Onkyo ht-s790 and no TrueHD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-03-2009, 10:47 AM - Thread Starter
mito's Avatar
Greetings,
My good and faithful old Onkyo HT-S790 doesn't support TrueHD.
I have a Samsung 2550 blu-ray player and wish to hear TrueHD.
What receiver do you recommend that will allow me to keep the HT-S790 7.1 speakers?
Thanks in advance. Cheers.
mito is offline
post #2 of 5 Old 04-03-2009, 12:10 PM
Tulpa's Avatar
Liked: 61
Just about any 7.1 receiver with HDMI audio. Doesn't even have to be Onkyo, although the TX-SR606/605 will allow TrueHD over HDMI.
The HT-S790's receiver will do TrueHD over the analog audio inputs, but you'll need a player that has the corresponding outputs. Doesn't this model have those outputs? You may not have to buy anything but analog audio cables.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 5 Old 04-03-2009, 12:33 PM - Thread Starter
mito's Avatar
Yes, it has analog outputs, but what about overall quality, won't it degrade using analogue outputs?
mito is offline
post #4 of 5 Old 04-03-2009, 01:07 PM
Tulpa's Avatar
Liked: 61
I don't think anyone's ever complained.
If you want to spend on a new receiver, go ahead, but for >$10 worth of cables I'd give the analogs a go first.
Tulpa is offline
post #5 of 5 Old 04-03-2009, 01:16 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Quality doesn't degrade using 5.1 analog outs for TrueHD. I use them on my HD-DVD player to an Onkyo receiver and they sound great.
I even use analog outs for my SACD/DVD-Audio player. In fact that was the only way to do hi-res multichannel audio until recently.
There is a difference from TrueHD and Dolby Digital but its not earth shattering like going from a SD TV to a HDTV. Its a much smaller upgrade, especially if you're using the speakers that came with your Onkyo HTIB.
Like Tulpa said, buy some cables and give it try.
Get 4 pairs of stereo cables, label them and plug 'em in to the corresponding 7.1 input on your receiver!
http://www.monoprice.com/products/pr...t=1#largeimage
Afro GT
afrogt is offline
Reply Home Theater In A Box
