Yamaha HTR-6030 and a PS3 - not getting 5.1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-12-2009, 11:58 AM - Thread Starter
pb32's Avatar
so i've gotten my ps3 hooked up to the htr-6030 through an optical cable, with the video coming from the ps3 through hdmi. i researched and have the ps3's audio output settings as optical and bitstream, and have been able to get 5.1 audio from the ps3 on most blu-ray discs.
here's the thing, some blu ray movies only come with one audio track of uncompressed pcm DTS-HD or something like that (wall-e being one example). I was under the impression that the ps3 would send this audio to the receiver as plain DTS, and I would be able to get 5.1 sound that way. Unfortunately, when I play these movies, the receiver is only getting 2 channel sound. I can expand this using pro logic or neural decoding, but i was really hoping for the full 5.1 track.
are there any funky settings on the ps3 or receiver i'm missing that will let me get the full audio, or am i going to have to just deal with 2-channel sound from the ps3 for those movies?
if i'm leaving out any information let me know, i think i covered everything. thanks guys.
pb32 is offline
post #2 of 5 Old 01-15-2009, 01:18 AM
LBFilmGuy's Avatar
I am trying to watch Wall E right now and having the same exact problem with my Panasonic PT760, it's pissing me off.
http://www.avsforum.com/avs-vb/showthread.php?t=1108817
LBFilmGuy is offline
post #3 of 5 Old 01-03-2014, 06:34 PM
cp1024's Avatar
It's amazing how unhelpful that post link is.
cp1024 is offline
post #4 of 5 Old 01-04-2014, 10:08 AM
Otto Pylot's Avatar
Quoted: 1578 Post(s)
Liked: 984
^^^ it is a 5 year old post rolleyes.gif FWIW, Wall-E played just fine on my Panasonic Blu-ray player.
Otto Pylot is online now
post #5 of 5 Old 01-05-2014, 05:24 AM
DarkVenture's Avatar
Check your multi out settings in the PS3. If you enable HDMI and optical sound output, it will only output 2 channel to optical under some settings. You have to set it so HDMI only gets 2 channel. Can't get surround outputs on both at the same time with the PS3.
DarkVenture is offline
Reply Home Theater In A Box
