Cable extension for Sony HT-CT100? - AVS Forum | Home Theater Discussions And Reviews
Old 05-10-2008, 09:16 AM - Thread Starter
joeykoolaids's Avatar
I just got my HT-CT100 from SonyStyle and it sounds great.
The problem is the cable that feeds the sound bar is to short. My TV is wall mounted and that is the plan for the bar. The sub will only be about 5 ft. to the right of the bar, but there is a doorway in between. My plan was to go up, into the attic, and drop it back down.
With the 10 ft supplied I would only need to extend it another 10ft or so. Sony support said that it is not recommended and had no such extension. I can find 10' DB9 M/M cables (I think that is the connection I will need), but I'm not sure how they will transport the signal.
Any advice is appreciated......thanks
joeykoolaids is offline
Old 03-03-2009, 05:49 PM
deadsexy's Avatar
bump!
I have the exact same question 8 months later lol
deadsexy is offline
Old 03-03-2009, 06:49 PM
da1writer's Avatar
You can extended it by grabbing a 9-pin serial cable.
http://reviews.cnet.com/9602-12576_7...&tag=mncol;txt
PSN- da1writer
My Sony CT-100 Settings (& PS3 Settings) *UPDATED 1/10/09*
http://www.avsforum.com/avs-vb/showt...7#post15172017
da1writer is offline
Old 12-28-2009, 03:35 PM
severenz's Avatar
I wanted to point out that I tried a 9-pin straight-thru serial cable extension and encountered the following problems:
1. Volume on Soundbar was muffled, quieter, and missing higher frequencies
2. Remote control would would no longer work - was not recognized by soundbar
As soon as I removed the extension cable, all problems disappeared. I'm guessing that since power goes through the cable, that the length was affecting the power that got to the soundbar.
This is a disappointment for me because I really needed the extra length.
severenz is offline
Old 01-31-2010, 11:52 AM
mpcreech's Avatar
I just purchased and installed the following cable with my Sony HTC100:
Go to monoprice.com and search item 442 - it is a 6 ft 9 pin extension cable.
The sound is exactly the same and the remote works without any problems. Not bad for less than $2!
mpcreech is offline
