Need advice with AV receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-20-2008, 08:03 PM - Thread Starter
doza73's Avatar
Guys:
I am using Panasonic HT 940 HTIB / Panasonic TH-50PX60U ( Plasma TV )-- just purchased Sony S-550 Blue Ray Player -- My problem is that the HT-940 receiver does not have any HDMI -- Optical / Coax inputs. I will connect the S-550 player straight to TV for video but the only option for audio is the standard red / white connections. I am trying to decide if it would be better to purchase a new 1.3 AV receiver with HDMI / Optical connections & keep the speakers or purchase a new HTIB with HDMI / Optical connections.
doza73 is offline
post #2 of 9 Old 12-20-2008, 11:05 PM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
I would purchase a new 1.3 AV receiver with HDMI / Optical connections for now. Then upgrade the speakers when you can afford to. If you get another HTIB you are likely going to be having input limitation again.
HDMI Guy is offline
post #3 of 9 Old 12-20-2008, 11:45 PM
kingtz's Avatar
Depends on how much you want to spend. Hard for people to offer suggestions without a stated budget.
kingtz is offline
post #4 of 9 Old 12-21-2008, 07:37 AM
m_vanmeter's Avatar
as mentioned above, without more info, the entry level a/v receiver that meets your requirements is the Onkyo SR606 or Pioneer 1018
m_vanmeter is offline
post #5 of 9 Old 12-21-2008, 07:45 AM - Thread Starter
doza73's Avatar
In the $500 --- $750 Price Range
doza73 is offline
post #6 of 9 Old 12-21-2008, 08:49 AM - Thread Starter
doza73's Avatar
I see Circuit City has the Denon 7.1 Dolby and DTS Home Theater Receiver
Model #: DEN AVR888 for $499 -- what do you think about this receiver
doza73 is offline
post #7 of 9 Old 12-21-2008, 09:00 AM
Tulpa's Avatar
Liked: 61
It's not bad, but you could get the Onkyo TX-SR606 which does hi-rez audio over HDMI for about the same price (or a little less) from CC.
The Denon has analog inputs, and fortunately the Sony Blu-Ray player you have has analog outputs, so if you have your heart set on the Denon, you can have the hi-rez audio. But it looks like an older model. You could get the Onkyo TX-SR506 for $270 or less that will do much of the same stuff.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #8 of 9 Old 12-21-2008, 03:31 PM - Thread Starter
doza73's Avatar
Thanks a lot -- Think I will go with the Onkro SR-606
just a couple more questions / issues ( I am not much of a sound / audio guy -- I am more of a computer guy ) anyway here are my questions
1. HDMI cables -- is their any big advantage on buying the much more expensive Monster Cables verses the say Sony / Panasonic brands
2. Here are my Panasonic HT-940 Receiver Specs -- RMS Output Power
Front Ch ---- 190 W / Channel
Surround Ch ---- 90 W / Channel
Center Ch ---- 320 W Channel
Subwoofer ---- 320 W/ Channel
Total 1200W
How does compare to the Onkro SR-606
Like a said earlier I am not much of audio guy -- not sure how a 1200 Watt receiver can be compared to a 600 watt receiver
Thanks again for all the help
doza73 is offline
post #9 of 9 Old 12-21-2008, 04:08 PM
Facilman's Avatar
None whatsoever. Anything with Monster on the package is guaranteed to be horribly overpriced. Check out forum sponsor Monoprice.com for well-regarded cables at much cheaper prices (I'm a happy customer). Don't let the low prices fool you. Any cable you get from them will be every bit as good as transmitting that digital info as the high-priced Monster stuff.
Facilman is offline
Reply Home Theater In A Box
