Magnavox 557, 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 921 - AVS Forum | Home Theater Discussions And Reviews
 165Likes
post #27601 of 27617 Old 05-19-2017, 06:41 PM
JER01's Avatar
Quoted: 12 Post(s)
Originally Posted by mrmazda View Post
Pictures can be made smaller either by reconfiguring the camera before shooting, or by resizing those already taken with any of many different image manipulation programs, such as Irfanview, GIMP, Photoshop or whatever was on the media that came with your digital camera. We need to see what you mean by mottled. Note too that lack of swelling or leakage is no guarantee the surge produced no hidden damage. A weak or failing cap can easily be reduced to useless via electrical overload.
Also, make a list of the brand names you see on each along with each's 5-character position stenciled adjacently on the board. The more Enercons you find, the more likely cap replacement could be a solution. Skip the little ones C2201, C2206, C2214 if you want. The name on the one under the DVD drive you might not be able to see.
These old eyes may not be up to doing what you asked for unless I tear the whole thing apart first. Looking at an angle with the glare, it is very difficult for me to read.
But at a quick look:
They are almost all a bluish purple [ maybe all] and I think I see: Su'scon on the side. Even the biggest one near the power cord looks like this. Plus a couple medium size ones in the area. The ones near the power cord have the heaviest mottling.
The tops of new caps have a uniform fairly shiny surface. By mottling, I mean that shiny surface is no longer uniform -- parts of it have turned into an oxidized non uniform looking surface. So a mix of shiny and various shades of oxidized. But NOT starting at the edge of the cap top.
There's a few under the HDMI circuit board that look the same purple color as the exposed ones. But they are pretty small. There are not any hidden by the DVD drive as far as I can tell.
Here is a PRELIMINARY list of caps in the power circuit:
C2223, CC2204 [ the largest], C2206, C2205, C2216, C2201, C2207, C2204, and further on the side C 2210. I am not seeing the method to the madness here. No correlation between the size and the number?? I am assuming D is for diode, R is for resistor??
I will get into this more tomorrow.
Thanks for your help on this mrm
Jer
JER01 is offline
post #27602 of 27617 Old 05-19-2017, 07:04 PM
mrmazda's Avatar
Quoted: 135 Post(s)
Liked: 49
The list I wanted might look something like so:
Code:
C2104 HEC
C2201 ENERCON
C2202 ENERCON
C2203 Su'scon
C2204 Su'scon
C2205 Su'scon
C2206 ENERCON
C2207 ENERCON
C2210 ENERCON
C2214 ENERCON
C2216 Su'Scon
The numbers that relate to size are the uF and V specifications on each cap, not the number stenciled on the board.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is offline
post #27603 of 27617 Old 05-19-2017, 09:13 PM
JER01's Avatar
Quoted: 12 Post(s)
Code:
C2104 HEC
C2201 ENERCON
C2202 ENERCON
C2203 Su'scon
C2204 Su'scon
C2205 Su'scon
C2206 ENERCON
C2207 ENERCON
C2210 ENERCON
C2214 ENERCON
C2216 Su'Scon
All the numbers I gave you are Su'scon. In fact, I am pretty sure all the caps in my 2160 are Su'scon
JER01 is offline
post #27604 of 27617 Old 05-20-2017, 02:48 PM
JER01's Avatar
Quoted: 12 Post(s)
Well here are the photos in a compressed file size. Most of them are taken from the rear of the 2160. A couple were taken from the side. I included close ups of the HDD and the DVD drive as general info for those who have never taken their unit apart.
For some reason the files were posted in reverse order. You may want to start at the bottom and work your way up to the top. The bottom photo gives you a view of the whole unit as viewed from the top rear of the unit. This will help you gain insight into where the close ups were taken from.
Jer
ID:	2148146   Click image for larger version
ID:	2148154   Click image for larger version
ID:	2148162   Click image for larger version
ID:	2148170   Click image for larger version
ID:	2148186   Click image for larger version
ID:	2148194   Click image for larger version
ID:	2148202   Click image for larger version
JER01 is offline
post #27605 of 27617 Old 05-20-2017, 03:57 PM
JER01's Avatar
Quoted: 12 Post(s)
Here it is in two formats
SORRY -- It lost its formatting after I hit PUBLISH!!!
