Magnavox ZV450MW8 problem viewing recorded discs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-28-2008, 06:03 AM - Thread Starter
titantn24's Avatar
I bought the Magnavox ZV450MW8 VHS/DVD recorder combo for the main purpose of transferring some old tapes to dvd. Recently, I've recorded some programs from television (analog cable). When I go to watch them on the same unit I recorded them with, there is no problem. But when I try to watch them on another player, nothing happens. Is there something I'm forgetting to do when doing the recording process? I didn't see a "finalize" option or anything when completing a recording. I felt like an idiot when letting a co-worker borrow one of these recorded discs only to find that she couldn't watch it. I thought for a moment that it could be the format that's the issue as these are +R dvds, but she tried it in two different players and her PC with no success. My other dvd player at home plays +R and it won't play on it either. Any help anyone can provide will be much appreciated. Thanks in advance.
titantn24 is offline
post #2 of 14 Old 01-28-2008, 06:05 AM
Guest
Quoted: 38 Post(s)
Liked: 198
The Finalize option is in the Disc Edit menu.
7558037 is offline
post #3 of 14 Old 01-28-2008, 08:10 AM - Thread Starter
titantn24's Avatar
Thanks. I will give that a try. I'm assuming I can still go back and finalize any discs that I've recorded previously?
post #4 of 14 Old 01-28-2008, 08:19 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Yes, you can wait.... just don't wait too long. I've read of many people who waited until their unit went bad and they couldn't finalize lots of discs. They had to somehow find the same model/mfgr, etc.
7558037 is offline
post #5 of 14 Old 08-16-2008, 08:32 PM
ZV420MW8's Avatar
To finalize a ZV450MW8 disc (Manavox dvd recorder vcr combo model ZV450MW8). Using remote press stop button (Black Square) twice. Press SETUP button > Disc Edit > Finalize > Yes. Use up, down and ok button to navigate thru the menus.
ZV420MW8 is offline
post #6 of 14 Old 08-18-2008, 08:48 AM
acwai's Avatar
I had a problem with a DVD+R disc, my Philips HDD recorder would not let me finalize the disc (finalize option was grayed out). I put the disc into my Panasonic DVD recorder, it allowed me to finalize the disc.
acwai is offline
post #7 of 14 Old 08-18-2008, 09:28 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Odd that the Panny finalized a Philips disc!?
Anyway, your Finalize option was greyed out cuz there must have been a timer rec program that was supposed to start within 1-hour... "Finalize" won't be available even 59 minutes before start of a timer rec program.
When I run into that, I use one of my other 3575's, but if I didn't have more than one, I'd either wait till after the timer rec program is done, or delete the timer rec, Finalize, then re-enter the timer rec program.
7558037 is offline
post #8 of 14 Old 08-18-2008, 11:01 PM
Rammitinski's Avatar
Methinks you may have accidently gotten your discs confused.
Rammitinski is offline
post #9 of 14 Old 08-19-2008, 08:09 AM
acwai's Avatar
No. I did not get the disc confused. In fact, it also removed the empty title from the disc.
Thanks Wajo,
Now I know why the finalized disc option was greyed out.
acwai is offline
post #10 of 14 Old 08-19-2008, 08:19 AM
Guest
Quoted: 38 Post(s)
Liked: 198
Wow! You might have found a great feature?
What model Panny did you use?
7558037 is offline
post #11 of 14 Old 08-19-2008, 08:26 AM
acwai's Avatar
I am using a Panny DMR-EZ17 DVD recorder.
acwai is offline
post #12 of 14 Old 12-03-2008, 11:40 AM
Totalcontrol's Avatar
Does anybody have any universal code files for the Magnavox ZV450MW8 ? Pronto, Marrantz, URC, anything would be great. If you send me a file I would be happy to provide you with a file of graphics for your remotes free of charge.
Thanks in advance,
Vincent
Please email to : Vincent at totalcontrolremotes dot com
Total Control Remotes
www.totalcontrolremotes.com
Totalcontrol is offline
post #13 of 14 Old 09-02-2012, 07:53 PM
Iffy50's Avatar
Thank you so much for writing this! I was messing with it for 45 minutes! I read this and I was in business in 15 seconds! smile.gif
Iffy50 is offline
post #14 of 14 Old 12-12-2012, 07:01 PM
Nilz Fullerton's Avatar
Thank You so much for this concise, accurate, and LIFE-SAVING help! Those sites that claim to offer free downloads of manuals I have found to be a confusing runaround. You have TRULY made my YEAR! Bless YOU!
Nilz Fullerton is offline
