Panasonic DMR-E80H (80 GB) DVD Recorder - AVS Forum
post #1 of 11 Old 12-03-2007, 10:58 AM - Thread Starter
despat's Avatar
Hi,
I'm looking for a way to make a personal cpy of commercial DVDs after editing the foul language and nude scenes so that my kids can watch them. Can I do it with a Panasonic DMR-E80H (80 GB) DVD Recorder. For instance, first a make a dycrpted copy of the DVD then use that copy to burn to HDD or DVD-RAM while editing on-the-run. Is this possible. I really don't even need to make a 2nd (edited DVD copy) if it can remain on the 80GB HDD that comes with the Panasonic DMR-E80H (80 GB) DVD Recorder.
Please advise if this is possible or feasible with reasonalble qualitiy. I also have a Dell laptop (with an HP analog TV Tuner that accepts RC cable only), if that helps.
Thank you!
despat is offline
post #2 of 11 Old 12-03-2007, 07:57 PM
gerrytwo's Avatar
You can edit anything you have on the hard drive, although I usually would just edit out commercials. As others have noted, with the E-80, you should try to make your edits when there is a black interval or there will be a freeze frame at the edit point. If there is audio, you will lose a fraction of a second of audio at the edit point. The E-80 does not do frame accurate edits but I have found it to a very easy unit to use to make deletions.
gerrytwo is online now
post #3 of 11 Old 12-03-2007, 11:22 PM
Digaman's Avatar
NO! NO! NO!
Let me tell you about my experience. A few years back, I recorded an episode of ER on my DMR-E80H. I missed the start of the show, but I happened to be recording the same channel on my new Zenith XBR413. In order to make a complete episode for archiving, I figured I would copy the start of the show to the hard drive of the DMR-E80H. So, I fired up my PC, imported the video that I recorded on the XBR413, and wrote it back out to DVD-RAM. (You cannot copy from DVD-R to the HDD on the E80). When I tried to copy the video to the E80's hard drive, it didn't work the first time. I should have taken the hint. After a few tries, it finally worked...sort of. Although the title showed up in direct navigator, it could not be played or copied. In fact, I couldn't even delete it! So now, 3 years later, I still have this corrupted title on my hard drive. It just sits there, taking up space. I suppose one of these days I'll get everything off the hard drive and reformat it.
When you "make a decrypted copy," you're re-encoding the movie on your computer. The DMR-E80H may or may not be able to handle the new bit rate/compression/whatever. If you try to put stuff on the HDD that was not recorded on that recorder (or similar), you could corrupt the hard drive or worse.
BOTTOM LINE: Don't do it! It's not worth the risk. Since you're importing the video into your computer anyway, why not do the editing there?
Digaman is offline
post #4 of 11 Old 12-04-2007, 08:50 PM
Westly-C's Avatar
Quoted: 57 Post(s)
Liked: 63
You can't make copies of commercial dvds on the e80, unless you use a dvd player connected to the recorder thru some kind of filter that removes the copy protection.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #5 of 11 Old 12-05-2007, 06:38 AM
gerrytwo's Avatar
My original posting is correct. If you feed the signal of a DVDR with no copy protection (decrypted) from a DVD player to the video (preferably S-video) and audio inputs of the E-80, the E-80 will record that signal on the hard drive.
post #6 of 11 Old 12-05-2007, 08:52 AM
Digaman's Avatar
Yes, that would work. However, it's not clear if that's what the original poster was attempting to do. His post is open to interpretation. My interpretation was that he wanted to make a decrypted copy of the DVD on his computer, copy the content to the E80H hard drive (using the dubbing function), edit the content on the E80H, and then copy it back to DVD. If that's the case, it would be better to simply edit the decrypted copy on his PC. On the other hand, if he is using a video enhancer like Sima, your method would be easier. There is also a third option: clearplay.com .
Digaman is offline
post #7 of 11 Old 12-05-2007, 05:11 PM - Thread Starter
despat's Avatar
Thank you all the the wonderful response.
EDIT:: I don't know why I mentioned VHS to DVD (I got confused with another post). What I really want is a way to edit my commercial DVD so as to remove foul language and nude scenes so my kids can watch them. I've droped the idea of getting the E-80 (to expensive). I'm aware that connecting a Toshiba HD-A20 DVD player directly into the RCA input on an anolog tuner card is not going to be enough. So what's the cheap way to edit and at the same time get a reasonable quality image on the Hard drive of the computer?
despat is offline
post #8 of 11 Old 12-05-2007, 05:47 PM
gerrytwo's Avatar
Best of luck using a computer software program and video card to create a DVD.
As the owner of an E-80, you made the right decision not to buy a used one, they start having problems at the three year mark as parts wear out.
post #9 of 11 Old 10-17-2008, 10:42 AM
Chingu808's Avatar
Question about the Panasonic DMR-E80H. When you finalize the dvd and play back does it have a title bar or thumb nail to click on the opening scene or does it start to play immediately? I know on the E-500 you have the option in th menu of doing one or the other but not sure about the E80.
Chingu808 is offline
post #10 of 11 Old 10-17-2008, 10:51 AM
AVS Club Gold
wajo's Avatar
Quoted: 38 Post(s)
Liked: 134
Here's a page with several options for DVD players and recorders that can filter foul language, but the nude scenes....?
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
wajo is offline
post #11 of 11 Old 10-17-2008, 03:42 PM
Semaphoric's Avatar
You get the Top Menu - no thumbnails, just text.
Semaphoric is offline
User Tag List
