thank you everyone for your help.
I need to re-arrange things in my room and need to know if two Mag units can be stacked one on top of the other. The lower unit (557) would still be plugged in (Standby Mode) as it is my backup unit. If I had to use it again, as I have the past three weeks, I don't want to have to go through the lengthy setup process. (I keep a small towel over the infrared sensor so it doesn't respond to commands for the other unit.)
Is there a concern about not having air space for the lower stacked unit and the Standby Mode generating heat that could affect it?
Thank you.
NewABC is offline
post #27551 of 27563 Old 02-03-2017, 06:50 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
The air vents from side to back. These units don't get hot.
For individual control of multiple units with the same remote, you can more easily use a "Kluge," as described here.
Or you can get a Universal remote like the one described here.
wajo is offline
post #27552 of 27563 Old 02-03-2017, 06:52 AM
mrmazda's Avatar
Quoted: 113 Post(s)
Liked: 41
I have a 4-high stack with no apparent heating issues. I do have added feet about 1/8" thick to add a little more air space in between. I block the extra IR ports with thin cardboard painted black and with grab tabs made of ordinary tape.
post #27553 of 27563 Old 02-03-2017, 08:41 AM
NewABC's Avatar
Quoted: 21 Post(s)
Thank you wajo.
In your picture, your units are on open shelves. My shelves are only semi-open. I have about 7"-8" venting space behind the units so that should be sufficient. But about 1" venting space on each side. Do you see a concern with the sides?
And I really like your kluge
NewABC is offline
post #27554 of 27563 Old 02-03-2017, 08:44 AM
NewABC's Avatar
Quoted: 21 Post(s)
Thank you mrmazda. Perhaps I can get some soft furniture leg coasters to place between the units for elevation.
NewABC is offline
post #27555 of 27563 Old 02-03-2017, 09:09 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Thank you wajo.
Should be no problem. For your peace of mind, check unit for heat after a long recording session?
wajo is offline
post #27556 of 27563 Old 02-03-2017, 10:20 AM
NewABC's Avatar
Quoted: 21 Post(s)
Thanks again, wajo. I'll check it.
A separate question: I've seen many posts referring to the 513's w/72A FW upgrade and associated upgraded functions/features. Is there any command that would show whether a unit has that upgrade installed?
NewABC is offline
post #27557 of 27563 Old 02-03-2017, 10:46 AM
Quoted: 866 Post(s)
Liked: 349
Post 703. Post 1 has links to everything.
This might work: http://www.avsforum.com/avs-vb/showpost.php?p=13686310
It takes a few seconds to get the right page.
JoeKustra is online now
post #27558 of 27563 Old 02-03-2017, 01:48 PM
NewABC's Avatar
Quoted: 21 Post(s)
Thank you JoeKustra. The page(s) came up.
NewABC is offline
post #27559 of 27563 Unread Yesterday, 07:23 PM
Liked: 0
I've been using a Magnavox MDR533H HDD & DVD Recorder for a few years and it's been great -- does everything I could have possibly imagined.
But for the last few days it's been displaying closed captions, even though all the closed caption options available through the menu are OFF. I've fooled around with the options, trying to make the letter (which are white) and the background (which is black) both transparent, but the machine completely ignores those instructions and keeps displaying the white closed captions on a black background. I tried turning the settings OFF again, and that does nothing -- keeps displaying them. I tried unplugging the machine, but that did nothing.
I run two of my cable company's (Shaw Cable of Canada) boxes (Motorola DCX 3200-X) through Line 1 and Line 2 of the Maganavox. On both boxes, the closed caption settings are OFF. When I pipe the signal dircectly from the cable boxes to my TV through an HDMI cable, there are no closed captions. Go back to piping it through the Magnavox, and there they are again.
If anyone can help with this really annoying problem, I'd be much grateful.
Leonard Smith is offline
post #27560 of 27563 Unread Yesterday, 07:32 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
But for the last few days it's been displaying closed captions, even though all the closed caption options available through the menu are OFF...
As a start, try a Soft Reset, as described here.
If no joy, try a Hard Reset (# 3) described next.
wajo is offline
post #27561 of 27563 Unread Yesterday, 10:15 PM
Liked: 0
Thanks for the reply, wajo. I've been fooling around with the menu on my TV. Seems there's a closed caption setting that was on -- I don't know how as I haven't been into the TV menu in months. It seems to have solved the problem, at least for now. But I am archiving the info in your reply and will try it if the problem returns.
Can't thank you enough for the reply, but thanks a thousand anyway.
post #27562 of 27563 Unread Today, 11:36 AM
mrbway's Avatar
Liked: 0
MDR557H Deleting All Titles
I have 3 Mag DVRs stacked. Use kluges consisting of aluminum foil sandwiched between 2 sheets of construction paper to block IR remote from 2 of them when I'm using remote on any one. Never any problems with older gen DVRs, but I accidentally wiped all titles on MDR557H twice. At least I assume it was my fault & not spontaneous erasure. Question 1: what am I doing wrong? Question 2: Does "Delete All Unprotected Title" on HDD Menu mean there's some way to PROTECT recorded titles on the hard drive? If so, how?
mrbway is online now
post #27563 of 27563 Unread Today, 12:23 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
In Title List, select a title then EDIT > PROTECT (it's a toggle function ON/OFF).
wajo is offline
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
