Replacing my HTIB - AVS Forum
post #1 of 4 Old 08-23-2008, 01:58 PM - Thread Starter
__Josh125__'s Avatar
My existing system is a little long in the tooth and the receiver is flaky with powering off, loosing signal lock, etc etc.
I appreciate everyone's time in helping us pick a new system. For starters:
Budget: $500
Existing Receiver
Existing 5.1 Speakers
Room: 18'x17' with vaulted ceilings
Want to stay with a 5.1 system.
I am looking hard at the Polk RM6750 system or the Athena WS-15 speakers. I'm not in a hurry to upgrade the sub and in fact it's not half bad. The receiver does need to be changed for reasons I talked about above. I like the form factor of the mountable speakers, however not sure if I will hear an improvement over the speakers I have.
Thanks all !
__Josh125__ is offline
post #2 of 4 Old 08-23-2008, 03:55 PM
fireman325's Avatar
Since you have a working set of speakers, personally I would put the majority of that budget into replacing the receiver and worry about replacing the speakers down the road. What kind of features are you looking for in a receiver?
Steve
fireman325 is offline
post #3 of 4 Old 08-23-2008, 04:12 PM
afrogt's Avatar
Quoted: 37 Post(s)
Liked: 346
I don't think the Polk 6750 speakers will be that much different than your exisiting JBL's. Like the previous response said, spend your money on the receiver.
Afro GT
afrogt is offline
post #4 of 4 Old 08-24-2008, 09:37 AM - Thread Starter
I have very simple needs, right now the receiver just functions as a 5.1 system with no video interface or switching. I guess it would be nice, however but I have zero experience with that.
Currently I feed the TV via HDMI direct from the HDDVR and then run optical to the receiver. I also have a DVD player that runs component directly to the TV and coax to the receiver. Throw a analog Wii in the mix and that about does it.
If I were to upgrade the speakers I could set them on shelves I guess but wouldn't know where to start with a decent set of bookshelf speakers.
Reply Home Theater In A Box
User Tag List