All caps except those under HDMI board C Mfg Size 1007 Su'scon S 1085 Su'scon S 1102 Su'scon S 1122 Su'scon S 1175 Su'scon S 1176 Su'scon S 1185 Su'scon S 1186 Su'scon S 1201 Su'scon S 1202 Su'scon S 1212 Su'scon S 1221 Su'scon S 1222 Su'scon S 1418 Su'scon S 1419 Su'scon M 1420 Su'scon S - M 1421 Su'scon S 1501 Su'scon M 1605 Su'scon S 1608 Su'scon S 1609 Su'scon S 1610 Su'scon S 1701 Su'scon S 1702 Su'scon S 1703 Su'scon S 1710 Su'scon S 1715 Su'scon S 1723 Su'scon S 1727 Su'scon S 1752 Su'scon S 1752 Su'scon S 1757 Su'scon S 1759 Su'scon S 1760 Su'scon M 1761 Su'scon S 2201 Su'scon S 2202 Su'scon M 2203 Su'scon M 2204 Su'scon L 2205 Su'scon M 2206 Su'scon S 2207 Su'scon M 2210 Su'scon M 2213 Su'scon S 2216 Su'scon M
Power Circuit Fwd of HDMI Board Fwd of HDD Rear of HDD C Mfg Size C Mfg Size C Mfg Size C Mfg Size 1 2202 Su'scon M 1608 Su'scon S 1186 Su'scon S 1419 Su'scon M 2 2204 Su'scon L 1609 Su'scon S 1185 Su'scon S 1420 Su'scon S - M 3 2206 Su'scon S 1605 Su'scon S 1175 Su'scon S 1418 Su'scon S 4 2213 Su'scon S 1610 Su'scon S 1761 Su'scon S 1421 Su'scon S 5 2205 Su'scon M 1501 Su'scon M 1176 Su'scon S 1212 Su'scon S 6 2216 Su'scon M 1757 Su'scon S 1122 Su'scon S 1202 Su'scon S 7 2203 Su'scon M 1759 Su'scon S 1752 Su'scon S 1201 Su'scon S 8 2201 Su'scon S 1085 Su'scon S 1102 Su'scon S 1221 Su'scon S 9 2207 Su'scon M 1007 Su'scon S 1222 Su'scon S 10 2210 Su'scon M + some under HDMI Board 1723 Su'scon S 11 I can see 7 -- 2 M 1701 Su'scon S 12 1715 Su'scon S 13 1702 Su'scon S 14 1703 Su'scon S 15 1710 Su'scon S 16 1727 Su'scon S 17 1752 Su'scon S 18 1760 Su'scon M
JER01 is offline
post #27606 of 27617 Old 05-20-2017, 04:13 PM
mrmazda's Avatar
Quoted: 135 Post(s)
Liked: 49
Relevant formatting would be saved by wrapping code tags around plain text, which you should be able to do yet by editing and stripping the HTML. But given all were Su'scon, the entire post as written was pointless. Better just to delete it.
mrmazda is offline
post #27607 of 27617 Old 05-20-2017, 04:42 PM
JER01's Avatar
Quoted: 12 Post(s)
Would you mind explaining this. I don't understand what you mean by that. It would be good info to have for next time. I copied the data from Excel. It looked ok In the edit box. But lost it when I published it.
Jer
JER01 is offline
post #27608 of 27617 Old 05-20-2017, 04:58 PM
Ken.F's Avatar
Quoted: 1570 Post(s)
Liked: 1354
Jer
Use a code box whenever you want to prevent the forum's wordwrap from messing up your formatting. Highlight everything you want to put in a code box then click on the hashtag button in the tool bar at the top.
Code:
If you quote my post you will see the code tags in this section of my reply.
Ken.F is offline
post #27609 of 27617 Old 05-21-2017, 08:59 AM
JER01's Avatar
Quoted: 12 Post(s)
Code:
Thanks Ken. I understand it now. Appreciate your help.
Jer
JER01 is offline
post #27610 of 27617 Old 05-21-2017, 11:54 AM
JER01's Avatar
Quoted: 12 Post(s)
Code:
Hi Ken
I just tried this with my Excel data _ 4 columns X about 40rows
I copied the data from excel to the edit screen here
I then highlighted the data I just copied over
Then I hit the # sign on top of the edit box
I did not see the code tags. The data looked a little different.
I hit save changes
The formats were not preserved. It looked just like original attempt I made above.
Are you sure this works on Excel Data???
Jer
JER01 is offline
post #27611 of 27617 Old 05-21-2017, 01:03 PM
Ken.F's Avatar
Liked: 1354
I don't have Excel so I have no idea. Maybe someone else with more experience with that kind of thing can help you.
Ken.F is offline
post #27612 of 27617 Old 05-21-2017, 01:41 PM
Quoted: 900 Post(s)
Liked: 363
Jer
Code:
This is code with spaces     and    spaces.
Highlight the text, then hit the # icon before the <> icon.
For Testing: http://www.avsforum.com/forum/46-post-testing-area/
JoeKustra is online now
post #27613 of 27617 Old 05-22-2017, 08:40 AM
JER01's Avatar
Quoted: 12 Post(s)
Originally Posted by JoeKustra View Post
Code:
Thanks Joe. That's what I did. Twice.
Jer
JER01 is offline
post #27614 of 27617 Old Yesterday, 11:11 AM
Kelson's Avatar
Quoted: 1972 Post(s)
Liked: 1161
OK, so what has happened to "wajo".
Two weeks ago he changed his name to a number, "7558037".
His profile shows he hasn't posted since 5/1/17.
His profile lists no AVS login activity since the name change.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #27615 of 27617 Old Yesterday, 11:35 AM
Ken.F's Avatar
Liked: 1354
I hope everything is OK. Hopefully he's just taking a break for a while. After maintaining this thread for all these years he deserves a break.
Ken.F is offline
post #27616 of 27617 Old Yesterday, 12:20 PM
plplplpl's Avatar
Quoted: 12 Post(s)
Liked: 26
Hope he's OK. He's something of a living legend on this board. Hope he can remain among us long enough to see this thread reach a venerable 1,000 pages.
plplplpl is online now
post #27617 of 27617 Old Today, 02:05 PM
ClearToLand's Avatar
Quoted: 33 Post(s)
Liked: 39
Question What Happened to Wajo?
YEARs ago, when I bought my first Magnavox 2160 and initially found this forum, GOOGLE research led me to, IIRC, VCDHelp (or whatever name it goes by now) and Wajo "was " there "in force". But, apparently something 'upset him' because he changed his name (to something similar - i.e. wajo_1234) and DELETEd *MANY* of his posts. That was my first thought when I saw what happened here...
BTW, if anyone knows what state he lives in, someone could try the different area codes and see if 7558037 is a telephone number.
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
Magnavox Mdr515h 500gb Hdd And Dvd R With Digital Tuner
